Official Turbo LSJ thread!!!
Old 08-27-2013 | 05:58 PM
  #6576
InfraRedline's Avatar
Cool, just let me know Rob.
Old 08-28-2013 | 12:20 AM
  #6577
armcclure's Avatar
I'm pretty sure ZZP uses a Solstice Alt because it shares the same plug as the LSJ/LNF. My recommendation would be to just find and use an LNF Alt... I'm pretty sure they have a higher output than the 2.2 alt, as well.
The LSJ/LNF plug and the 2.2 plug are NOT the same.
I'll go check my wiring though, as I did my swap when it was next to impossible to find an LNF Alt, so I used the 2.2 Alt.
EDIT: the stock wiring on my car is a Red (+) and Grey (GND?) wire.
If you place the new plug on a flat surface so that the "Release Lever" is on top... the Right wire is connected to the Red Wire. Once plugged into the Alt... that would put the Red Wire on bottom.
Aaahhhh.... Good to know
Old 08-28-2013 | 12:41 AM
  #6578
c130aviator's Avatar
i bought my LNF alternator from mongorat (the parts guy on this forum) for 50 bucks. Sold my LSJ alternator for 50 bucks. Net cost - free.
if you are internet shopper savvy the part number for the LNF alt is 20862828
Old 08-28-2013 | 08:52 AM
  #6579
armcclure's Avatar
How about the pn for the lnf bolts lol
Old 08-28-2013 | 10:22 AM
  #6580
take a stock bolt and match the threads at a hardware store then order proper length socket head bolts
Old 08-28-2013 | 11:23 AM
  #6581
armcclure's Avatar
I was just kidding. Ill measure and order at work. Just take stock bolt and subtract bracket thickness.
Old 08-29-2013 | 03:19 PM
  #6582
Laser_Blue's Avatar
My car has been giving me a lot of problems. Lol. I just finished my turbo swap about a month ago. Been at my tuners house for the whole month. First the TB went out, broke the intake map sensor. Replaced both now I'm my wot is at 4k and surging at idle.
Old 08-29-2013 | 09:59 PM
  #6583
takes time man. not at you but people think they can throw a turbo togther, maybe even an engine build and its no big deal. It takes time to get things worked out. Its not considered a bolt on like a pipe on an LNF would be. Turbo, tuning, etc takes time to find the problem, troubleshoot the problem, fix, and repeat. I have about 4 months into my built motor and another 4 months in tuning, boost leak fixes, tuning, etc. I have had my car for about a year and I have only been enjoying 400+ hp for only a few months out of that year. I can tell you though its worth it. My car couldnt be running better right now. I have 3000 on newly built engine, turbo, and a few other things and I could not be happier with the wheel spin and blow off valve noise around people who think they are fast. Just the other day I had an STI guy stop me at the BX and told me about how he was making 300+ whp. Then I showed him my glovebox full of dyno sheets. His look was priceless.
Old 08-30-2013 | 05:18 AM
  #6584
Laser_Blue's Avatar
Thanks man. I've done about 1 1/2 pull in it and it was amazing. Hearing the full spool and bov going off then boom a backfire. Lol. It's gonna be fun I'm just thinking of the future of that car. Can't wait to drive it around freaking people out.
Old 09-01-2013 | 04:05 PM
  #6585
574's Avatar
574
Catless+E85 SMELLS SO GOOD
Old 09-01-2013 | 06:24 PM
  #6586
EXsoccer1921's Avatar
Let's keep the bickering and dick measuring professional yeah?
Old 09-01-2013 | 06:30 PM
  #6587
mexi_loco's Avatar
Thank you...pickle ******
Old 09-02-2013 | 07:46 PM
  #6588
Killa SS's Avatar
Who here has the fuel pump re wire kit? I need to know what fuse they used for the inline fuse and what size wire they use as well
Old 09-02-2013 | 07:49 PM
  #6589
mexi_loco's Avatar
I believe Mark has the rewire kit on his car.
Old 09-02-2013 | 07:55 PM
  #6590
And I am unable to look at it, so I'm no help.
Old 09-02-2013 | 07:56 PM
  #6591
Killa SS's Avatar
Aww poop
  #6592
armcclure's Avatar
  #6593
Killa SS's Avatar
Ahhhh
Old 09-02-2013 | 08:08 PM
  #6594
mexi_loco's Avatar
just looked on zzp and unfortunately they don't have anything on their site. you could try emailing them though.
Old 09-02-2013 | 08:10 PM
  #6595
BLAZIN07SS's Avatar
I'm too JDM for you
It's 12 gauge wire. as for the fuse, I couldn't tell you. check what the pump will draw at max. I wouldn't think more then 20 amps
Old 09-02-2013 | 08:18 PM
  #6596
Killa SS's Avatar
Thank you sir!!! Il throw a 20 in there. Im making my own re wire. Soo much cheaper
Yea I had already looked there as well. :/
Old 09-02-2013 | 08:20 PM
  #6597
Killa SS's Avatar
Old 09-02-2013 | 08:40 PM
  #6598
574's Avatar
574
Guys will Hahn intake manifold, what did you mount your dipstick to?
Old 09-02-2013 | 09:57 PM
  #6599
BLAZIN07SS's Avatar
I'm too JDM for you
nothing, you bend it and run it up between the runners
when i used to have the hahn manifold:
Old 09-03-2013 | 10:25 AM
  #6600
Viceversa10's Avatar
Alright i need a little input from you turbo lsj's. I currently am in the middle of building my LSJ-T and am stuck between 2 different turbos. the gt2871r and the gt3071r Both would be .64a/r with a t3/4.
I'm looking to make around 350whp. Has anyone got any experience with these two turbos? Just want to see if anyone has numbers on a balt for them. They both seem to be full spool by 3800rmp ish.
Quick Reply: Official Turbo LSJ thread!!!
