Official Turbo LSJ thread!!!
Old 07-20-2013 | 01:17 AM
  #6176
SupaCharged06's Avatar
Question about brfps. I am going to plumb a return style in using my evap as a return. I am going to run the regulator in my engine bay and have bought the Ottp fuel rail fitting and will run that to the feed on the regulator.
My question is I am mainly running this to improve the idle issues with the big injectors and give me some room to grow if I go to e85. Will leaving the stock regulator in the pump and having this on the rail drop the pressure under vacuum? I don't care much for increasing boost pressure over 17psi at the moment but zzp's instructions confuse the **** out of me. Their option 1 install seems like it would drop boost pressure..
Also what is the deal with having to change the fuel filter?
Old 07-20-2013 | 08:50 AM
  #6177
mexi_loco's Avatar
You have to take the stock regulator out in order for the brfs to work. The fuel filter is different because you have two fuel lines plumbed into it as oppose to one.
Old 07-20-2013 | 11:15 AM
  #6178
Ok but if I'm not plumbing it under the rear axle then i shouldn't have to get the filter
Old 07-20-2013 | 03:32 PM
  #6179
rico's Avatar
Old 07-22-2013 | 12:45 PM
  #6180
Laser_Blue's Avatar
I'm just about done with my turbo swap. Finally. Lol. I'll post up a video this Friday when I'm getting tuned.
Old 07-23-2013 | 08:20 PM
  #6181
Killa SS's Avatar
Apparently my pressure plate doesn't work with the dual mass flywheel in the f40 conversion so zzp replaced the pressure plate with an oem pressure plate. I have a feeling its not gonna hold the power I make or plan on making. Im putting down 461whp and 385wtq at 21psi. I wasnt even asked if I wanted a diff pressure plate installed to handle the power. And ill be damned if I have to pay more to have it swapped out later due to a slipping clutch.
They have also had my car for 7 &1/2 business days and i was told id have my car back in two business days.
What do you guys think?
Opinions plz!
Old 07-23-2013 | 08:40 PM
  #6182
c130aviator's Avatar
the constant issues with any cobalt company seems to be the norm. Cars are very complicated and you cant always foresee all the things. its only 10 days I wouldnt sweat that at all. If its months then you have problems, unless you are fitting the bill for a hotel, then that sucks. Good luck man. I am sure your clutch is fine. My GMPP upgrade is handling my power just fine and I was pulling on the dyno at 27 psi and no slipping. You power will probably come on much greater at a given PSI but I think you will be happy as long as its the LNF version of the PP. The stock style LSJ PP sucks.
Old 07-23-2013 | 08:47 PM
  #6183
Killa SS's Avatar
Regardless I was given a time frame itd be done. And it better hold. I bought my clutch from them. They should atleast put in a new stronger pressure plate thats equal to what I bought and had them install before
  #6184
EXsoccer1921's Avatar
7.5 days lol. That's not that much man. It's a custom transmission built and r&d'd by the people installing it. You take your car to a shop down the road in your home town there and tell them "I want an F40 transmission. I'm going to need it back in a week.". They'll tell you it's not going to happen for at least a month.
I'm not trying to be a dick, sure being told one amount of days and it ending up being different is frustrating. But for that kind of work I'd rather them take their time and do it right. **** they've had my car in a time frame starting back in may '11 till now a total of like 10 months for things. And I can't find one area to be displeased in.
Old 07-23-2013 | 08:49 PM
  #6185
Bad-A-SS's Avatar
So what's a reasonable AFR @wot??? For a turbo swapped LSJ?
Old 07-23-2013 | 08:52 PM
  #6186
Killa SS's Avatar
Most would say 12.4-12.7 is safe and makes good power
Old 07-23-2013 | 08:54 PM
  #6187
Bad-A-SS's Avatar
Ok then I am guessing the reason my car hits a brick wall is because its running to rich maybe??? Exsoccer got any thought on this?
  #6188
Killa SS's Avatar
I understand its all custom but it is frustrating when Im told one thing and then it doesn't happen. And the pressure plate is concerning me do to my hp and I want to turn up the boost for the track with slicks and I wont run **** if my clutch is slipping
Old 07-23-2013 | 09:06 PM
  #6189
You'll be fine.
Old 07-23-2013 | 09:14 PM
  #6190
BLAZIN07SS's Avatar
I'm too JDM for you
Not safe on pump gas at all. 11.6 to 11.9 is a safe place to be
Old 07-23-2013 | 09:20 PM
  #6191
mexi_loco's Avatar
^this
Old 07-23-2013 | 09:32 PM
  #6192
Bad-A-SS's Avatar
Ok well im not much below that Im right at 11.4AFR so it must be something else dammit
Old 07-23-2013 | 09:39 PM
  #6193
On E...
Old 07-23-2013 | 09:51 PM
  #6194
Killa SS's Avatar
E85 sry. Ur right on gas afr my bad
Old 07-23-2013 | 09:56 PM
  #6195
Bad-A-SS's Avatar
Here is an easy take off. Need to get a good video of the OPEN WG gah that sound yum will be coming soon I promise lol meanwhile here ya go
Old 07-24-2013 | 10:06 AM
  #6196
Area47's Avatar
Rent me! per hour
if you're running north of 11.5 afr on e. you're losing power.
Old 07-24-2013 | 10:09 AM
  #6197
Killa SS's Avatar
Thats what zzp tuned it for. Why am I losing power?
Old 07-24-2013 | 10:29 AM
  #6198
armcclure's Avatar
Corn makes better tq richer than gas. And as we know, hp is tq*rpm/5252.
Old 07-24-2013 | 10:37 AM
  #6199
Killa SS's Avatar
Realllyy? Hmm. This is why I want to find some one else to tune me but I have no one local to do so.
Old 07-24-2013 | 11:13 AM
  #6200
armcclure's Avatar
Look at eq and/or lambda.
Quick Reply: Official Turbo LSJ thread!!!
