Official Turbo LSJ thread!!!
Old 05-09-2013 | 05:07 PM
  #5426
574's Avatar
574
Get back in the game
Old 05-09-2013 | 05:20 PM
  #5427
jonathan923's Avatar
if i keep the cobalt for the remainder of this year for sure i will.
Old 05-11-2013 | 06:22 AM
  #5428
Bad-A-SS's Avatar
Well guys went yesterday to get tuned for boost well turns out Hahn sent the wg with the 7psi spring WOW so disappointed. Lol so now what should I do guys go with another 7psi spring or 10psi spring to stack with the current one?
Old 05-11-2013 | 07:57 AM
  #5429
BLAZIN07SS's Avatar
I'm too JDM for you
You don't have a boost controller?
Old 05-11-2013 | 08:55 AM
  #5430
Bad-A-SS's Avatar
Yeah can I just use that????
Old 05-11-2013 | 09:02 AM
  #5431
EXsoccer1921's Avatar
yes. the spring in the wastegate. unless you only want that amount of boost. is just a "baseline" so to speak. your boost will never be below spring pressure. with a boost controller you can somewhat over ride in basic terms that spring pressure. but it's not like you can run as high of boost as you want. the spring will determine how high you can go.
Turbochargers | Turbobygarrett
click link. hover curser over "turbo tech". it'll give you just about every piece of info you need.
Old 05-11-2013 | 09:18 AM
  #5432
Bad-A-SS's Avatar
I mean that is what I figured, but thanks
Old 05-11-2013 | 09:31 AM
  #5433
Bad-A-SS's Avatar
Ok could i say run twice as much boost? Just trying to get an idea. Checked out that link it will be added to my favorites thanks
Old 05-11-2013 | 09:50 AM
  #5434
paintballerr78's Avatar
you can usually double the wastegate spring with a boost controller so if you have a 7lb spring should be able to run up to 14psi with boost controller
Old 05-11-2013 | 09:57 AM
  #5435
Bad-A-SS's Avatar
Awesome I will give it a try
Old 05-11-2013 | 01:34 PM
  #5436
Killa SS's Avatar
Hey guys. My fuel pump has been makin a funky sound during priming lately. Its a walbro 255. Been in the car for a few years. Less then a yr on e85. Car has been acting up lately as in stuttering like fuel starved and during warm up stutters and gets a bad idle dor short peeiords and sometimes dies. Think I may need a new pump? Any suggestions? Ive replace my fuel filter already. Also has been running leaner according to my wideband when I get on it hard and it breaks up bad.
Old 05-11-2013 | 03:04 PM
  #5437
armcclure's Avatar
Sounds like the walbro is on its last leg. Get a deatschwerks. No more problems.
Old 05-11-2013 | 03:30 PM
  #5438
Killa SS's Avatar
Is it a direct swap? I have a return style setup.
Old 05-11-2013 | 05:35 PM
  #5439
armcclure's Avatar
Almost. A little trimming with a dremel (like a couple minutes worth) and it drops right in.
Old 05-12-2013 | 10:11 AM
  #5440
slvr 04 rl's Avatar
ill have my aeromotive steath 340 pump up for sale soon. i needed more fuel so i bought the walbro 400lph fuel pump.
Old 05-12-2013 | 10:23 AM
  #5441
Killa SS's Avatar
Hows it handle e85? I daily my car and I heard that pump likes to over heats and fails. Hows ur experience been with it?
Old 05-12-2013 | 11:40 AM
  #5442
armcclure's Avatar
The stealth does not like corn. Some last a week some last a month, a handful last 6 months plus.
Old 05-12-2013 | 12:09 PM
  #5443
Killa SS's Avatar
Ok thx!! Hows the swap from a 255 walbro with a return setup too the dw300? Direct swap? Any lines different?
Old 05-12-2013 | 02:29 PM
  #5444
armcclure's Avatar
The lines all stay the same, you're only changing what's in the tank.
I've never I stalled a walbro, so I'm not sure. But for installing the dw300, all you have to is take a dremel or even a file and open up the hole in the canister that the power plug clips into, then take about 1/8" off the sending hose piece so that it can clip onto the pump.
The plug opening is obvious once you look at it but here's b/a pics of the other part.
Old 05-12-2013 | 02:42 PM
  #5445
Killa SS's Avatar
Ok. Great. Should be simple then. How long have you been using the pump for?
Old 05-12-2013 | 02:43 PM
  #5446
armcclure's Avatar
Roughly 50k
Old 05-12-2013 | 02:45 PM
  #5447
Killa SS's Avatar
How can I tell if my pump is for sure going bad besides the symptoms im experiencing now. I havent noticed a fp drop at my regulator. Damn thermostat is stuck open. Replacing that and my wideband sensor tuesday. What should I look for in my short term and long term fuel trims. How can I tell if its leaning out by the numbers?
Old 05-12-2013 | 02:46 PM
  #5448
Killa SS's Avatar
Also believe I have a bad battery. Could that cause any misfire/ stuttering issues if I have bad cells in the battery?
Old 05-13-2013 | 06:13 PM
  #5449
mahfouzman's Avatar
Does anyone here have an LSJ throttle body harness? Or does anyone know where I can get one?
Old 05-13-2013 | 06:34 PM
  #5450
SylverSS/SC's Avatar
check ZZP, not sure if you need an extension or not
Quick Reply: Official Turbo LSJ thread!!!
