Official Turbo LSJ thread!!!
#4851
while i dont doubt youve seen it before ive hand my hand in many motors as well and havent seen any signs of wear or elongation. You sure the ones uve seen havent had the balancer on and off or running the ATI?
#4852
the balancer being removed and replaced has nothing to do with it you have a 1/4in or less of the key grabbing the dampener and that is why it bends/shears and elongates the key way another reason why is because the dampener is also a slip fit not a press
#4853
Hey guys, what would be the best compressor/turbine a/r combination if I want a relatively quick spool (3-3500-ish) and want to make around 320-330 hp? I've been looking at precision turbos a lot and I'm close to making a decision, but I just wanted to ask around before I actually purchase the turbo haha.
#4855
Yeah honestly I probably won't go over 350 max, I'm planning on boosting around 15-16 psi, would that be enough to get me in the low 300s? And yeah, the Precision 4431 has a 58mm compressor wheel, 57mm turbine wheel, and it comes with a 48 a/r turbine housing, that should be sufficient right?
#4860
Currently I'm on an exedy clutch with about 10-15k miles....the last few thousand being used at the eighth mile by someone else. It's not slipping, but with the new short block going in, I'm questioning whether I should keep using the old clutch. Not too mention it would be easier to put the new clutch in now as oppose later.
#4862
Does $1500 seem right for engine rebuild labor? Of course we are talking about getting everything completely out of the car, cleaned, disassembled and reassembled plus he said he does additional deburring here and there etc. With total cost of parts his labor and machine shop I'm looking at around 4500-5000 grand for my motor rebuild and this doesn't include sleeves. only upgraded parts I'm aware of are the k1 rods, diamond pistons, klevlite bearings and ARP studs. All new gaskets, misc bearing, bolts sensors etc...He siad he thinks the reason my bearings and rotating assembly had issues was due to failure of my balance shaft bearings getting chewed up putting shavings and additional debri into the oiling system.
#4867
i went to put the turndown on the end of the downpipe and when i disconnected the vband for the catback the downpipe just swung down against the swaybar lol. thing had so much play in it. i didn't feel like taking the hot side pipe and dump tube off to get to it so i just put it on jack stands real quick and spent like 30 minutes reaching up there and turning the wrench like 1/8 of a turn at a time.
#4870
ty lol...it's so hard to tell friends and family that don't understand. I didn't plan on this build and tbo I have no idea how I'm gonna get the money together. It is nice to hear someone confirm that the costs are in check at least.
#4871
Ud be surprised. I've seen dumb asses not line the key way up exact and force the balancer on causing issues later on.
