Official Turbo LSJ thread!!!
Old 03-11-2013 | 12:59 AM
  #4551
c130aviator's Avatar
i have read several people going to 3.5" piping on the maf section of pipe.
Originally Posted by jonnymerk
I have posted about this several times and recently. LoL everyone spams new posts in here lately not so much reading. You can try to go to 3.5 in pipe section for the MAF. This often helps and is inexpensive.
Are you serious?
Old 03-11-2013 | 08:17 AM
  #4552
zrated89's Avatar
i already know about the trick for the maf housing thanks. I was just asking if anyone else has had the issue.
Old 03-11-2013 | 08:20 AM
  #4553
zrated89's Avatar
and to answer your question my tvs on the built motor walked away from an E46 M3 on spray that was over 420whp. 18psi on the 6262 feels ten times stronger. As far as people that were insinuating lag and the turbo is too big? lol thats funny. May be a combination of my motor and headwork, but my 62 feels like the tvs did in the lower to midrange, then when she gets into full boost its like omfg hang on
Old 03-11-2013 | 08:26 AM
  #4554
zrated89's Avatar
anyone have a good link or know a place you can buy pieces for a custom 4 inch intake? I need to do it soon so i can tie my catch can line, and a few other things into it. The purge solenoid line is now seeing boost, and i dont think it likes it so much lol
Old 03-11-2013 | 10:12 AM
  #4555
IonNinja's Avatar
Jesus 67lb/min lol
Old 03-11-2013 | 10:16 AM
  #4556
zrated89's Avatar
yea me and joe were like WTF?!? lol (this turbo is a monster, and in a .63 housing with my headwork and motor responds very nicely) Im sure the ceramic dual bbing center and billet wheel helps with spool as well
Old 03-11-2013 | 02:44 PM
  #4557
CCrunner84's Avatar
I believe those lb/min maf readings can be skewed depending on how the injectors are setup, doesn't change the fact that you've maxed the maf out but those numbers can be misleading.
Old 03-11-2013 | 03:26 PM
  #4558
Area47's Avatar
Rent me! per hour
maf maxing does not happen until 16k hz. you can make over a grand on the stock maf btw.
Old 03-11-2013 | 04:19 PM
  #4559
jonnymerk's Avatar
Are you serious?
I was quoting him not you lol. Was merely pointing out the increase in turbo builds and the resulting new random every other post. Questions and answers getting mixed in with the post flood lately. Maybe cus its tax season I dunno.
Old 03-11-2013 | 04:56 PM
  #4560
CCrunner84's Avatar
There's no real way to adjust pasy 11k though is there? It just uses that last value upwards?
Old 03-11-2013 | 07:02 PM
  #4561
yes, 11,100
Old 03-11-2013 | 08:03 PM
  #4562
zrated89's Avatar
theres tricks around it
Old 03-11-2013 | 08:09 PM
  #4563
klutch814's Avatar
how do you guys boost leak test? i have a damn leak somewhere. under wot i spike 24psi and hold 19-20.
Old 03-11-2013 | 08:16 PM
  #4564
thats not a leak that is your MBC. Mine did the same thing on the dyno pull after pull.
NOW I have a leak or a bad WG. I did a leak down test on my piping and there was none from turbo to TB. I boost to 10 psi and then hold there, wont go any higher from 2500-7500. Still working trying to figure my next move. I must have a leak in my manifold or a bad wg spring/diaphram.
Old 03-11-2013 | 08:41 PM
  #4565
klutch814's Avatar
but my leak tester wont hold 10 psi? and idle dips sometime. also i'll leave this here..
Mar 11, 2013 5:24pm | Facebook
Old 03-13-2013 | 06:05 PM
  #4566
I picked up a couple psi and 2 inches of mercury (in hg) of vacuum from taking my blow off valve and regreasing it, air was leaking past the the brass cylinder inside and using a thicker axle grease sealed it up. I was so excited cause I presurized the hose to the BOV and heard it coming out the BOV horn but it ended up not being the whole problem. So my guess is I have anther boost leak either in the brake booster hose or around a bolt or coupling on the manifold. If it is a leak that is holding me back from going over 12 psi now it has to be in the manifold or off one of the sensors mounted to it. I did pull the MAP and reseat it but it felt tight and sealed. I have checked everything else but the wastegate flapper.
Whatever it is it developed slowly over a few weeks and is now still not letting me go over 12 psi. Boost leaks are a PITA.
Old 03-13-2013 | 06:56 PM
  #4567
rivaladore's Avatar
So i was partially right
Old 03-13-2013 | 07:05 PM
  #4568
the BOV spring or being open had nothing to do with this issue. Since its on the actuator side not the piping that was leaking. The BOV held 25 psi when I pressure tested my piping, it has to be something I haven't pressurized yet like my brake booster hose because its so big, I haven't had something to test it.
Old 03-13-2013 | 08:36 PM
  #4569
Cmyler34's Avatar
Did you have problems with the hot side intercooler piping rubing on your tire/boot
Old 03-13-2013 | 09:26 PM
  #4570
dktgarlick's Avatar
^i did. I'm running a Hahn hot side And I had to tie mine up so it wouldn't rub
Old 03-13-2013 | 10:00 PM
  #4571
The previous owners rubbed the pipe. When I got it there was a spot of powder coat rubbed off. My tire even with a wider 225 tire doesnt rub.
Old 03-14-2013 | 12:07 PM
  #4572
Cmyler34's Avatar
Yeah that's what I did, but if I turn to the left hard it rubs, just wondering how to prevent this, I'd rather not have replace all the piping haha:d
It doesn't rub when you turn?
Old 03-14-2013 | 02:01 PM
  #4573
dktgarlick's Avatar
thats odd. Mine doesnt rub at all when I turn. What size tire? Currently I am on 225s in the front
Old 03-14-2013 | 03:40 PM
  #4574
Cmyler34's Avatar
i have 225/18/40 so the same setup pretty much.. idk it only will rub when i make sharp left turns.. idk why hahn made the hot side piping run the way they did.
Old 03-14-2013 | 03:50 PM
  #4575
dktgarlick's Avatar
Mostly so people can keep their windshield washer fluid tank. Also it works with the log style manifold
Quick Reply: Official Turbo LSJ thread!!!
