Official Turbo LSJ thread!!!
#6502
I would beg to differ they had pcv pathways and oil sep biscuits and they were also built into the valve cover they did not look like what they use today but it was all there one in each valve cover
#6504
no gravy either. just a rocker cover can with a hole in it.is But if you like I take pictures of what I have. you do the same.
#6505
ill have to find some I got rid of all my mopar stuff and they were baffled with a biscuit and with a sep plate to keep the oil from the rockers getting into the intake tract I have seen gm covers done the same way and ford also
ive even worked fresh air systems on 80s stuff also we can go back and fourth all we want but the lsj uses a basic bare bones pcv system that functions and was not different then what was used years ago just because a one of the parts may look different or be in a different spot doesn't make it modern now the new vette pcv stuff may be completely new in how it functions and so fourth and parts and it might be the first actual modern pcv system out
#6508
My good friend Kurt Urban ( Milan LSX shoot out engine winner in MI many times past) told me how he was recently given a tour of a reknowned NASCAR engine builder and it was impressive indeed. Kurt has moved from Michigan to NC.
Kurt would interest you guys, he was the man who did the work assembled the engines etc, on the 1000 hp Ecotec Cavvy drag cars W2W built for Chevrolet.
#6512
You don't have a vacuum source on them right? They are just vent to atmosphere? If so you are not pulling any vapor, oil, or anything for that matter out of the crankcase, that's why they are empty. Running e85 according to some websites has higher water content, you need to vac that stuff out of your engine. If atmosphere (around here) is 14.5 psi it wont overcome that.
#6513
e85 naturally is a gas "de icer" and pulls moisture. Thats why Ethanol has a real bad rap around Marina's. If it was me I would run two seperator in an e85 engine, one for water and one for oil...especially in high humidity areas and with short run cycles of 1.5 miles or so. Short trips are deadly for moisture build up.
#6514
Soo. A vendor on this site told me that using a larger maf tube wont fix my maxing the maf issue and I need an afc. What do you guys have to say about that? And yes i know ive already asked
#6515
I think you need to quit being gun shy and pull the trigger on one or the other. Do some of your own testing and quit relying on reading. There is only so much of that you can do before you just have to find out for yourself. Good luck.
#6516
I ordered the 3.5 maf tube with tall maf from treadstone. Be here friday. Then when ever my tuner gets time :/
#6517
nice, i know all about waiting on a tuner. Its very worth it though. Mine works for a very large dealership that specializes in twin turbo Corvettes and Camaros. They have always got a 2-4 week waiting period to get an appointment.
#6518
Yea mine doesnt do that. Its when he feels like it :/
#6522
Ha. He called me a lil bit ago and said hes sorry for not being around. He said we will work on it when my maf tube gets here and said it still wont help much and I NEED an afc.
He finally agreed to look at ur file and I told him bout adding to the last scale in the maf to read when I max it and he said we can look into it
#6523
Just lmk.
