Official Turbo LSJ thread!!!
Old 12-11-2013 | 09:33 PM
  #7176
BlkWdoSS's Avatar
Custom is the route to go, Ready to work with Comp on mine
Old 12-12-2013 | 08:10 AM
  #7177
armcclure's Avatar
You'll be fine for the most part.
At low boost levels, desired turbo and sc cams will be similar. As you approach pressure equilibrium, which is different for each turbo, desired cam profile leans more toward an NA cam. Beyond that, when running high boost, that's where reverse splits come in.
Nick, yours are more suited (IMO) for moderate boost, but will still do much better than stock at high boost levels.
Long story short, when someone says a turbo cam is a turbo cam, I el-oh-el.
The guys at comp are VERY good, and will work with you on a grind specific to your desired setup. Mine are spec'd out, I just haven't sent the blanks in yet. Iirc they're 264/262, 224/222@0.050, .453/.456, on a 112.
Old 12-12-2013 | 09:53 AM
  #7178
InfraRedline's Avatar
Mine are the s2's as well, although they will still hit my goals. I'll probably have to run somewhere in the high 20's for boost, which I'm fine with.
Old 12-12-2013 | 04:18 PM
  #7179
i944scania's Avatar
can anyone help me out?? ive got a strange problem and i cannot figure out whats going on with my turbo swap. Others dont seems to know whats wrong either.
PM me if you can help, i didnt wanna jack the turbo swap forum
Old 12-12-2013 | 04:30 PM
  #7180
armcclure's Avatar
Posting here is fine. That's what this thread is for
Old 12-12-2013 | 04:41 PM
  #7181
i944scania's Avatar
my car has a hesitation, the more boost i run. i can run 12 psi or so and rev the engine all the way out. if i try to run 20psi like i want, rpms get slower around 5500 and stop near 6k. The engine sounds terrible and sputtery.
upon tuning, we noticed at that higher boost, the MAF Hz start to quiver and eventually drop ( in the 5500-6k range)
Old 12-12-2013 | 04:44 PM
  #7182
i944scania's Avatar
-to4e 50 trim with .63 turbine
-2.5" catless exhaust
-#60s
-3" intake, lsj intake manifold with zzp adaptor plates
-turbonetics deltagate with new 9-13psi spring, voodoo boost controller
-step colder ngk-r .028 gap
I talked with zzp about the issue. they assured me that the lsj intake manifold was fine.
they think its a stuck lifter or bad coil? even when i told them its directly maf related
Old 12-12-2013 | 05:02 PM
  #7183
Area47's Avatar
Rent me! per hour
spark blow out. drop the gap till it stops.
Old 12-12-2013 | 05:04 PM
  #7184
i944scania's Avatar
do you think?? im at .028! am i getting too small now?
Old 12-12-2013 | 05:08 PM
  #7185
BlkWdoSS's Avatar
Your knocking... run a better fuel or decrease timing
Axelthered05, you need a bigger turbo, cams wont help much, the k04 is running out of wind before you get to 5k rpm
Old 12-12-2013 | 05:13 PM
  #7186
i944scania's Avatar
im not knocking. we tuned the car, no knock even when it starts to sputter. without any added timing, still no knock when it does.
so detonation is out of the question
Old 12-12-2013 | 05:15 PM
  #7187
BlkWdoSS's Avatar
its not out of the question, if you have a dead knock sensor then you wont see KR but you will be knocking, have you ohm'd the sensor?
Old 12-12-2013 | 05:21 PM
  #7188
i944scania's Avatar
not throwing a knock sensor code and doesnt seem to knock at any other rpm. but possibly.
I have not checked the resistance, seems to behave at other airflow numbers
Old 12-12-2013 | 05:22 PM
  #7189
i944scania's Avatar
what do you think i should try? currently gapped at .028, dropping from .030 i saw little positive change in the issue.
Old 12-12-2013 | 06:06 PM
  #7190
BlkWdoSS's Avatar
ok, well good luck...
Old 12-12-2013 | 07:16 PM
  #7191
i944scania's Avatar
thanks for the advice! ill keep it in mind. Im just going to try plugs before working with knock since our logging didnt show any
Old 12-12-2013 | 09:02 PM
  #7192
armcclure's Avatar
Have your tuner out misfires in the scanner. They should have been there already. Could be a coil as well since you're at a 28 already.
Everything points to blowout. Trace it down, fix it up
Old 12-12-2013 | 09:32 PM
  #7193
i944scania's Avatar
it feels like a wicked bad blowout. i hate to test if ive fixed it! car gets nastyy.
If i let it rev to the point where it starts to freeze up, usually i get a CEL for misfire but its the random code, not specific to any cyl
Old 12-12-2013 | 09:41 PM
  #7194
noorj's Avatar
are the plugs the bkr7e?
Old 12-12-2013 | 09:48 PM
  #7195
i944scania's Avatar
yep! theyre in good shape. plugs have good color on them when i went to regap
Old 12-12-2013 | 09:54 PM
  #7196
noorj's Avatar
whats the wideband do when this happens?
Old 12-12-2013 | 10:02 PM
  #7197
i944scania's Avatar
I cant remember exactly what my wideband said when we tuned, it was weeks ago.
But i do remember that it was still getting pletly of fuel, according to the HP software.
The only thing that happend was we noticed a big change in the MAF freq.
Old 12-13-2013 | 07:13 AM
  #7198
armcclure's Avatar
Do you have a scan? What exactly was the maf doing?
Old 12-13-2013 | 09:06 AM
  #7199
i944scania's Avatar
The Maf frequency climbed as normal when I did a pull. But as it boosted higher and the rpms rose past 5k, the freq started to keep its position or slow. Then eventually dropped down causing the car to freeze and stop pulling completely.
Also, this does not happen if I run like 12 psi of boost, it can rev all the way out
Old 12-13-2013 | 09:22 AM
  #7200
armcclure's Avatar
Assuming blow through? You aren't running meth pre maf are you?
Quick Reply: Official Turbo LSJ thread!!!
