Official Turbo LSJ thread!!!
Old 12-04-2013 | 05:59 PM
  #7151
574's Avatar
574
I forgot about the extending crank key. Whats the point in that again?
Old 12-04-2013 | 06:59 PM
  #7152
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by BlkWdoSS
yep who told ya?
Ive been working on rebuild.
I have:
Diamond Pistons (stock compression, coated)
Pauter x-beam rods
knife edged and coated crankshaft (waiting to get crank key extended)
160lb/hr injectors
still need:
block to get sleeved by mr. b
head to go to M2
order cams springs and valves
then its just reassemble tune and run
what in the hell do you need 160lb/hr injectors on pump gas for
Old 12-04-2013 | 09:44 PM
  #7153
BlkWdoSS's Avatar
The stock woodruff key only connects with the harmonic balancer by about 1/4" meaning that if you twist the end of the key off that the harmonic balancer wont spin. No harmonic balancer then no oil pump. Cut a longer key in it so that you get much more bite and less likely to fail.
for this:
back before god blessed you all with e85, ppl were using big injectors and pump gas, Ive known several DSMs and Evos back in the early 2000s running 1200cc + injectors with 105 and making 650+awhp.
Old 12-04-2013 | 10:05 PM
  #7154
BLAZIN07SS's Avatar
I'm too JDM for you
exactly, so what do you need 1,680cc of injector for on pump gas
Old 12-05-2013 | 07:13 AM
  #7155
armcclure's Avatar
So that he (most likely) doesn't have to worry about them ever again.
Old 12-05-2013 | 12:33 PM
  #7156
574's Avatar
574
I got 99 problems and fuel is one
Old 12-06-2013 | 08:47 PM
  #7157
BlkWdoSS's Avatar
^^^ this guy, he gets me lol
I lol'd
Old 12-08-2013 | 08:42 PM
  #7158
evil ss's Avatar
Ok so I'm looking at putting my own kit together over the winter and have a few questions. I'm going to be using a k04+ turbo that I already have and am looking for options on what manifold I can use, I was looking at the zzp one but it says it's only meant for the bullseye t3 turbos. Also what flange is on the k04, I've tried searching but can't find the specs on it. My last question would be the charge piping, I was looking at the zzp kit also for this(mainly for sake of one stop shopping) but says it's also for the bullseye and there manifold and the Saab intake which I was going to use but should it fit the k04 and could it still fit with a different manifold also or would it cause more fit meant issues then it's worth?
Old 12-08-2013 | 08:48 PM
  #7159
574's Avatar
574
I could answer questions, but I'll tell you this instead. You don't want to run that K04 turbo
Old 12-08-2013 | 08:54 PM
  #7160
evil ss's Avatar
Why wouldn't I want to use the k04? I'm not looking to make a ton of power just bring the car back to life, I'm still m62 with just over 100k so I'm just board with where the car is at now
Old 12-08-2013 | 08:56 PM
  #7161
574's Avatar
574
You will get bored with the K04 really quick. Will the car be on E85?
Old 12-08-2013 | 08:58 PM
  #7162
evil ss's Avatar
E85 isn't around my area so it would be on meth injection instead
Old 12-08-2013 | 09:03 PM
  #7163
574's Avatar
574
Yeah... I really wouldn't do the k04 then. I'll let other guys chime in so you can see I'm not loony toons
Old 12-08-2013 | 09:17 PM
  #7164
BlkWdoSS's Avatar
F*ck no on the k04, way too small for an LSJ, its a nightmare to tune, spools up way too low on the RPM band and falls flat on its face before you get above 5500rpm. LSJ head flows better than LNF, get a properly sized turbo.
k04 wont get you anywhere, If you are dead set on that turbo then just save your money and keep the m62, you will make similar power.
Old 12-08-2013 | 09:21 PM
  #7165
evil ss's Avatar
Not so much dead set on it just already have it. So I guess I'll just save a little more and get a full kit and I'll use the k04 as an upgrade to the daily's k03 then haha
Old 12-08-2013 | 09:27 PM
  #7166
BlkWdoSS's Avatar
what is your daily? seems like a much better plan, Ive helped with a few k04 installs on LSJs and the operator is never fully satisfied with it, they typically start shopping for a bigger turbo before we even finish tuning the car.
Old 12-08-2013 | 09:28 PM
  #7167
evil ss's Avatar
2014 gti, but I guess I should start looking into kits then and just make my life easier
Old 12-08-2013 | 09:50 PM
  #7168
574's Avatar
574
Nothing wrong with piecing a kit together
Old 12-09-2013 | 01:18 PM
  #7169
bmxracerchamp12's Avatar
i am piecing my own together. then i decided i want to upgrade before it ever gets installed....
Old 12-11-2013 | 06:46 PM
  #7170
Axelthered05's Avatar
im not sure if this has been coverd yet in this thread but is anyone useing the cams from the turbo Saab 9-3 with their turbo setup? I would like to know how seting the timing went/was done and how it runs
Old 12-11-2013 | 09:05 PM
  #7171
armcclure's Avatar
That is an enormous pita for little to no gain.
  #7172
BlkWdoSS's Avatar
havent seen that, are they different from LSJ cams?
Old 12-11-2013 | 09:08 PM
  #7173
574's Avatar
574
I heard they are more of a turbo grind but as Alan said, if your gonna do a cam swap do one that will pick up some power
Old 12-11-2013 | 09:17 PM
  #7174
BlkWdoSS's Avatar
LSJ cams are turbo cams lol, at least more setup for turbo than for supercharger
Old 12-11-2013 | 09:23 PM
  #7175
574's Avatar
574
Speaking of turbo cams, I wish I woulda got stage 3 instead of 2
Quick Reply: Official Turbo LSJ thread!!!
