Official Turbo LSJ thread!!!
#6876
It should be close, but might not be in the exact same location. Also, you will need a 2.4 TB and harness adapter I believe. And I have a passport, but both cars will be down probably and the 92 Dakota probably wont like the long road trip Also we have our work appreciation event that night.
#6883
#6885
Probably not gonna happen your first time out lol so don't be disappointed. Big turbo setups are much more difficult to learn from a dig, and you'll need a good suspension setup. Will the car have it in it power wise? Sure, but the rest is on you and the setup.
#6892
#6897
No that was after I got used to launching the car on those tires. Just a 2.0 60'. I still haven't been able to turn the car up past 20psi. The only time it's been above that was the night when I first picked it up in '11 on the 62mm. After that night I turned it down and ran pump gas. Then the bearings didn't like that so I put a new motor in it and went with the 58mm .55a/r and 110 gas. Once I did that though the season was over so I hardly drove it. Then I did some powder coating and took everything apart and it sat. Then the transmission issue and it's still been sitting. Haven't drove it since February and haven't made a pass since September of last year.
#6898
Im hoping I can see 10s on this 256et. If not. 6262 :p
Once balt sees 10s. Modding the bike begins!! Ima turbo my 1000rr
#6900
