Official Turbo LSJ thread!!!
Old 05-03-2013 | 09:47 PM
  #5376
rivaladore's Avatar
Tomorrow when it's light out ill take a look at my car and report back if you haven't resolved it by then
Old 05-03-2013 | 09:50 PM
  #5377
mahfouzman's Avatar
Thanks man I would really appreciate it, my oil fitting is coming in tomorrow so I'm hoping I can get done by tomorrow, so it would be awesome if you could do that so I can finally start my car lol.
Old 05-03-2013 | 09:53 PM
  #5378
rivaladore's Avatar
Trying to figure out what that might be, looking at the lsj engine from the side I don't see anything like that would be in the way once the stock stuff is removed
Old 05-03-2013 | 09:57 PM
  #5379
mahfouzman's Avatar
I think it's where the bottom of the tensioner bolts, the stock tensioner that is.
Old 05-03-2013 | 10:51 PM
  #5380
c130aviator's Avatar
Had this done at a race car builder here locally. Shahans Race and Fabrication.
Turned the boost controller down to 18 psi or so (222kpa - atmosphere) and the car was just stupid violent again. WIth the turbo rebuild I am going to go get it tuned on the dyno again to see if my rpms dropped at boost lag and to set up my boost controller back to 22-23 psi. All my calibrations were messed up from the cracked manifold so I need to dial the car in again. Videos to come, the car was scary tonight.
I am going to get a 10psi wastegate spring and an EBC and set it up to run low boost in the first and second gear, then open it up above that. What EBC are you all running?
Old 05-04-2013 | 09:15 AM
  #5381
mexi_loco's Avatar
most likely your car is acting retarded because the tune you had was compensating for the boost leak you were experiencing. Get it retuned and you should be good to go.
Old 05-04-2013 | 09:19 AM
  #5382
mexi_loco's Avatar
this is what his serpentine belt should be looking like now without the LSJ tensioner or the supercharger
Old 05-04-2013 | 10:52 AM
  #5383
i am back on my original 420hp tune, before the manifold cracked. It runs the car into the low 11's AFR. I am upping the MAF frequency today and then running up the Power enrich. I talked my tuner last night and he told me what to try since the rebuilt turbo seems to have leaned out the car since the dyno run. STill going to go get it on the dyno with a new boost controller cause i hate my MBC.
Old 05-04-2013 | 12:14 PM
  #5384
zrated89's Avatar
DAMMIT why cant i have a baby dick turbo that doesnt run out of fuel Going full return system with the DW300 fuel pump and BRFPS
Old 05-04-2013 | 12:32 PM
  #5385
Bad-A-SS's Avatar
Are you running out of fuel at 20psi Kenny? What kind of power do you estimate your making at that much boost?
Old 05-04-2013 | 12:39 PM
  #5386
I ran out of fuel at 22-23 psi, the 20g had more to go. I am on a completely stock fuel system except for injectors and still hit my 400+goal. There is absolutely no point in moving towards more power right now as I cant keep the car from losing traction as it is. I am spending my money on new custom drilled wheels and a boost controller. No one seems to use anything but a mbc on this site. There is so much control to be had form an electronic boost controller.
Old 05-04-2013 | 12:48 PM
  #5387
zrated89's Avatar
more like out at 18psi lol. She leans out past 1/4 throttle in PE, or after 6500 rpms she starts to go back to stoich. Estimate probably 400-430whp as she sits. Tire roasting machine. I will be doing a boost by gear setup for the street though when not on my slicks at the track
Old 05-04-2013 | 10:53 PM
  #5388
MP Cobalt's Avatar
Well least everyone has semi good news. my car is making me pull my hair our. changed valve springs and still no more power, so I must have multiple boost leaks, bad boost controller, bad turbo or the flex piece in the downpipe collapsed and is restricting the exhaust. If it's none of them I have no friggin idea.
Old 05-04-2013 | 11:12 PM
  #5389
rivaladore's Avatar
We bought our kit within days of each other and now I'm scared..............what's your issue? Right now I have an exhaust leak that goes away after a minue of being run, today I retightened all the manifold nuts for the third time and noise is still there but went away in half the time. So possibly needs another retorque or the flange is warped but the flex joint on the downpipe does look a little dark like there's some carbon build up........always something
Old 05-04-2013 | 11:16 PM
  #5390
rivaladore's Avatar
I know BYT was taking **** about the vac lines zzp uses with their kit and saying that they're crap and will split and also remember startingline134211 or whatever number that followed fucked up his turbo because he had a leak and kept upping the boost controller to compensate and eventually his turbo took a crap for over working it
Old 05-05-2013 | 12:12 AM
  #5391
been there two months ago.
tested the tubing and couplers checked good
tested the boost controller good
tested the wastegate good
time passed
tested vac line and bov small 2 psi leak
rebuilt turbo with new seals bearings superback oil spreader etc checked good
finally found a crack in my manifold loosing about 10 psi.
now i have all the above fixed and need a tweak to my tune, its running lean with all the leaks fixed.
20g really woke up
Old 05-05-2013 | 01:19 AM
  #5392
mahfouzman's Avatar
Has anyone taken the insulation from under their hood off? What's the point of it?
Old 05-05-2013 | 05:57 AM
  #5393
BLAZIN07SS's Avatar
I'm too JDM for you
time passed
20g really woke up
low 11's on gasoline afr isn't lean at all. No reason to run it richer. I'm currently running 11.7-11.9:1
Old 05-05-2013 | 10:00 PM
  #5394
i am on E. Right now I am afraid to get into it because I am not sure its going into PE soon enough.
Here you can see at 3600 rpm that it hits my boost setting of 20 psi (238 kpa - 100kpa atmosphere using my phones barometric pressure sensor) I am not seeing my AFR dip below 14.0 right now however there is no KR. The turbo is now hitting max boost at 3600, before the rebuild it was 4500 rpm to reach max boost. With the car responding so much faster to boost the fuel isnt there to keep me wanting to rev it out. The car is spinning tires uncontrollably if I downshift so I am afraid the fuel isnt there with the faster spool. What ramp in do you guys use and my PE delay is set to 3000.
Old 05-06-2013 | 08:37 AM
  #5395
MP Cobalt's Avatar
Yeah I have no idea what it is yet. I work till Friday then leave to Carlisle on Friday so won't be able to test anything till Monday. I'm so annoyed with this crap right now. I think it's a major boost leak or vacuum lines maybe. The only way to tell if it picks the power back up is throwing it on the dyno for a run.
Old 05-06-2013 | 01:30 PM
  #5396
Area47's Avatar
Rent me! per hour
your idc and msec are countering each other.
zrated. aren't ya glad i stepped in to help ya out? it's only money.
Old 05-06-2013 | 01:58 PM
  #5397
i was hoping you would step in there, what does that mean?
Old 05-06-2013 | 02:05 PM
  #5398
also i was reading that IDC is based off of the injectors static state, how can they counteract if IDC is based off the bank 1 injector msec
Old 05-07-2013 | 10:14 AM
  #5399
zrated89's Avatar
me glad yes my wallet not so much lol. Still staring under my hood scratching my head wondering where the hell im gonna fit the surge tank
Old 05-07-2013 | 10:41 AM
  #5400
armcclure's Avatar
On the left. In front of your air filter. Or delete your abs block and mount it there.
Quick Reply: Official Turbo LSJ thread!!!
