Official Turbo LSJ thread!!!
Old 08-21-2013 | 04:19 PM
  #6526
SylverSS/SC's Avatar
Now I want poutine you bastards! Lol
Old 08-21-2013 | 06:26 PM
  #6527
BLAZIN07SS's Avatar
I'm too JDM for you
My maf has been maxed forever lol.
Old 08-21-2013 | 07:38 PM
  #6528
USMCFieldMP's Avatar
Rattlesnake Race Shop
How glorious it would be if HPT would unlock all the MAP tables for us so that we could run speed density.
Old 08-21-2013 | 08:16 PM
  #6529
Steviodaddio's Avatar
Rollie, you talking about tight pants tuning your car?
Old 08-21-2013 | 09:09 PM
  #6530
c130aviator's Avatar
I have a 3" MAF and it ran out around 20 something PSI with a boost spike of 24 on a 20g now that is a lower CFM than probably some of the Precision turbos that others are running so that 3" is a bad idea in my option but its one you listed above in the quote. Unless you are on a 20g ( I am doing fine with my 3" MAF tube at 24 psi/440whp).
As for tuning you really need to have someone that is a very trusted tuner. You car is only going to be as good as the person tuning it. My tuner and I (I gave him the research I had done on HPT forums for our cars) made the power enrich table richer at higher rpm.
You command more fuel by enriching the PE(eq) table. It takes this value and divides it by commanded AFR. So you can simply tune around it without screwing with the MAF freq table. That PE table is can be a pain in the butt; however, it can also make your dreams come true.
Originally Posted by ItalianJoe1
More people need to understand this, if you get your MAF dialed in, the rest of the fueling is very simple to adjust. It takes time and patience to get a good, accurate MAF tune, especially on a very heavily modded car (like a turbo swap), but once it's there, you can very simply adjust your target a/f in any range and they will be surprisingly accurate.
The people above to include myself maxed out the MAF (disable the associated out of MAF range CEL) and tuned around it very easily with PE. Killa SS, I hope armcclure or others can help you out. Show your hardheaded tuner this thread and help him learn something.
Old 08-21-2013 | 11:24 PM
  #6531
ItalianJoe1's Avatar
Originally Posted by Killa SS
Ha. He called me a lil bit ago and said hes sorry for not being around. He said we will work on it when my maf tube gets here and said it still wont help much and I NEED an afc.
He finally agreed to look at ur file and I told him bout adding to the last scale in the maf to read when I max it and he said we can look into it
Email me a copy of the tune dude, i'll make some changes.
Old 08-21-2013 | 11:28 PM
  #6532
That's really not necessary though...
You can make the car run nice on a MAF setup if you want and you will always get more accurate closed loop driving behavior with a MAF's ability to compensate for weather changes. SD is easier for straight up power and simplicity, but it's still old-school. Like popping a carb on an LS motor in a swap, might be simple compared to EFI and effective at the drag strip, but not the same.
Old 08-21-2013 | 11:36 PM
  #6533
armcclure's Avatar
Brfps makes this a simple task. Full maf control is nice, but you can work with what you got.
However, above 8192 maf control is a must, s the PE table stops and uses last cell.
Old 08-22-2013 | 12:18 AM
  #6534
Killa SS's Avatar
He won't give me a copy. Its b.s $100 thrown away
Old 08-22-2013 | 03:56 AM
  #6535
BLAZIN07SS's Avatar
I'm too JDM for you
with how highly modified your car is, you really need to invest in your own hpt cable
Old 08-22-2013 | 08:45 AM
  #6536
Killa SS's Avatar
I agree. But he talked mw into lettin hin tune it. It being much cheaper and save my money
Old 08-22-2013 | 11:04 AM
  #6537
Gonna suck when you blow the car up over saving $400 though.
Old 08-22-2013 | 11:22 AM
  #6538
InfraRedline's Avatar
Thats really what it comes down to.
Go find a used HPT cable with a couple credits and snag it up cheap. You will have fun learning which changes do what and you will have support from everyone in here that is trying to help you. Most importantly, you won't have to wonder if your car is running correctly or not, or how safe it is.
Old 08-22-2013 | 11:52 AM
  #6539
mrbelvedere's Avatar
and if you grenade it you only have one person to blame
Old 08-22-2013 | 01:07 PM
  #6540
Killa SS's Avatar
Everyone in here is correct. Ill pick up hpt soon. I dont need a brand new one with 8 credits
Old 08-25-2013 | 06:25 PM
  #6541
Killa SS's Avatar
Just got done washing my car and engine bay. Start car and have eng pwr reduced. Two tps codes. Cleard them and still have p0123. Why would this randomly just go bad? Can I fix it
Old 08-26-2013 | 10:29 AM
  #6542
You got things wet. Take off TB connector and hit it with electronics cleaner and see if the codes come back on.
Old 08-26-2013 | 01:41 PM
  #6543
CCrunner84's Avatar
Yep, the zzp connectors at the tb are not water tight, I packed mine with dielectric grease when it happened to me.
Old 08-26-2013 | 01:43 PM
  #6544
574's Avatar
574
Four more days until startup
Old 08-26-2013 | 02:28 PM
  #6545
I approve of that message ^
Old 08-26-2013 | 05:07 PM
  #6546
Killa SS's Avatar
Yea I did just that too haha thanks tho. I need a damn afc and zzp wont sell me one :/
Old 08-26-2013 | 05:22 PM
  #6547
Killa SS's Avatar
My gauges are doin funky ****. Turned car off and needles are bouncing around at the bottom of the gauge. Wth?
Old 08-26-2013 | 06:08 PM
  #6548
rivaladore's Avatar
My car does that every once in a while since I've owned the car. Don't worry about it
Old 08-26-2013 | 06:21 PM
  #6549
jonathan923's Avatar
all these cars do that its normal lol its usually about a minute when you turn off the car
Old 08-26-2013 | 07:58 PM
  #6550
Killa SS's Avatar
Ok. Just something I noticed after sitting in the car for a bit after turning it off. Also does anyones car take a sec to actually stop running once you turn the key off? I think its normal. With the heavy flywheel keeping the momentum and the alt supplying juice still. Idk tho.
Quick Reply: Official Turbo LSJ thread!!!
