Official Turbo LSJ thread!!!
Old 04-12-2013 | 08:57 PM
  #4901
mahfouzman's Avatar
A couple questions guys, first one, will the tiny 2.2l serpentine belt really fit once I put on the 2.2 tensioner and alternator? Secondly, should I get the oil cap crankcase breather from ZZP or should I just put a filter on the current pcv port? Or both?
Old 04-12-2013 | 09:32 PM
  #4902
mexi_loco's Avatar
The best way to would be to revise your entire breather system. LSJ engines are horrible for venting crankcase pressure. Ask me how I know...
Old 04-12-2013 | 09:33 PM
  #4903
mexi_loco's Avatar
The cheapest way would be to slap a breather filter on the oil cap and call it a day. At least if you don't mind oil all over your valve cover.
Old 04-12-2013 | 09:54 PM
  #4904
mahfouzman's Avatar
Lol I actually read your thread, I wonder why they're so bad at crankcase venting...Would that be enough though? I wouldn't have to put a filter on the pcv port? I'd probably only be running the filter(s) for a little while until I upgrade to a catch can.
Old 04-12-2013 | 10:08 PM
  #4905
mexi_loco's Avatar
I ran a breather filter on the oil cap and was "fine" until I realized that there was a lot of oil and crap around my intake manifold and ports. The filter only goes so far. You really need to do it right. Otherwise you will be popping spark plugs like I did. Or worse.
Old 04-12-2013 | 10:48 PM
  #4906
mahfouzman's Avatar
God damn, did that happen to anyone else?
Old 04-12-2013 | 11:34 PM
  #4907
c130aviator's Avatar
I probably have the most affordable breather on the market. LOL. I am running two 3/8" NPT taps on my valve cover and on my turbo intake with an oil can between them from ebay. The breathers on the oil can are drilled out to just over 1/4" on each to allow for more flow. Total cost was 20 bucks and works great!
Also I gutted the valve cover baffles but that is probably not neccessary as long as you can get the metal shavings out, but good luck with that. LOL
coming out of the vc.
The ebay can ports drilled out to accommodate the larger hose.
Old 04-13-2013 | 09:49 AM
  #4908
rivaladore's Avatar
You ever figure out that boost issue?
Old 04-13-2013 | 10:48 AM
  #4909
mexi_loco's Avatar
Yeah I ran the vacuum from my intake as well. I'm not sure about that catch can myself, but it's def better than what I had. A lot of guys will run a can with a breather filter on there as well. Any little helps imo
Old 04-13-2013 | 09:41 PM
  #4910
i started to tear into today. I am pulling the turbo and take a look at everything really well. There are no boost leaks and my biggest reason behind that is that my vacuum is like 21-22 in Hg. If it were a boost leak it would be a heck of lot lower so something doesnt add up. I think my 20g took a crap from sitting in the garage for 4 months while I built my car. Besides that the PO of the turbo may have never done it properly. I ran this turbo to 27 psi quite a few pulls for peaks and she just slowly started to die. LOL. I will let you know what I find after I pull it apart.
Old 04-13-2013 | 11:06 PM
  #4911
rivaladore's Avatar
Good luck....just want you to enjoy your car already. I feel blessed when I see some of the things you guys go through. I kept my engine stock, went with zzp's cookie cutter kit, and my car was down for barely 3 days when i installed it. Been almost a year and everything's still fine no issues.
Old 04-14-2013 | 02:32 AM
  #4912
mexi_loco's Avatar
I was holding down vacuum just fine as well as boost when I had a crap load of leakage in my whip. The biggest way I could tell is that my car's AFR's were leaning out intermittently at idle. Not too mention my rpm's were jumping when it leaned out as well. Just saying...
Old 04-14-2013 | 11:05 AM
  #4913
Very nice kit.
I know man but everything as you have stated is steady and strong. My AFr's are good and there isnt a trace of a leak, I have checked everything.
Old 04-14-2013 | 03:07 PM
  #4914
Joe Schulte's Avatar
Originally Posted by zrated89
hp tuners due in tomorrow
Old 04-14-2013 | 03:14 PM
  #4915
zrated89's Avatar
Originally Posted by Joe Schulte
time to take matters into my own hands
Old 04-14-2013 | 03:15 PM
  #4916
EXsoccer1921's Avatar
you still on stock sleeves no guard?
Old 04-14-2013 | 07:56 PM
  #4917
zrated89's Avatar
yea stock sleeves. I have a 2.1L sleeved block though already just in case. Gonna see how far the stock sleeves or trans will hold
Old 04-14-2013 | 08:11 PM
  #4918
mahfouzman's Avatar
Is anyone on an all stock engine and transmission? Besides clutch of course. How much power are you making?
Old 04-14-2013 | 08:29 PM
  #4919
BLAZIN07SS's Avatar
I'm too JDM for you
I am but I don't think mine counts
Old 04-14-2013 | 08:32 PM
  #4920
rivaladore's Avatar
All stock here including clutch, probably at around 350. 20psi on the s252et
Old 04-14-2013 | 09:16 PM
  #4921
mahfouzman's Avatar
Lol why is that Blazin?
And seriously Rivaladore? Stock clutch even? How many miles does your car have?
Old 04-14-2013 | 09:19 PM
  #4922
BLAZIN07SS's Avatar
I'm too JDM for you
stock motor, stock transmission, gmpp clutch, e85, zzp s256et on 26psi. estimated 470whp
Old 04-14-2013 | 09:29 PM
  #4923
i'm on a stock trans. but i also hardly drive the car. and i launch it easy
Old 04-14-2013 | 09:34 PM
  #4924
dktgarlick's Avatar
I am also on a stock clutch motor and trans. Pushing about 370hp and I just broke 154k miles
Old 04-14-2013 | 09:35 PM
  #4925
rivaladore's Avatar
78K......yes stock clutch is still holding, been swapped for a year now and two years before i has swapped i was on 2.8 with the m62. i have to feather the gas in second to get any hope of traction
Quick Reply: Official Turbo LSJ thread!!!
