Official Turbo LSJ thread!!!
Old 05-13-2013 | 06:38 PM
  #5451
mahfouzman's Avatar
They don't have the harness, just the adapters for running other TBs.
Old 05-13-2013 | 07:06 PM
  #5452
EXsoccer1921's Avatar
yeah i'm just running a 2.4
Old 05-13-2013 | 08:28 PM
  #5453
mahfouzman's Avatar
I'm not sure if I can run a 2.4 tb on the adapter plate, the extension that I made went to crap because I crimped it instead of soldering, didn't work out. The wiring on my harness is really short now so I figured it would be much easier to get a new harness so I have wire to work with when I solder in a new extension.
Old 05-14-2013 | 11:35 PM
  #5454
c130aviator's Avatar
Originally Posted by zrated89
if i was still SC there would be alot more room, running the Hahn intercooler piping with my monster IC i have not so much lol
How are the stock rods doing? What PSI are you at?
Old 05-15-2013 | 10:50 AM
  #5455
Cmyler34's Avatar
Anyone have any idea on how to change the oil filter with the Hahn intake mani/ ttr
Old 05-15-2013 | 01:01 PM
  #5456
patiently.
Old 05-15-2013 | 01:03 PM
  #5457
jonathan923's Avatar
i can tell you its a whole lot easier than when your lsj was stock...
Old 05-15-2013 | 01:08 PM
  #5458
Cmyler34's Avatar
I can't seem to get the oil filter out, it hits the throttle body, or so it looks
Old 05-15-2013 | 02:13 PM
  #5459
I use a socket on an extension just behind the TB but forward of the fuel rail, loosen it, pull the filter and the cap out as one right behind the TB and turn it over on it side. Mine comes right out between the TB and the oil cooler block.
Old 05-15-2013 | 02:27 PM
  #5460
Cmyler34's Avatar
But the big silver block on the back of the throttle body gets hit by the oil cap where the filter pops into and I can't pull it up
I have a pic on my phone if you can text me
Old 05-15-2013 | 02:30 PM
  #5461
cant get to my phone at the moment.
I also have a throttle body spacer on my setup. Do you?
Old 05-15-2013 | 02:32 PM
  #5462
Cmyler34's Avatar
Not that I'm aware of.
Old 05-15-2013 | 02:35 PM
  #5463
This is a Hahn kit, it came with all that little stuff that makes the difference when accessibility and functionality are needed in some areas. I have a list of the things the Hahn kit came with somewhere. Anyway, look between my manifold and my TB. Do you have that spacer there?
Old 05-15-2013 | 02:38 PM
  #5464
Cmyler34's Avatar
Your picture won't load and let me view it, and yes I have the Hahn kit as well so I prolljry have it
Old 05-15-2013 | 02:40 PM
  #5465
I thought your manifold was TTR?
Old 05-15-2013 | 02:41 PM
  #5466
Cmyler34's Avatar
It is, but everything else is hahn.
Old 05-15-2013 | 02:43 PM
  #5467
Then you are missing the spacer, so your TB is in the way of the cap. I think.
Old 05-15-2013 | 02:48 PM
  #5468
Cmyler34's Avatar
Yes that's the problem, should I just remove my tb? Or how else can I do it? Everything else is done in this oil change besides this stupid filter
Old 05-15-2013 | 02:52 PM
  #5469
i had the hanh manifold and didnt have issues removing the oil filter then, if anything like i said it was much easier.
like caviator130 already said, use a long extention with the right size socket i think it kinda goes in sideways but still should be enough to loosen it and pull it out
Old 05-15-2013 | 05:01 PM
  #5470
Cmyler34's Avatar
No the problem was my tb. I just took it off and it fixed the issue
Old 05-15-2013 | 05:23 PM
  #5471
cool!
Old 05-15-2013 | 05:27 PM
  #5472
Cmyler34's Avatar
cool!
Thanks tho guys!
Old 05-15-2013 | 05:57 PM
  #5473
BLAZIN07SS's Avatar
I'm too JDM for you
do I have super powers? I changed it when I had the Hahn manifold without taking anything off lol
Old 05-15-2013 | 06:24 PM
  #5474
i never took anything off either, Hahn includes a spacer so you can get to the filter. Cmyler has the TTR and his TB is bolted directly to the manifold and is in the way of the cap.
Old 05-15-2013 | 06:42 PM
  #5475
Killa SS's Avatar
I never had a spacer on my hahn kit and I got to the oil filter just fine
Quick Reply: Official Turbo LSJ thread!!!
