Official Turbo LSJ thread!!!
Old 12-29-2013 | 08:02 PM
  #7326
i944scania's Avatar
0069 is on, the one I'm getting
Old 12-29-2013 | 08:16 PM
  #7327
BlkWdoSS's Avatar
Originally Posted by noorjariri
the one on HPT forum?
IDK which one is the latest but the one on hpt has the maf/map correlation code turned on
the code P0068 and P0069 are turned on but:
The tuner has it so that the test for the P0068 will not run below 8,000 rpm.
If your tuner will set this to 800 rpm, your car should fail immediately and go into Engine Power Reduced mode. If so then one of the 3 sensors MAF/MAP/BARO is dead and has to be replaced
Old 12-29-2013 | 08:20 PM
  #7328
BlkWdoSS's Avatar
I still maintain that overall it is a fuel issue but I cant determine that without seeing the Injector Duty Cycles in logs
Old 12-29-2013 | 08:28 PM
  #7329
noorj's Avatar
damn good call didn't know p0068 was on that tab as well
Old 12-29-2013 | 08:30 PM
  #7330
i944scania's Avatar
So since it still trips 0069 when I boost(and well under 8000 rpm) then I should replace the baro?
Old 12-29-2013 | 08:34 PM
  #7331
noorj's Avatar
no it's tripping the p0069 because that sensor should not be there, find a plug or something for that spot.
like I said leave that sensor in there but unplug it, see what it does
Old 12-29-2013 | 08:36 PM
  #7332
Import Reaper's Avatar
Hey guys just did my zzp turbo swap with 256. I'm having an issue with an exhaust leak that my mechanic can't figure out for the past 2 days, all gaskets have been replaced, everything is tightened down, nothing is loose. He's doing a smoke test as we've exhausted all options pretty much. Could something possibly be bad from fabrication that it's leaking?
Old 12-29-2013 | 08:37 PM
  #7333
i944scania's Avatar
Thanks a bunch guys! Will do
Old 12-29-2013 | 08:40 PM
  #7334
BlkWdoSS's Avatar
I wouldnt replace any sensors until we can see logs, we can see what the MAP MAF and Baro sensors are seeing itll be quite obvious when one isnt displaying a signal or is incredibly erratic. Your car needs to run the tests on those sensors, so he has to turn that back on by setting it at 800 rpm like GM has it set.
The SCIP has a different code set, the p0069 is MAP / MAF where MAP is the actual MAP sensor
Old 12-29-2013 | 08:41 PM
  #7335
BlkWdoSS's Avatar
Its possible in some cases, especially when dealing with stainless, that the flange is warped and leaking, smoke test will definitely smoke that out lol, if it is the flange, you can either discuss with zzp or have some one put a lathe to it and get it smooth
Old 12-29-2013 | 08:42 PM
  #7336
noorj's Avatar
did you tighten the manifold nuts in the correct order?
lol I would be extremely impressed if you could flatten that flange on a lathe
Old 12-29-2013 | 08:46 PM
  #7337
BlkWdoSS's Avatar
wrong word sorry, brain is dead, the warp can be smoothed with the proper tool
Old 12-29-2013 | 08:49 PM
  #7338
noorj's Avatar
lol its okay im just ****** with ya
you can bring the manifold to a machinist and they can straighten it on a mill
  #7339
BlkWdoSS's Avatar
belt sander... lol thats what i used to clean mine up, but yea Mill is the way to go with a warped flange
Old 12-29-2013 | 08:50 PM
  #7340
noorj's Avatar
lol that works too
Old 12-29-2013 | 09:11 PM
  #7341
574's Avatar
574
Matter of fact mine is in the shop now getting milled
Old 12-29-2013 | 09:14 PM
  #7342
noorj's Avatar
how many of you guys are running a fuel pump rewire kit?
I'm on the stock pump+80s and the pump can't keep up anymore. I'm gonna replace it with the aem 320 e85 fuel pump but keep the stock in-tank fuel pressure regulator. Should I get a rewire kit too? I was thinking I would with a ZZP order I'm putting in soon but they took it off there website.
Old 12-29-2013 | 09:27 PM
  #7343
574's Avatar
574
Your fuel system stock besides 80s?
Old 12-29-2013 | 09:34 PM
  #7344
noorj's Avatar
yep
Old 12-29-2013 | 09:37 PM
  #7345
574's Avatar
574
Do pump, rewire, return system and my ID1000s lol
Old 12-29-2013 | 09:56 PM
  #7346
noorj's Avatar
you'll sell me all of that?!?!? for $20?!?! DEAL
Old 12-29-2013 | 10:00 PM
  #7347
574's Avatar
574
$19.95 sir
Old 12-29-2013 | 10:03 PM
  #7348
noorj's Avatar
Old 12-30-2013 | 08:55 AM
  #7349
Bass_Waves's Avatar
Size:  107.8 KB Name:  1387769338603_zpsahxisvxa.jpg
Size:  108.1 KB Name:  IMG_20131228_162100_zpsjrhcqw20.jpg
My install. Found these pipes to be a right fit.
Zzp 256et
tial bov
Nothing special. Just the regular kit.
Quick question. The oil feed line. Mines is pretty short but normal to all I'm assuming. Said don't let it touch the manifold. I have attached the open dump and well that feed line is in between the dump and manifold. How did ya route this line? I was about to zip tie it to the coolant line for the heater core.
Old 12-30-2013 | 08:58 AM
  #7350
574's Avatar
574
Mine touches the manifold but the black protector around it protected it last season. Heat wrap the manifold and dump if you are worried, I just did
Quick Reply: Official Turbo LSJ thread!!!
