Official Turbo LSJ thread!!!
#4829
I never really maxed out the car. It had plenty left in it, I just got lazy and forgetful with it one day and made an irreversible boo-boo. That's not something you can do with an aggressive tune and the constantly fluctuating temperatures of Autumn.
The most I ever saw out of the MAF was 49lbs/min. At full boost, I ran 22psi, a 12.0AFR, and 18* timing. My AFR & timing on spool up were fairly aggressive though. The AFR started at 14.7 and ramped down to be at 12.0 once I hit about 15psi... and timing started in the low 40's and worked its way down. Switching to that AFR & Timing ramp took a good 400-500rpm off of my lag compared to flat lining the AFR and having a more traditional timing map. The mods that mattered were the billet HP5557e (T3 .63A/R), ETS 7" Street Intercooler, short routing the piping (2.5" all around with an 8" long section of 3" for the MAF), custom return style fuel system, Vulcan Intake Mani w/ phenolic spacer, and a custom turbo manifold built for flow and top end power - which had a cracked runner.
#4830
your so close to the stripe that even though your loosing momentum from the cams falling off your loosing less from the shift to fourth
#4832
so yes the options are out there and found rather easily
#4833
#4834
12.0 AFR on a 60* day became something like a 12.7 AFR on a 45* day.
The #4 piston didn't like that.
#4835
Yes we've talked about that. I've even short shifted to fourth though before the trap and still ran slower. I'm sure on the new setup ill have to shift to fourth, although now that I'm at 8200rpms it may help but this turbo eats the rpm band up now lol
#4836
I however did all these mods not for the stock cams but to run zzp cams later on for extra power later on. I will bump my redline to 7800 and call it done. The stock rods are not chromoly like 4330 steel but they are 5115 Chromium steel. Stronger than LNF but weaker than aftermarkets. I am running them with billet pistons and chromoly spun sleeves in my block. I would feel good about daily driving the car at 500 whp. They probably could do more but then you have to deal with drivetrain breakage. I hit my 400+ goal with the 20g but to my next goal would be 500 on a different turbo and still daily drive it.
Also if you supercharger guys following along, running those revs will require more work to your crank keyway. The supercharger puts extra load on the crank pulley and with an ATI balancer and a supercharger on the end of that crank the key ways get chewed up.
#4838
a turbo is no different when it comes to the crank key
#4840
A lot less load on the woodruff key when the blower isn't there anymore. I am also on a built valve train and was running zzp cams. Reason I'm back on stockers is because they were a blower grind. I will be contacting comp directly this time around for a nice turbo spec cam. And that's the point I was making with the stock cams even though the power stops increasing after 7k it doesn't fall off and is better to maintain that gear than shift into a lower rpm making less power.
#4842
