Official Turbo LSJ thread!!!
Old 10-26-2013 | 10:31 AM
  #6926
smitzk01's Avatar
Originally Posted by jhaddock21
I made 508whp 445wtq on the stock longblock with a s256et on 28psi and e85.
For how long though?
Old 10-26-2013 | 11:35 AM
  #6927
jhaddock21's Avatar
I've only put maybe 1500 miles on the car since it's been turbo swapped. I only drive it maybe once or twice a week but they're are a few guys on here running around the same power level for awhile with no major problems. It all depends on the tune and how you drive it.
Old 10-26-2013 | 01:20 PM
  #6928
BlkWdoSS's Avatar
If anyone sees some ID1000s or 2000s for sale let me know, needing to source some for the rebuild
Old 10-26-2013 | 02:02 PM
  #6929
CCrunner84's Avatar
Originally Posted by jakeLSJs2
Just finished up my LSJ turbo swap and was wondering if i have compressor surge and how you guys routed your bov. I have a line come off the intake manifold down to the top port of my bov. Where do i need to connect the bottom port of my bov?
Cobalt lsj turbo swap - YouTube
Compressor surge is WOT cha-cha-cha, you have BOV flutter. Not sure what you have, might need a different spring, or lessen the pre-load on the spring if it's something else.
Old 10-26-2013 | 02:09 PM
  #6930
noorj's Avatar
BOV flutter causes compressor surge
Old 10-26-2013 | 06:52 PM
  #6931
smitzk01's Avatar
Thanks man. 500 was at the tip of my top end goals for this stock engine. I drive it all summer as of now but knowing I should easily achieve 400 makes my decision with where to go from here a lot more clear.
Old 10-28-2013 | 04:05 PM
  #6932
574's Avatar
574
I'll just drop this here
https://www.cobaltss.net/forums/fron...thread-303766/
Old 11-01-2013 | 06:30 PM
  #6933
smitzk01's Avatar
Let's all hope ZZP will do a 50% turbo lsj kit with choice in upgrades. Ran a leak down test on my cylinders, all were around 5%. Compression test showed 150&175psi on cylinder 1, 145&175psi cyl 2, 130&180psi cyl 3, 140&170psi cyl 4.
Old 11-01-2013 | 06:46 PM
  #6934
armcclure's Avatar
Dry/wet?
Old 11-01-2013 | 08:28 PM
  #6935
BlkWdoSS's Avatar
would you go in dry? I always fear damaging my tool by jamming it in dry
wet is the only way to go in
on another note, considering a 50 shot to get my spool time down once my car runs again
Old 11-01-2013 | 08:37 PM
  #6936
EXsoccer1921's Avatar
Or a smaller turbo
Old 11-01-2013 | 08:44 PM
  #6937
574's Avatar
574
What turbo is he running?
Old 11-01-2013 | 08:46 PM
  #6938
366 with either a .70 or .82 a/r I can't remember.
Old 11-01-2013 | 08:58 PM
  #6939
574's Avatar
574
Damn thats a daddy turbo
Old 11-01-2013 | 09:01 PM
  #6940
Yeah I thought my 62mm on a .70 housing was bad. His is ridiculous. But he hasn't given up yet and has some pretty cool stuff so I'm curious as to how it'll go.
Old 11-01-2013 | 09:04 PM
  #6941
574's Avatar
574
I wish people like that would make build threads. Thats the cool stuff to see. Enough with what exhaust and pulley threads
Old 11-01-2013 | 11:41 PM
  #6942
armcclure's Avatar
I wish I had the room to do compound
Old 11-02-2013 | 03:37 AM
  #6943
You do.
Old 11-02-2013 | 11:20 AM
  #6944
BlkWdoSS's Avatar
Ask and ye shall receive...
https://www.cobaltss.net/forums/feat...-fcotm-266086/
not an actual build thread but has most parts on the car listed and a few pics
the turbo itself is a 66mm , I am running a quick spool valve to shorten spool times, I would be more active on here but my car has been down for a year and a half getting the motor rebuilt, plans for it are:
custom cams from Comp Cams
built head
ID1000s or 2000s (depending on budget)
port and polish head
balance shaft delete (already complete)
GMR bearings
ARP head studs
Diamond pistons (coated)
Pauter X-beam rods
extended crank key (Mr. Belvedere)
Sleeves (Mr. Belvedere)
machined, knife edged, micro polished and ceramic coated crank
redesigned oil pan for turbo drain
Custom PCV system with Mishimoto catch can
Mishimoto Radiator
and much more....
Old 11-02-2013 | 01:37 PM
  #6945
armcclure's Avatar
Originally Posted by Drivetrain Solutions
You do.
How so? If you're talking about a rear mount, no thanks.
And unless you get your sawzall out and attack the front, no room there either.
I know if I went radical it would be possible. I was talking about fitting it all in the engine bay.
Old 11-02-2013 | 01:38 PM
  #6946
armcclure's Avatar
built head
GMR bearings
ARP head studs
Pauter X-beam rods
Mishimoto Radiator
and much more....
I'd recommend these. Better spray pattern and they're the same core as ID's
http://fuelinjectorconnection.com/sh...?productid=191
Old 11-02-2013 | 02:04 PM
  #6947
574's Avatar
574
Would I be better off with something like that?^^ or a BRFPS and surge tank?
Old 11-02-2013 | 03:02 PM
  #6948
smitzk01's Avatar
Dry/wet?
I don't know if this was for me?
Old 11-02-2013 | 03:22 PM
  #6949
armcclure's Avatar
You're gonna need more pump regardless.
Yes. How'd you get 2 drastically different results?
Old 11-02-2013 | 04:06 PM
  #6950
BlkWdoSS's Avatar
FUEL INJECTOR CONNECTION - 160lb FIC FLOW MAX FUEL INJECTORS
Ive never heard of those, but they seem like very good injectors, may consider going that route, price is definitely right, thanks
I was after the IDs because of tunability, if these can be tuned to idle and act right then they could work
Quick Reply: Official Turbo LSJ thread!!!
