Official Turbo LSJ thread!!!
Old 04-24-2013 | 07:09 PM
  #5151
mahfouzman's Avatar
Has anyone here ever washed their engine bay and then gotten a code for a random misfire? I've been getting the P0300 code since monday morning, I washed my engine bay sunday evening. I got it once before, but it turned off within a couple hours, this time it isn't turning off, could there be water under the coil pack?
Old 04-24-2013 | 10:06 PM
  #5152
MP Cobalt's Avatar
I personally would never take a hose to my engine bay. I wipe it down and ****
Old 04-24-2013 | 10:10 PM
  #5153
mexi_loco's Avatar
yeah, I use degreasing spray, or brake cleaner and wipe it down.
Old 04-24-2013 | 10:14 PM
  #5154
rivaladore's Avatar
I would never spray water near electronics, maybe I'm too used to working with class 3 electronics, but still.....why risk anything.....take your time with a rag and some engine degreaser
Old 04-24-2013 | 11:21 PM
  #5155
mahfouzman's Avatar
I covered everything electric with bags and used a power washer at one of those do it yourself car washes. I pulled the plugs today, put them back in, drove around for about 10 minutes, and the light turned off :P
Old 04-24-2013 | 11:34 PM
  #5156
zrated89's Avatar
Re gapped plugs at work today. But instead of logging the car and making some more adjustments, I had the pleasure of carpeting my sons nursery and now have a sore knee from the kicker lol. Gonna log her again and see how she feels. Now only if there was a way to disable that blasted engine over speed light lmao
Old 04-24-2013 | 11:45 PM
  #5157
c130aviator's Avatar
when are you seeing the overspeed light? I cant find it in HPT, I used to have a rpm dash light setting but now I dont see it. Doesnt matter it never worked anyway but I think in my latest version hpt they removed it.
I am running hpt version 2.23.810
Old 04-24-2013 | 11:51 PM
  #5158
Laser_Blue's Avatar
Does it matter which side is hot and cold on the intercooler?
Old 04-24-2013 | 11:59 PM
  #5159
nope
Old 04-25-2013 | 12:29 AM
  #5160
Laser_Blue's Avatar
nope
Thanks.
Old 04-25-2013 | 08:48 AM
  #5161
armcclure's Avatar
Is that the most recent?
Old 04-25-2013 | 09:52 AM
  #5162
zrated89's Avatar
I'm running the new 2.24 version. It depends what rpm when I see it. I'm sure the neutrals and other things don't help. I really wish it was adjustable but I haven't looked. Hell there isn't even a table to mess with the scip sensor. I was told on earlier ones there was. I'm sure me spinning tires all the time doesn't help lol.
Old 04-25-2013 | 10:10 AM
  #5163
mrbelvedere's Avatar
2.24 is a headache
Old 04-25-2013 | 10:14 AM
  #5164
do it all the time it wont hurt anything just done hold right on the the ele parts hold it away and spray **** off
Old 04-25-2013 | 01:47 PM
  #5165
Bad-A-SS's Avatar
Hey Guys i need a W type crimper anyone got an idea what the hell that is plz help
Old 04-25-2013 | 01:55 PM
  #5166
Area47's Avatar
Rent me! per hour
the over speed light kicks on at 76-7800 rpms in the 07's. can not be changed. hard coded.
you need to click the link i posted about it. there is a link in there to an electronics supply place that has every part you need.
Old 04-25-2013 | 03:40 PM
  #5167
zrated89's Avatar
god dammit that comes on and the cars like ohhhh u wana see 8192 rpms huh ?!?! not gonna happen lol. Before at the track i was hitting 7800 on stock internals, alas guess ill have to nls at 7600-7800
Old 04-25-2013 | 03:48 PM
  #5168
armcclure's Avatar
Why is a little light stopping you?
  #5169
zrated89's Avatar
so anyone on here ran the walbro 400? I was ready to purchase one and in big letters said not for E85. There has to be another special model or something because i know a few buddies running them on E
Old 04-25-2013 | 03:50 PM
  #5170
Bad-A-SS's Avatar
Ok so its just a regular multi crimper lol damn and I was looking all over the place ok gonna go get that but she is almost done just to put the injectors in then tap and put the oil return line in WOOHOO
Old 04-25-2013 | 04:17 PM
  #5171
EXsoccer1921's Avatar
some pumps don't like running e on a returnless system.
Old 04-25-2013 | 04:26 PM
  #5172
Area47's Avatar
Rent me! per hour
run a modded 255 pump.
the overspeed light isn't going to stop you from reving till you fling a rod out of the side of the motor.
Old 04-25-2013 | 04:30 PM
  #5173
get a rule 1500 pump. set timing to over 9000. plug the wastegate so it doesn't open. you should be down track in no time.
Old 04-25-2013 | 04:59 PM
  #5174
zrated89's Avatar
i have a 255 already. Modded as in increase the voltage? think it will flow enough without a return or increased line size?
when u gonna get down the track?
Old 04-25-2013 | 05:09 PM
  #5175
idk. workin on moving right now. hopefully by the end of the season
Quick Reply: Official Turbo LSJ thread!!!
