Official Turbo LSJ thread!!!
Old 08-02-2013 | 12:30 PM
  #6251
Killa SS's Avatar
Im looking for a mini afc any leads
Old 08-02-2013 | 12:44 PM
  #6252
c130aviator's Avatar
zzp doesnt have them?
Old 08-02-2013 | 03:02 PM
  #6253
Killa SS's Avatar
Yea but tim said there hit and miss with them workin
Old 08-02-2013 | 06:19 PM
  #6254
I saw that zzp quit tuning over 21 psi on your build, awesome numbers by the way. You can tune around the problem. I went as far as 27 psi with stock MAF stuff and 3" MAF housing.
Old 08-02-2013 | 06:22 PM
  #6255
armcclure's Avatar
4" maf ftw
Old 08-02-2013 | 06:27 PM
  #6256
^this is the right way to do it but for my 20g maxing out at 470whp I dont think I am going to do the larger MAF housing since the 20g seems to be reigned in just fine the way I am setup right now.
Old 08-02-2013 | 07:09 PM
  #6257
Cobalt_SSTuner's Avatar
So I finally fixed my car. After replacing the cam sensor, crank sensor, and having the fuel pump recalled, it ended up being a bad maf sensor...
So just to note, when a maf goes bad, it may not throw a dtc
On a side note, can anyone confirm, with k1 rods the stamp faces the front of the motor correct?
Old 08-02-2013 | 07:11 PM
  #6258
Originally Posted by Bad-A-SS
Is this the Hallman boost controller you guys run???
Hallman ESKIT ES Kit Boost Controllers : Amazon.com : Automotive
Grimmspeed boost controller imo is the best quality I have seen yet
Old 08-02-2013 | 07:23 PM
  #6259
rico's Avatar
^ yep
Old 08-02-2013 | 07:43 PM
  #6260
Yep too?
Old 08-02-2013 | 09:17 PM
  #6261
rico's Avatar
Originally Posted by Cobalt_SSTuner
Yep too?
Lol grimdspeed
Old 08-03-2013 | 02:30 AM
  #6262
armcclure's Avatar
Pull through vs blow through... Who has tried both?
Old 08-03-2013 | 03:04 AM
  #6263
Blow through, I found it was easier to get a more accurate tune, plus who wants to have to extend the maf all the way to the back if the motor lol. Just make sure you put the blow off valve before the maf sensor on the hot side
Old 08-03-2013 | 03:22 PM
  #6264
Found out my smoking issue on decel is my turbo seals, I hate to say it but even after my turbo rebuild with new bearings, seals, etc. I am getting small amounts of oil to pool just after the compressor exit, about a small oil cap full. At first I thought it may have been my rebuild was bad or had dirt in it. I also thought my inexpensive oil catch was not doing its job, but those both turned out to be good to go. Even with my VC baffles removed my oil catch is doing its job well. In spite of its inexpensive 30 dollar price tag.
I now believe it to be an oil restrictor issue. I think during hard pulls my oil gauge is hitting 80 psi. I am not using an oil restrictor cause it wasn't needed before. However I am pulling hard on the car lately and it may have always been a problem but now is showing up. Per a lot of the 20g guys and mexiloco i think i need an oil restrictor off my high pressure oil line.
Also as an update, I have been working with hahn for almost a month now on a new manifold. I will be the first to get a chance to run it and cant wait to post up pics of the install.
Old 08-03-2013 | 04:02 PM
  #6265
mexi_loco's Avatar
One thing I am considering as well is rigging up a cooling system that utilizes a small radiator and the stock LSJ intercooler pump. A buddy of mine runs a 20g in his cav and he was having issues with keeping it cool.
Old 08-03-2013 | 05:07 PM
  #6266
You could just plumb coolant lines from the crossover tube to the turbo and a return to the bottle. Way easier and inexpensive I would think.
Old 08-03-2013 | 05:15 PM
  #6267
I had a few issues with that when I first started running my turbo and I contemplated running a restrictor, then the smoking issues stopped. Keep me informed on what you find!
Old 08-04-2013 | 12:17 PM
  #6268
Bad-A-SS's Avatar
Ok guys just installed my hallmans mbc WOOHOO... But yesterday my brick wall problem is back. I cleaned the maf sensor n it seemed to work for a few days then the other day i did a third gear pull n bam did that **** again. So i went and ordered a maf sensor should i pull out the map sensor n clean it while I'm just messing around on her today? Thanks
Old 08-05-2013 | 07:25 AM
  #6269
armcclure's Avatar
What do you guys do with the scip sensor? Just delete p1182?
Old 08-05-2013 | 07:53 AM
  #6270
Tjolley's Avatar
Yes
Im sure gm put it there for diagnostic reasons
Old 08-05-2013 | 07:54 AM
  #6271
574's Avatar
574
Had to get a 3.5" vband flange for my down pipe so it would fit the precision 5862... Not sure why because I talked to zrated about his 6262 and he said he only needed 3"
Old 08-05-2013 | 08:22 AM
  #6272
armcclure's Avatar
There's quite a few discharge options for each compressor.
Originally Posted by Tjolley
Yes
Gm put it there just to **** us off is the consensus I've come to.
Yes
Old 08-05-2013 | 09:06 PM
  #6273
574's Avatar
574
This thread needs more pictures
Old 08-05-2013 | 09:10 PM
  #6274
Killa SS's Avatar
Old 08-05-2013 | 09:16 PM
  #6275
06blackg85ss's Avatar
wow that looks mighty similiar to my set up from way back in the day
Quick Reply: Official Turbo LSJ thread!!!
