Official Turbo LSJ thread!!!
Old 08-12-2013 | 12:20 AM
  #6476
Powell Race Parts's Avatar
Originally Posted by mrbelvedere
there is no way your drain back system can keep the manifold cores 100% oil free unless you plug the head before you get your feathers ruffled I did not say it was a bad system
here is the deal. I have done it. I have the results. You have not. end of this part.
Old 08-12-2013 | 01:03 AM
  #6477
EXsoccer1921's Avatar
So for an engine where the only time it sees boost is when it's making a pass down the track...Vented like the Civics and Supras or sealed with a return to the intake? I've noticed some of the vented setups are vented and returned, check valves in place then? Would it be on the lines from Engine->Can or the return Can->Engine line?
This is an interesting thread.
Oil catch can set up - pic request - EK9.org JDM EK9 Honda Civic Type R Forum
Old 08-12-2013 | 01:47 AM
  #6478
Tjolley's Avatar
Wow guys.
Old 08-12-2013 | 10:37 PM
  #6479
Killa SS's Avatar
Question. I have stg2 turbo cams and only put down 461whp and 383wtq. Im seeing guys with stock cams put down much more tq and bouy the same whp. Whats with that? Im thinking of switching back to stock cams. What do you guys think. Keep stg 2 cams? Why? Or go back to stock cams? Why? Thank ya fellas.
Old 08-13-2013 | 04:06 AM
  #6480
c130aviator's Avatar
In one months time you went from there is no fresh air to there is fresh air.
On the 9th of July... (ttr manifold thread)
lol. the LNF system has a different system with a different rocker cover. The rocker cover on the LSJ is similar but has no fresh air intake. and only one route for the rocker cover vent. At 25 psi, I am guessing you are developing considerable blow by, how much i dont know. And if you have a filtered rocker cover cap, then its all meaningless from a vacuum point of view. LSJ's like to pop dipsticks, thats an indication of compressing in the base of the motor- blow by.
On the 10th of August... (this thread)
so agree or disagree:
the pcv system is used to consume crankcase vapors in the combustion process instead of venting them to the atmosphere. Fresh air from the intake system is supplied to the crankcase mixed with blow by gases and then passed through a calibrated orifice into the intake manifold.
Thw primary control is through the pcv orifice which meters the flow depending on inlet vacuum. The pcv orifice is an integral part of the rocker cover.
if abnormal operating conditions occur, the system is designed to allow excessive amounts of blow by gases to backflow through the crankcase vent into the intake system to be consumed by normal combustion.
The moment you significantly change your engine the requirements will change. If you change the orifice sizes in the PCV system then the system wont function as designed. The best you can say if you mod your car and it runs well, is that it runs well.
So you either learned something in 30 days and are acting like you had it all figured out since racing the Time Attack according to how you addressed MRB. OR you, like most on the forum, dont like to admit you were WRONG.
Old 08-13-2013 | 04:24 AM
  #6481
I had stage 2 cams sitting on my workbench for weeks. I was going to put them in but I searched and made the same assumption you did. I dont drive my car into the 7-8000 range for a daily driver. I believe your cams gave up some torque for horsepower and moved the power band up.
Now with that said, you did put up 461whp on only 21 psi of boost. It took me 26 psi to do that. At 21 psi my car was only making 410whp and 395wtq. So if you look at it from that stand point you gave up 10wtq for 50whp. Good trade off. I know our turbos, mods, head flow, exhaust, etc. are all different and its apples to oranges but I am trying to give some perspective. Dont change anything, get more fuel, more maf, and turn the boost up. You wont care about those cams or the numbers...
Old 08-13-2013 | 05:38 AM
  #6482
Killa SS's Avatar
Yeah. I do shift at 7800 tho so I pull all the way thru. I have the fuel now. I swapped in a dw300 fuel pump and ID1000s. Im still maxxing my maf tho and I cant get around it. Max freq is 12.5k and im nailing that bitch hard. No one has a mini afc I can use. Tim at zzp said they dont work and he doesnt have any ATM. And im being told two diff things that you can and you can't extend the maf scale. Idk which it is.
A few guys I know running turbo 3800s blocked off half of the inlet on there maf to make it see less air and compensated with fuel accordingly so its seeing less air and demanding less fuel but they had to richen it up across the tables to make it idle and drive correctly.
I read that bumping too the larger maf tubes you lose drivibility and I DD my car so I cant be having that
Old 08-13-2013 | 10:20 AM
  #6483
The LSJ has no SPECIFIC SEPERATE FRESH AIR INTAKE COMPARED TO THE LNF. Which is what I
Meant . JUST I DIDN'T EXPLAIN IT WELL. sorry that you are so arrogant you want to dissect every word. Which is why I quoted The WORKSHOP MANUAL FOR DESCRIPTION OF THE PCV S
SYSTEM. You said that statement may or not be true OH WELL
Old 08-13-2013 | 10:30 AM
  #6484
armcclure's Avatar
Lol. I've already received several pm'd from people wanting to do it the right way. Good has been done. Good luck with your car c130.
Old 08-13-2013 | 10:42 AM
  #6485
rico's Avatar
Ill buy cams lmk pm me
Old 08-13-2013 | 11:04 AM
  #6486
noorj's Avatar
Old 08-13-2013 | 11:40 AM
  #6487
mrbelvedere's Avatar
lmao
Old 08-13-2013 | 11:51 AM
  #6488
armcclure's Avatar
lmao
Which cyl is on true tdc @ 10&2
Point being, there's tons of things that you know better than me. Ill easily admit that. Modern pcv is not one of them. I'm done argueing with you about it. I know you're just busting my *****. But come on.
Old 08-13-2013 | 12:56 PM
  #6489
the lsj dose not have a modern pcv system it is using the same tech from the late 60s early 70s
Old 08-13-2013 | 12:58 PM
  #6490
Rockford_Redline's Avatar
I want a hahn s20g for an LNF manifold someone let me know if you've got one for sale. Thanks.
Old 08-13-2013 | 01:02 PM
  #6491
armcclure's Avatar
If you say so. You can plumb your car however you so desire.
And ill set mine up to flush the blowby gasses out instead of just venting.
Old 08-13-2013 | 01:08 PM
  #6492
MrBelvedere, got a hahn 20g?
Old 08-13-2013 | 01:27 PM
  #6493
Old 08-13-2013 | 02:34 PM
  #6494
you can take 2 piles of **** clear coat one of them but in the end you still have 2 piles of ****
your the dude on the rl forums that's k04 crazy
Old 08-13-2013 | 02:35 PM
  #6495
if you could take care of the other side it would be perfect
Old 08-13-2013 | 02:36 PM
  #6496
K04 crazy? I don't have a k04. Do you have a hahn 20g that you'll loan me bro?
Old 08-13-2013 | 04:13 PM
  #6497
I wouldn't waste my time with a Hahn 20g
Old 08-13-2013 | 05:24 PM
  #6498
Well I have an LNF turbo manifold and I'm not wasting my money on a ZFR.
Old 08-13-2013 | 06:50 PM
  #6499
Just to be a db I would argue that point. The 60 and 70's rocker covers DID NOT have PCV pathways with oil seperator biscuits mounted in a mezannine built into the top of the rocker cover. etc.
Old 08-13-2013 | 07:23 PM
  #6500
New valves arrived to day. Kick ass.
Quick Reply: Official Turbo LSJ thread!!!
