Official Turbo LSJ thread!!!
#5652
I know yours is good to go. im just stating that because I took mine off for a while and then put it back on. im a retard and hooked the fuel up backwards. burnt my pump quick. oh well I needed a new one anyways.. it was bound to go out soon anyways. got 130000 miles on it.
there is guy on here that showed me this great replacement upgrade that is plug and play from jegs or summit racing for 100 bucks. There are of course lots of good replacements.
#5654
yeah I just went with a stock pump. I do have the zzp rewire kit tho. .. its good to go for now. once euthanasia gets my kit finished I will be replacing the head for a ported head the sc upgrade and my balance shafts. I know im not cool like you turbo guys but I should be one of the quickest sc guys around. lol
#5659
anyone have any idea about going lsj tc swap and keeping your stock intake manifold, buying the adapter plate from zzp? idk where i can get vacuum from for the bov. someone said there is one port on the stock manifold once you remove the sc?
#5662
#5664
AEM fuel pump 50-1000 is a direct swap pump. 320lph at 43 psi 13.5 volts. Gonna go this route if my pump fails.
#5666
#5668
I have an almost complete zzp oil/feed return kit, zzp bov and my old lsj oil pan(zzp oil feed return kit comes with oil pan fittinng to be welded on). The feed/return kit is partial because the return hose I cut an inch or so off so it might be too short now. And the bov wasn't opening properly causing turbo flutter( I don't know how they even let that sell with their kit....needs a weaker spring!) I went with a tial q didn't feel like ordering a different spring and wanted a quick easy solution after dealing with installation headaches. The oil pan will come in handy because you can have an oil pan ready the day you are doing the install and not have to worry about running out and getting your pan welded in the middle of your tear down. Pm me if you're interested
#5672
I was getting compressor surge under certain situations with mine. Fourth and fifth gear accelerate on the highway let off and get the cha cha cha chaaa sound. Spring is too stiff. Im Not putting that kind of strain on the fins on the compressor wheels a daily driver. Put in the tial q and the surge is gone but bov hangs open at idle. I never catch a break.
#5674
