Official Turbo LSJ thread!!!
Old 12-29-2013 | 10:11 AM
  #7301
i944scania's Avatar
Are you familiar with map sensor locations? I've got the one from the sc connected to my zzp plate. The other one doesn't seem to be connected to anything
Old 12-29-2013 | 10:16 AM
  #7302
i944scania's Avatar
My stock intercooler system is removed besides the endplate. Checked knock sensor connector, looks good.
As for the fueling issues, tuner had no explanation for the issue and said fueling and timing was great.
Old 12-29-2013 | 10:45 AM
  #7303
noorj's Avatar
This is why I want to see the tune, we really can't give anything except speculation without the tune and logs/config
Old 12-29-2013 | 10:46 AM
  #7304
i944scania's Avatar
Can you tell me anything about the other map sensor? I've got one that isn't connected to anything.
Old 12-29-2013 | 10:55 AM
  #7305
CCrunner84's Avatar
It's the SCIP sensor, was mounted before the rotors on the M62, it should be disabled in your tune.
Old 12-29-2013 | 12:12 PM
  #7306
BlkWdoSS's Avatar
green circle is Supercharger Inlet Pressure sensor, it should be turned off
blue circle is the location of the actual Manifold Absolute Pressure sensor
red circle is the location of the Barometric Pressure sensor, it just sits on a bracket, doesnt hook into anything
If you dont provide people with the tools to help you then we wont ever solve the problem. It seems your tuner isnt wanting to fix your issue, harass him repeatedly to get the logs and tune posted so that Noor and I can comb thru them.
"Keep doing what you are doing, and you will keep getting what you are getting"
Old 12-29-2013 | 12:57 PM
  #7307
i944scania's Avatar
Cleaned the intake plates, the map, and throttle body. Check codes, no codes thrown as it idled for 10 min.
Went down the road, boosted towards 18 and the problem happened. Came back, threw 2 p0069. What should I do!
Old 12-29-2013 | 04:07 PM
  #7308
noorj's Avatar
your scip isn't tuned out
edit: "If the PCM detects that the BARO sensor signal and the SCIP sensor signal are not within a calibrated range of each other, whether that value is negative or positive, DTC P0069 sets."
again just get us the tune and logs, then we will help. anything else will not change anything
Old 12-29-2013 | 04:19 PM
  #7309
i944scania's Avatar
Ohhh I'll talk with my tuner! Do you think it could be the high boost issue I'm having
Old 12-29-2013 | 04:20 PM
  #7310
noorj's Avatar
no
Old 12-29-2013 | 05:49 PM
  #7311
ItalianJoe1's Avatar
Yes, the SCIP isn't supposed to see boost. If you have it in a part of your piping that is getting pressurized and it isn't disabled in the tune, it's setting the fault code. I don't know what the PCM's course of action is for that fault but if it's supposed to send the car into reduced power mode it could explain the stuttering you are getting under higher boost.
Old 12-29-2013 | 06:39 PM
  #7312
i944scania's Avatar
Oh wow :x any options until I get to meet up with my tuner? At least to kill the issue?I'm guessing disconnecting the sensor won't change anything
Old 12-29-2013 | 06:40 PM
  #7313
noorj's Avatar
Sorry, I assumed it was known not to put it in a charge pipe. Bad assumption on my part I guess lol
edit: I'm pretty sure that the p0069 will not put a vehicle in limp mode, only p0068. Are you getting that too?
Old 12-29-2013 | 06:46 PM
  #7314
i944scania's Avatar
It is seeing boost.
http://shop.zzperformance.com/store/...ter-Plate.aspx
Its in the right side port. Throws code as soon as I boost
Its only throwing 0069 the correlation code.
Old 12-29-2013 | 07:02 PM
  #7315
BlkWdoSS's Avatar
It does not look like your SCIP sensor is in a boost area it is just hanging out in space:
red is your map sensor, blue can be disconnected and thrown away, tuner needs to turn it off
but it isnt correlating with the rest of the sensors, MAP is seeing pressure, MAF is seeing flow but SCIP is showing same as BARO sensor, pcm sees that as an issue
Old 12-29-2013 | 07:10 PM
  #7316
noorj's Avatar
Isn't that right over where the bypass "stem" of the intake manifold is, therefore if it is in the "stem" it is reading boost? Either way I'm not convinced that the sensor seeing pressure would cause limp mode, especially being that only once it gets over a certain pressure it happens.
Old 12-29-2013 | 07:16 PM
  #7317
i944scania's Avatar
Here is the issue. See how zzp shows the blue? That Bosch sensor in that picture is the map. The left port is where it originally sits.
I tried to put the map in that right port today and the holes drilled do not match. So the map needs to stay at the manifold.
Surprisingly the scip fits perfectly into the right port on the plates.
So I don't know why zzp shows the map in that spot
Old 12-29-2013 | 07:17 PM
  #7318
i944scania's Avatar
I would let the scip sit in open air but I'd have to find a way to plug it. Or get in touch with my tuner..
Edit: never mind! That blue sensor is not the Bosch map! My mistake
Old 12-29-2013 | 07:30 PM
  #7319
noorj's Avatar
unplug it and see what happens
Old 12-29-2013 | 07:31 PM
  #7320
BlkWdoSS's Avatar
SCIP isnt the problem just looked at your tune. those are turned off (P1182/p1183/p1184)
You are seeing a MAP/BARO correlation issue, seriously looks like the MAF is failing, it looks at the MAP and the MAP and BARO arent correlating, one or the other is too far up or down
Old 12-29-2013 | 07:35 PM
  #7321
BlkWdoSS's Avatar
your tuner also has the MAP/MAF throttle correlation test turned off, he needs to turn that back on, It is possible that your map sensor is dead
Old 12-29-2013 | 07:37 PM
  #7322
noorj's Avatar
Where'd you see the tune?
Old 12-29-2013 | 07:48 PM
  #7323
i944scania's Avatar
I'm having a communication break down with him atm but I believe we turned test off to see if it changed the problem. I will find out!
Old 12-29-2013 | 07:51 PM
  #7324
BlkWdoSS's Avatar
Im looking at the file he posted Noor, just comparing it to mine, I know they said its been reworked but Im assuming that those things havent been changed
and you were right, I forgot about the bypass stem, that is where the SCIP is, but appears to just be blocking off that area from what I see that he did in the original tune
Old 12-29-2013 | 08:00 PM
  #7325
noorj's Avatar
the one on HPT forum?
IDK which one is the latest but the one on hpt has the maf/map correlation code turned on
Quick Reply: Official Turbo LSJ thread!!!
