Official Turbo LSJ thread!!!
Old 10-17-2013 | 09:26 AM
  #6901
mrbelvedere's Avatar
I see a lot of hopes and dreams
Old 10-17-2013 | 10:57 AM
  #6902
armcclure's Avatar
Hey, that's what 87% of the cars here run on
Old 10-17-2013 | 01:12 PM
  #6903
lol
Old 10-17-2013 | 04:08 PM
  #6904
Killa SS's Avatar
We wouldn't have anything in life if we didnt have hopes and dreams for something
i see everyone around you stretched there bikes over the last few days lol. but get those 10's done
Yup all those slow bikes :p
Old 10-18-2013 | 08:31 AM
  #6905
bmxracerchamp12's Avatar
ill take my low and slow on my bike lol
Old 10-19-2013 | 01:55 AM
  #6906
Killa SS's Avatar
A few sick races tonight. 1200whp twin turbo vette vs a turbo busa and a 2.3 whipple term vs gtr full bolt ons and e85. Rode in the vette. ****** nasty
Old 10-19-2013 | 11:08 AM
  #6907
armcclure's Avatar
Lolololololl that's some 1320video stuff right there!
Old 10-19-2013 | 11:32 AM
  #6908
jakeLSJs2's Avatar
Can anyone tell me where to run my MAF sensor on my lsj turbo swap?
Old 10-19-2013 | 11:49 AM
  #6909
574's Avatar
574
I already did in the thread you made.
And, because I'm whoring it out... https://www.cobaltss.net/forums/feat...-fcotm-303499/
Old 10-19-2013 | 12:45 PM
  #6910
armcclure's Avatar
The depend entirely on your desired setup. I'm running a pull through setup, unlike boat on here. But This allows me to run a 3.75" maf housing without disrupting airflow, as well as keeping the w/m off of the sensor.
Old 10-19-2013 | 01:03 PM
  #6911
Killa SS's Avatar
Talk about fun finding the boost leak if u get one.
Its some where post maf.... fuucxccc
It was a blast!!
Old 10-19-2013 | 05:37 PM
  #6912
armcclure's Avatar
How would draw through maf have any effect on that.
I have only 2 couplers. There's very few places it could possible leak.
Old 10-19-2013 | 07:23 PM
  #6913
jakeLSJs2's Avatar
Nope, not seeing anything about it.
Where do you have the maf sensor?
Old 10-19-2013 | 07:58 PM
  #6914
noorj's Avatar
arm what bypass valve do you use on your setup? I was thinking about switching to a draw thru
Old 10-19-2013 | 10:06 PM
  #6915
armcclure's Avatar
Haven't decided. I have both an hks ssqv with recirc fitting and a zzp 50mm.
I've been doing a lot of research and a bov on a draw through setup CAN be tuned around with ltft boundaries and dfco, along with smart driving (I.e. not being a tool and blowing off every chance you get). Ill give it a try if the ssqv doesn't flow enough.
For a DD I would recommend a full recirc or maybe a turboxs hybrid.
Old 10-20-2013 | 06:50 PM
  #6916
Killa SS's Avatar
Oh yea. Straight too t.b. setup. Right?
Old 10-20-2013 | 08:20 PM
  #6917
armcclure's Avatar
Yessum. 1/4 the volume of tubing to fill compared to a "standard" setup.
Old 10-21-2013 | 12:55 PM
  #6918
InfraRedline's Avatar
Even if you were running a standard setup, it wouldn't make any difference in difficulty when pressure testing the system. Just like any factory turbo car that uses a draw through setup.
Old 10-21-2013 | 01:10 PM
  #6919
armcclure's Avatar
Right. Not worried about it. Ill probably have to bring VE back into the tune to get a stable idle with the 3.75" maf but nbd. Running draw through gives me 3 main benefits:
1) I can run a large maf housing that smoothly tapers down to the compressor inlet.
2) I can run a metric crapload of w/m without worrying about it getting on the maf or pooling in an intercooler.
3) PCV plumbing is WAY simpler and will be much more effective; I will have vac on the case even at 30psi.
  #6920
574's Avatar
574
Just bought a brand new set of zzp #82's for $200
Old 10-21-2013 | 10:58 PM
  #6921
conerboner's Avatar
It should be close, but might not be in the exact same location. Also, you will need a 2.4 TB and harness adapter I believe. And I have a passport, but both cars will be down probably and the 92 Dakota probably wont like the long road trip Also we have our work appreciation event that night.
I have a 2.4 tb on my 2.2 already so i can just put my stock one back on and take that one.
Old 10-25-2013 | 06:54 PM
  #6922
smitzk01's Avatar
Hey I have a few questions about turbo swapping. I've read a little of this thread but I just want a few specific answers and I haven't found the answers yet. I have a stock LSJ engine, meaning I have a stock top and bottom. I am looking at getting a s256 ET turbo kit. What are my limitations? What would my limitations be if I put just valve springs in? I understand turbo cams would help out but at what point is the bottom end just not strong enough? Or is there simply no way to avoid destroying the engine? I know people run these on stock engines so what are some numbers you are running and for how long?
Old 10-25-2013 | 06:55 PM
  #6923
armcclure's Avatar
Hey Jon, care to chime in?
Old 10-26-2013 | 09:15 AM
  #6924
jhaddock21's Avatar
I made 508whp 445wtq on the stock longblock with a s256et on 28psi and e85.
Old 10-26-2013 | 10:01 AM
  #6925
jakeLSJs2's Avatar
Just finished up my LSJ turbo swap and was wondering if i have compressor surge and how you guys routed your bov. I have a line come off the intake manifold down to the top port of my bov. Where do i need to connect the bottom port of my bov?
Quick Reply: Official Turbo LSJ thread!!!
