Official Turbo LSJ thread!!!
Old 05-22-2013 | 11:05 PM
  #5551
mahfouzman's Avatar
Haha nice man, I need to do cams when I get the money. I didn't do a rebuild but considering the time it's taken me to do the swap I may as well have lol. I mean I'm thinking maybe the oil stain could have been from when I was installing the oil return and feed flanges onto the turbo, because my workbench is all oily, but I hope that's it, I'll keep a really close eye, worst case I might get a larger drain flange and line and see if that helps, thanks man
Old 05-23-2013 | 05:59 AM
  #5552
c130aviator's Avatar
no prob, your turbo is different then mine obviously but my drain flange is the .5 inches and its flowing with no issues. Its the same size on the bigger 25g turbos as well.
Old 05-23-2013 | 08:23 AM
  #5553
574's Avatar
574
You get custom comp cams??
Old 05-26-2013 | 01:59 AM
  #5554
mahfouzman's Avatar
Where did you guys tap your pan for the oil return? I tapped mine just above the oil drain plug and I think that's what might be causing excess oil pressure to build in my turbo...
Old 05-26-2013 | 06:56 AM
  #5555
574's Avatar
574
I can take a picture of mine tonight if no one else does by then.
Old 05-26-2013 | 08:28 AM
  #5556
BLAZIN07SS's Avatar
I'm too JDM for you
You did it just above the plug? You are supposed to put it as high on the pan as possible
Old 05-26-2013 | 10:22 AM
  #5557
not custom, 212/212 duration stage 2 zzp comp cams
Old 05-26-2013 | 10:24 AM
  #5558
these are old pics before my engine build but you get the idea
Old 05-26-2013 | 10:42 AM
  #5559
mahfouzman's Avatar
Damn, well I guess that's what we'll be doing today, this'll be fun :P
Old 05-26-2013 | 09:33 PM
  #5560
EXsoccer1921's Avatar
Old 05-26-2013 | 10:37 PM
  #5561
mahfouzman's Avatar
Now that, is a clean engine haha, nice man. And thank you to everyone who provided a picture, hopefully tomorrow I'll get around to getting the oil pan off again.
Old 05-26-2013 | 10:40 PM
  #5562
lol, when I built my block I scrubbed it with a wire wheel and hand washed it.
Old 05-26-2013 | 10:44 PM
  #5563
mahfouzman's Avatar
God damn that looks sweet haha, valve cover is painted perfectly. I painted mine along with the spark plug cover, both are now ruined after not even two weeks because of the work we've been doing in the engine bay lol.
Old 05-26-2013 | 10:50 PM
  #5564
when i work on the car I cover it or make sure if I am going to do anything around it to remove it. I have stage 2 turbo cams to throw on, when I pull the cover I am going to touch the few areas up on it that are scratched. Overall the VHT Copper High temp is holding up really well.
This was yesterday.
Old 05-26-2013 | 11:11 PM
  #5565
eh, it just never had anything on it, till the axle boot exploded hahah. i never used to really care what the car looked like but now i'm moving towards looks a little bit.
Old 05-26-2013 | 11:31 PM
  #5566
get off here and work on the headlight intake already exsoccer
Old 05-26-2013 | 11:40 PM
  #5567
hahah i can't right now. it's 2.5 hours away from me. but i'll be back up there in a couple weeks or so to finish that and look into the transmission issue more
Old 05-29-2013 | 04:54 PM
  #5568
mahfouzman's Avatar
Do you guys think I'll see any leaks from the oil pan if I can't get one of the bolts back in? It's in a really tricky position and I really can't get it back in.
Old 05-29-2013 | 04:58 PM
  #5569
your not having any issues that many of us have had on here already. All bolts went back in with no issues, do it right, dont be lazy or give up so easy. What bolt are you talking about?
Old 05-29-2013 | 05:01 PM
  #5570
mahfouzman's Avatar
It's one of the corner bolts, it sits in right above the frame so I can't get a socket in there, I don't know how I did it the first time lol.
It's on the side with the crank pulley towards the front of the car
Old 05-29-2013 | 05:05 PM
  #5571
you need a 13mm socket and an extensionfor that deep crevice area just under the ac compressor.
Time to go buy some tools, extensions, different sized ratchets.
Old 05-29-2013 | 05:17 PM
  #5572
mahfouzman's Avatar
I got it lol, I had to get a little creative, I have everything, I just needed a way to get the bolt started in there so I could use the ratchet. I used this screwdriver with a 1/4" socket drive on it to start it and the ratchet to tighten it. Time to turn it on haha.
Old 05-29-2013 | 06:02 PM
  #5573
Old 05-29-2013 | 06:40 PM
  #5574
MP Cobalt's Avatar
Mark which dip stick are you using?
Old 05-30-2013 | 03:50 PM
  #5575
Leaning forward with the 20g, wanna see what cams and more fuel will do on the dyno?
Quick Reply: Official Turbo LSJ thread!!!
