Official Turbo LSJ thread!!!
Old 03-31-2013 | 09:11 PM
  #4826
zrated89's Avatar
I have proved that at the track winding third out to 7800 stock valve train, or shifting to fourth. Every time holding third was faster
Old 03-31-2013 | 09:14 PM
  #4827
ULWizSS's Avatar
Why do people even question the guy running 3rd on the all time 1/4 mile list on this forum. Puzzles the **** out of me.
Old 03-31-2013 | 10:42 PM
  #4828
Bad-A-SS's Avatar
Hey usmc what did you max out on your swapped lsj? And what kind of mods n timing n boost were you running?
Old 03-31-2013 | 11:17 PM
  #4829
USMCFieldMP's Avatar
Rattlesnake Race Shop
I never really maxed out the car. It had plenty left in it, I just got lazy and forgetful with it one day and made an irreversible boo-boo. That's not something you can do with an aggressive tune and the constantly fluctuating temperatures of Autumn.
The most I ever saw out of the MAF was 49lbs/min. At full boost, I ran 22psi, a 12.0AFR, and 18* timing. My AFR & timing on spool up were fairly aggressive though. The AFR started at 14.7 and ramped down to be at 12.0 once I hit about 15psi... and timing started in the low 40's and worked its way down. Switching to that AFR & Timing ramp took a good 400-500rpm off of my lag compared to flat lining the AFR and having a more traditional timing map. The mods that mattered were the billet HP5557e (T3 .63A/R), ETS 7" Street Intercooler, short routing the piping (2.5" all around with an 8" long section of 3" for the MAF), custom return style fuel system, Vulcan Intake Mani w/ phenolic spacer, and a custom turbo manifold built for flow and top end power - which had a cracked runner.
Old 03-31-2013 | 11:20 PM
  #4830
mrbelvedere's Avatar
I thought it was later than that. It'd be nice if we had some good cam options and a valvetrain that wouldn't crumble under them.
there are options out there
your so close to the stripe that even though your loosing momentum from the cams falling off your loosing less from the shift to fourth
Old 03-31-2013 | 11:31 PM
  #4831
Of course there are... just not as easy as the majority of other sport compact cars available.
Old 04-01-2013 | 12:03 AM
  #4832
there are several different sets of springs to be had with different types of retainers as for cams you can go to zzp or go custom for the lsj you need 2 intake blanks from a l61 and you can get those from c.e.d. along with the hexes for to drive the sensor comp can grind cams and and install te hex properly
so yes the options are out there and found rather easily
Old 04-01-2013 | 12:17 AM
  #4833
Bad-A-SS's Avatar
Sounds like a hell of a car. What kind of boo boo did you make btw? Im just excited to finally be getting my order in this week THANK GAH.... You should check into my swap thread maybe give me some pointers on somethings.
Old 04-01-2013 | 01:19 AM
  #4834
I didn't retune for a temperature change. 60* one day... dropped to 45* the next. I went to grab something from the store and not even thinking about it on my way home, gave it full boost in 3rd.
12.0 AFR on a 60* day became something like a 12.7 AFR on a 45* day.
The #4 piston didn't like that.
Old 04-01-2013 | 04:27 PM
  #4835
zrated89's Avatar
Yes we've talked about that. I've even short shifted to fourth though before the trap and still ran slower. I'm sure on the new setup ill have to shift to fourth, although now that I'm at 8200rpms it may help but this turbo eats the rpm band up now lol
Old 04-01-2013 | 07:07 PM
  #4836
c130aviator's Avatar
Sure, but at what rpm? Also you turbo guys are alot gentler on the bottom end that I am. I'm an sc purist, just in here to learn.
i will be pushing my stock rods and sleeves and i rev to 8200 on the 6262. Im more worried about stock sleeves due to cyl pressure than my rods failing lol
I duno man many turbo guys on stock cams still make power. But I will be dynoing soon
I am spinning to 7500 on stock cams and while its not making more power its holding the power from 4500-7500 so as not to shift as early. I am running valve springs and balance shaft deletes with no issues except the crappy tensioner allowing slap at higher rpms. Going to fix that soon. I would say however 7000 was the limit on making power on stock cams and I shift around 7000 anyway. Its nice though to know it will continue to pull over 7000 and not drop the power like other cars. LSJ cams are good cams.
I however did all these mods not for the stock cams but to run zzp cams later on for extra power later on. I will bump my redline to 7800 and call it done. The stock rods are not chromoly like 4330 steel but they are 5115 Chromium steel. Stronger than LNF but weaker than aftermarkets. I am running them with billet pistons and chromoly spun sleeves in my block. I would feel good about daily driving the car at 500 whp. They probably could do more but then you have to deal with drivetrain breakage. I hit my 400+ goal with the 20g but to my next goal would be 500 on a different turbo and still daily drive it.
Also if you supercharger guys following along, running those revs will require more work to your crank keyway. The supercharger puts extra load on the crank pulley and with an ATI balancer and a supercharger on the end of that crank the key ways get chewed up.
Old 04-01-2013 | 07:29 PM
  #4837
ULWizSS's Avatar
Well the ZFR sold today. So again time for a new turbo capable of some huge numbers. lol
Old 04-01-2013 | 09:20 PM
  #4838
a turbo is no different when it comes to the crank key
Old 04-01-2013 | 09:47 PM
  #4839
armcclure's Avatar
Good thing I'm taking care of it anyway
And my s/c shouldn't be putting all that much stress on the crank; it'll be hardly working
Old 04-02-2013 | 10:51 AM
  #4840
zrated89's Avatar
A lot less load on the woodruff key when the blower isn't there anymore. I am also on a built valve train and was running zzp cams. Reason I'm back on stockers is because they were a blower grind. I will be contacting comp directly this time around for a nice turbo spec cam. And that's the point I was making with the stock cams even though the power stops increasing after 7k it doesn't fall off and is better to maintain that gear than shift into a lower rpm making less power.
Old 04-02-2013 | 11:34 AM
  #4841
armcclure's Avatar
not just less power, lower gear ratio. at Xhp, 3rd accelerates faster than 4th.
using VirtualDyno and lying about what gear you're in can give you some useful info...
Old 04-02-2013 | 12:45 PM
  #4842
a built valve train has nothing to d with the crank key and just because your not spinning the blower dosent mean you wont shear the key your a lot less likely to shear on a blower then a snail because of how the power comes on a snail is a lot harder on the bottom end the a blower
Old 04-02-2013 | 12:51 PM
  #4843
zrated89's Avatar
You misread my post. I wasn't saying a built valve train is easier on the key. But not spinning the blower and less rotational force (blower deleted) is easier on it
Old 04-02-2013 | 01:21 PM
  #4844
and I would have to disagree to a point having a snail is harder on the key
Old 04-02-2013 | 01:36 PM
  #4845
advise's Avatar
Who's sheered the keyway?
Old 04-02-2013 | 01:44 PM
  #4846
ive seen several on he verge of breaking discovered on engine teardown and I do know of 2 that have been sheared
Old 04-02-2013 | 01:52 PM
  #4847
advise's Avatar
Makes me a little worried looked pefect when i did the head and nbs
Old 04-02-2013 | 02:33 PM
  #4848
Area47's Avatar
Rent me! per hour
i did on a 1k hp vette
no relivance to this conversation, but it's a gm damnit
Old 04-02-2013 | 02:49 PM
  #4849
advise's Avatar
Lol well that's understandable
Old 04-02-2013 | 03:23 PM
  #4850
its not something that's going to happen over night but after a while of zipping these engines up it something that needs to be taken care of
Quick Reply: Official Turbo LSJ thread!!!
