Official Turbo LSJ thread!!!
#5276
#5277
This is the SAME thing I was thinking because when I just left it vented to the atmosphere it never smoked
#5278
that nipple is not really designed to vent the crankcase pressures created by turbocharging these engines. What you're seeing when blue smoke comes out is most likely caused by oil being pushed out the exhaust by too much crankcase pressure.
There's a couple of fixes to this. The cheapest is to get a breather filter and tap the oil cap. The RIGHT WAY would be to seal that nipple off and weld a couple of -10an fittings to the valve cover and run lines from the those fittings, to a air/oil separator (that has a breather), and to a good known vacuum source (your turbo intake, for example).
I honestly don't recommend the breather filter, for one, because you'll see a **** ton of oil on your valve cover, and two, because it's just a patch and not a fix.
#5279
#5280
So if I get a catch can and weld shut the nipple on the back of the vc then drill and weld a new nipple it should vent enough pressure to keep the oil from being pushed into the exhaust manifold causing the blue smoke? So how about this catch can
http://www.ebay.com/itm/BLACK-TURBO-OIL-CATCH-CAN-TANK-RESERVOIR-750ML-JDM-ALUMINUM-DRIFT-PERFORMANCE-/280769839786?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item415f2fc2aa
This setup would be familiar to c130's but what else must I do to the vc for this to work?
How is this?
How is this?
#5281
I'm not exactly sure how zzp run it myself. I just don't trust that nipple. It's a really small outlet; and after seeing a **** ton of oil around where my intake manifold meets the head, I won't ever use it again.
#5284
I never ran a canned tune ever. Installed kit then had BYT tune me again(tuned my sc setup with no problems).........car would stall with ac on, apparently was to lazy to change the tb scalar settings. we pulled over like 5 times to get the idle right and it was still rough and sent me on my way. Then a few months later after sweating my ***** off in humid weather i got retuned by Gremlin85 on the forums(new england performance and tune) and have had no problems since. It was so nice to finally be able to turn the ac back on
#5285
Well then that's your problem, don't hook it up to the intake manifold. The vacuum there is pulling oil into you combustion chamber. Run the back of the valve cover to right after your air filter like how zzp does with their turbo kits and problem is solved.
#5287
Will do or just try the catch can to intake setup. But ZZP doesn't modify the VC do they?
#5288
It should be fine that nipple is just a little bigger than 3/8s. To be exact I think it is a 1/2. Try it out and let me know bc that's the same one im going with.
#5289
If that's the case it should work perfect I think, I also have 1/2" line that I intended to run at first but the fittings on the catch can are 3/8" so the line is too loose. But I'll let you know man.
#5290
#5292
Just pulled my intake off today, running no catch can and the tube is clean. So reside what so ever, but Eventually I do plan on putting a catch can setup in there sometime.
#5293
This is the actual stock hole that travels about 12 inches to the front of the engine and then is further restricted under the steel baffle.
#5294
#5295
I will drill and weld up my vc later but I really need to just get this thing to a driving state right now so I can save a little money instead of driving the damn gas drinking truck
#5296
#5299
SMH man u should have hit me up dude. Until u get an intake vent that to atmosphere not the intake manifold. Only three lines should be there, your brake booster line, in the center, the line from the pcv check valve in the flange of the intake, and one down to your BOV.
and times two on a sealed catch can thats tied into a vacuum source
#5300
X2 on the check valves in the brake booster and manifold PCV breather on the intake manifold side of the head.
