Official Turbo LSJ thread!!!
Old 12-03-2013 | 10:14 AM
  #7126
ItalianJoe1's Avatar
Originally Posted by noorjariri
increased timing advance cools egts
To a point, yes. Not so much if you are already running pretty solid timing. Retarded timing is where you see greatly increased EGTs due to left over fuel.
Old 12-03-2013 | 10:21 AM
  #7127
noorj's Avatar
unless your at the knock limit adding advance will always decrease EGT, let me see if I can find my source
edit:
http://dspace.mit.edu/bitstream/hand.../676953430.pdf
http://www.sid.ir/En/VEWSSID/J_pdf/856200801B07.pdf
http://www.birmingham.ac.uk/Document...-si-engine.pdf
First one is a great read for LNF guys
Old 12-03-2013 | 12:53 PM
  #7128
edit:
I didn't disagree with you???
Point is, you benefit from running as much timing as you can run without detonation. This isn't a recent discovery
Old 12-03-2013 | 02:00 PM
  #7129
Area47's Avatar
Rent me! per hour
hi. welcome to 1995.
Old 12-03-2013 | 02:24 PM
  #7130
noorj's Avatar
not sure where that came from. But my point is that the cooled EGTs of ethanol allow leaner lambda ratios to be run and knock iat points to be higher, not that the lower combustion temp allows you to run more timing. which is what you initially had said
Old 12-03-2013 | 03:50 PM
  #7131
Area47's Avatar
Rent me! per hour
most of your monkeys on this forum have never seen and egt gauge let alone used one.
Old 12-03-2013 | 03:53 PM
  #7132
InfraRedline's Avatar
Thank you for sparking my memory. Need to order a new bung to weld into my turbo manifold for my defi egt gauge. Couldn't really just cut the old one out of the header when I sold it
Old 12-03-2013 | 03:55 PM
  #7133
Lol I was thinking that but didn't want to say it. People love to read and preach. I am going on personal experience on a car I converted to E85 that has an EGT installed in the dash permanently. Added boost, added timing, added fuel, saw changes. That's what matters to me.
Lol, small hole saw and just tell the guy buying it that it's for an O2 bung?
Old 12-03-2013 | 04:27 PM
  #7134
zrated89's Avatar
css = so many
Old 12-03-2013 | 04:35 PM
  #7135
Well I sold it to my friend who bought my TVS as well so there would have to be some serious convincing skills
Old 12-03-2013 | 05:44 PM
  #7136
armcclure's Avatar
If people actually used egt's, they stop the **** and moan about intake temps on e bs.
Old 12-03-2013 | 05:47 PM
  #7137
noorj's Avatar
you know what assuming does
Old 12-03-2013 | 06:31 PM
  #7138
Wasn't directed at you. Calm down.
Old 12-03-2013 | 06:41 PM
  #7139
BlkWdoSS's Avatar
wrong
not wrong, all metal intakes touching a metal head will heat transfer period . e85 isnt going to change the operating temperature of your engine, if it operates at 180* the head will still see temps similar and will transfer those to your intake manifold.
I leaned out once on gas, melted valves instantly, rebuilt my block, leaned out again and popped my cylinder.
Leaned out on E85, after my third engine build, pull after pull and never had the searing heat issues I did with gas. Its just safer if you plan on tinkering and testing.
your searing heat issues I would blame on tuner, and your car warned you prior to it leaning out in a split second and then dead motor, you had other issues. I have pushed my EGTs up over 1600* to decrease spool time (and that is a bone stock LSJ) and when I got the spool I wanted I left it there. 1300-1600* in the mid range run after run after run, daily drove it for more than 6 months that way
We aren't making anyone run this fuel, just have an open mind about it. I spend too much time on cruise night pleading my case convincing the older local car guys about it because they say "that **** will dry out your engine, yep your just ruining your motor". Now I just drive by and smile and pat my car on the door when I see them. 4+ years on E85 and 3+ years on a small pulley TVS not being easy on her.
On another Black Friday related note, I made some purchases from ZZP for my Red car F40 6-speed setup and s259et will be on its way! Snagged an oversized radiator as well.
I know you arent making me run this fuel, hence I havent bashed any of you guys that are running it, I just simply explain my opinion on the matter and what I would do if I did decide to run any form of alcohol based fuel. I respect all of you guys that make big power on it, I just ask for the same respect for me running pump gas.
Well, it's not that simple. But I guess I better let that one go since I'm apparently "over-complicating" things..
keep over complicating things, I enjoy reading and learning exactly how something works instead of "um , I pour it in my car and , um , it goes faster and , um , yea" Learning what works and doesnt work helps to further what we are all doing and keeps us from wasting money on parts that break or directions that are unnecessary.
Old 12-03-2013 | 06:45 PM
  #7140
BlkWdoSS's Avatar
EGT was the second gauge I bought after wideband
  #7141
Powell Race Parts's Avatar
^^^^this. ^^^^an d previous above it lol
pump gas for me. 94.
its got ethanol in it. 10%. o well. car runs fine
egt? I got 'em. I see 1700-1800 on track or at 150 mph continuous. s'alright/s'ok
Old 12-03-2013 | 06:46 PM
  #7142
noorj's Avatar
damn that's impressive, I'm shitting my pants when I pull thru 4th and see 1200*. stupid LE5
Old 12-03-2013 | 06:47 PM
  #7143
BlkWdoSS's Avatar
thanks, if I kept temps near 1k my lazy ass turbo would never spool, pushed it as hot as I could get it
Old 12-03-2013 | 06:48 PM
  #7144
SylverSS/SC's Avatar
I'll be putting an egt in my manifold as I learned from diesels on the farm. Monitoring everything is always a good idea
Old 12-03-2013 | 06:49 PM
  #7145
BlkWdoSS's Avatar
What gear are you in at 150mph? My 4th gear at 7200rpm shows 152mph on the dyno
Old 12-03-2013 | 07:01 PM
  #7146
Originally Posted by blkwdoss
what gear are you in at 150mph? My 4th gear at 7200rpm shows 152mph on the dyno
5th. 4.45. I aint looking for 2 mph its a freaking redline with the speedo in the passenger compartment. I use gps and look at it after.
Old 12-03-2013 | 08:06 PM
  #7147
BlkWdoSS's Avatar
I wouldnt know how fast mine is lol, I just see it in the logs after, was just getting an idea of what gears you would see on a road course at those speeds
Old 12-03-2013 | 08:09 PM
  #7148
BLAZIN07SS's Avatar
I'm too JDM for you
just because we haven't had a picture in here for awhile
Old 12-04-2013 | 03:05 PM
  #7149
Area47's Avatar
Rent me! per hour
blkwdo. didn't your **** go blamo.
Old 12-04-2013 | 05:53 PM
  #7150
BlkWdoSS's Avatar
yep who told ya?
Ive been working on rebuild.
I have:
Diamond Pistons (stock compression, coated)
Pauter x-beam rods
knife edged and coated crankshaft (waiting to get crank key extended)
160lb/hr injectors
still need:
block to get sleeved by mr. b
head to go to M2
order cams springs and valves
then its just reassemble tune and run
Quick Reply: Official Turbo LSJ thread!!!
