Official Turbo LSJ thread!!!
Old 08-10-2013 | 11:21 PM
  #6426
steveobed's Avatar
I wouldn't say cocky. Just fed up.
Oh all admit I'm getting a little pissed and frustrated, but you would too.
Apparently they call this place the short bus for a reason.
Yes I would too haha very valid point!
Old 08-11-2013 | 12:08 AM
  #6427
mrbelvedere's Avatar
you are the one riding it
Old 08-11-2013 | 12:12 AM
  #6428
Yes, the stock baffling sucks. So add a can. I absolutely never said a separator was a bad idea, not sure why your point was there...
Anyway, that's fine. But keep the stock port on the back of the vc so that you actually have some vac on the case when out of boost.
By drilling a hole and using a larger like you've increased airflow through the crankcase but lost vac. This is also a big vac leak that youre now forced to tine around. The oil in your can is blowby. As is the gunk on a stock tb/s inlet.
Your system is working like a stock one but is different on these ways:
Your fresh air inlet is too big. You have less case vac than stock
It is unmetered air, causing a self-made vac leak that you must tune around.
The only benefit you've made is that when your rings are trashed thanks to not having proper case vac, at least is wont pop the dipstick and make a mess thanks to your added line.
if you dig around on here you will find something your missing/not seeing from people running home depot air/oil seperator that has been done many years ago from if you find it you pic up on something that I did a long time ago
Old 08-11-2013 | 06:53 AM
  #6429
BLAZIN07SS's Avatar
I'm too JDM for you
no vacuum source here. could my system be better? sure, but it's functional as is and the car consumes no oil
Old 08-11-2013 | 08:49 AM
  #6430
MP Cobalt's Avatar
I see a vaccum source . Hehehe
Old 08-11-2013 | 08:57 AM
  #6431
Powell Race Parts's Avatar
Josh there is a filter on top of your breather can, right? so yup no vacuum going on there. If the can was sealed and you returned the gases ( that would be collected in the catch can along with the oil)
to the inlet manifold, then perhaps it would work.
atmospheric breathers work pretty much, but are not allowed in cars and trucks anymore due to environmental concerns. 99% of the cars I see at car shows have atmospheric breathers. And clearly most folks dont understand or care about retaining vacuum based PCV systems.
The new Camaro has a little bit of a PCV issue and the latest is an oil filler seperator device, with a vent line to the back side of the throttle body. New C7 has a patented PCV system. DI.
Old 08-11-2013 | 09:42 AM
  #6432
unless he plugged the port in the head he has a vacuum source that is pulling air in through his catch can
Old 08-11-2013 | 09:53 AM
  #6433
armcclure's Avatar
No, he doesn't. Because of that massive line running from the oil cap to the vented can. Air is flowing through, yes, but it's a massive vac leak and nearly zero crankcase vacuum.
John, were friends, so don't take this the wrong way. But you're missing some pieces here. And I could pile on all the information in the world and it wouldn't change your mind so go ahead and run a big ass vac leak and have someone try to tune around it. Hopefully your rings will seat without vac.
This is the "cams at 10&2" argument at Jordan's all over again
Old 08-11-2013 | 10:04 AM
  #6434
Killa SS's Avatar
I have a hose running from the back of the vc running too a tee along with a hose from the oil fill cap to the same tee then to an oil/air separator to the intake tube pre turbo for constant vac at all times. Is this the correct way or bad? I havent followed all the arguments between you guys. Just curious if my set up is ok
Old 08-11-2013 | 10:07 AM
  #6435
armcclure's Avatar
Killa SS this should answer your question too:
Get an ultra-low pressure check valve from Powell and put it in the like from the oil cap to the breather, so that flow can only go out of the case in this line.
Remove the filter on the can and add a line in place of it that runs to the intake tube pre-turbo as close to the impeller as possible.
This way, your self made vac leak is as tiny as possible which will help with tuning. Additionally, when wot, the line on the intake tube will creak a minuscule Venturi effect to help remove blowby gasses through both lines.
When you return to vac, check valve closes and everything goes back to normal.
Old 08-11-2013 | 10:08 AM
  #6436
armcclure's Avatar
Putting an air/oil separator in the stock line is far different from what were talking about here.
Old 08-11-2013 | 10:10 AM
  #6437
armcclure's Avatar
Assuming the head port isn't plugged, yes. But it's just sucking air through the case instead of pulling a vac on it.
Old 08-11-2013 | 10:15 AM
  #6438
armcclure's Avatar
The only issue is the line on the oil cap is unrestricted, causing a free flow and low case vac. Either remove this line or install one of powell's check valves as I mentioned to josh and your tuning will become much easier along with actually having vac on the case instead of just flushing air through it.
Old 08-11-2013 | 10:19 AM
  #6439
buzz you should go digging around and see what you find
Old 08-11-2013 | 10:22 AM
  #6440
lol keep swinging
Old 08-11-2013 | 10:31 AM
  #6441
Jeff876's Avatar
Hey guys,
i'm pretty new but have been on RLF for a while.
I just had a couple questions figured i'd ask here rather than making a thread
for a turbo setup - most likely just ZZP's full kit - do I want a non-resonated catback? their options are like "resonated for supercharged" and "non resonated for turbocharged" so I figure I won't want that?
I'm not 100% sure if I wanted to go turbo or not yet, so I was going to just do exhaust/s3 kit because its "cheap" and I figured I could sell both afterwards for not much of a loss.
was just wondering if I could/should keep the catback if I decided to go turbo.
also, do any of you run their full kit? I was wondering how the race tune works etc, i would not mind paying the $500 for the race tune, but would I need a dyno tune afterwards as well or does it get the most for the car/reliable as well? I don't care about squeezing extra HP out, its mostly going to be reliability>>power as long as i have around 325-350 wheel if I turbo swap.
They say it has adjustable launch control etc, how would you change that? specify when you buy, or is there some way to adjust it w/ laptop? would you need to use HPT?
Just wondering what I'm getting myself into
thanks
Old 08-11-2013 | 10:37 AM
  #6442
Killa SS's Avatar
Originally Posted by Jeff876
Hey guys,
thanks
Just get a 3in turbo back with zzp res. Sounds great!
Old 08-11-2013 | 10:42 AM
  #6443
armcclure's Avatar
lol keep swinging
Oh I got a big corked bat named truth and I'm swinging for the fences
  #6444
Killa SS's Avatar
Where can I find powell parts? Last I knew he didn't have a website up
Old 08-11-2013 | 10:43 AM
  #6445
armcclure's Avatar
john@powellraceshop.com
Old 08-11-2013 | 11:16 AM
  #6446
Killa SS's Avatar
I need to rebuild my inner cv axel. I have zzp stg1. Are these just lnf axles? I cant find needle bearings and retaining clips anywhere!
Old 08-11-2013 | 11:56 AM
  #6447
I bet its hairy and swinging for your mouth
Old 08-11-2013 | 11:58 AM
  #6448
no they are not just get new ones from zzp they are not the pricey
Old 08-11-2013 | 12:06 PM
  #6449
BLAZIN07SS's Avatar
I'm too JDM for you
pcv valve has been plugged off as well
Old 08-11-2013 | 12:42 PM
  #6450
werd dawg
Quick Reply: Official Turbo LSJ thread!!!
