Official Turbo LSJ thread!!!
Old 01-02-2014 | 05:47 PM
  #7376
BlkWdoSS's Avatar
He has your fuel maps set for 80s, he changed scalers that didnt make sense to change , and because he has changed them, the logs would be off for like injector duty cycle etc.
Old 01-02-2014 | 06:42 PM
  #7377
574's Avatar
574
I ain't scurrrred
Old 01-02-2014 | 07:31 PM
  #7378
bmxracerchamp12's Avatar
spent a nice chunk at zzp today for my ion. should be road worthy by the summer time and over 400! plus it will look and sound stock
Old 01-02-2014 | 08:06 PM
  #7379
i944scania's Avatar
Did you see anything in the tune that stood out as a possible factor?
Old 01-02-2014 | 08:14 PM
  #7380
BlkWdoSS's Avatar
The numbers themselves arent horrible, but the scalers are off, and since they work as multipliers it screws everything up worse and worse as you increase airflow/engine speed/ etc. If you were closer I could retune you and that would help to at least isolate the issue/part failure
Old 01-02-2014 | 08:19 PM
  #7381
574's Avatar
574
What you get? Sounding stock is no fun
Old 01-02-2014 | 09:38 PM
  #7382
i944scania's Avatar
Damn how close are you to southern New Hampshire haha
Old 01-03-2014 | 02:33 AM
  #7383
Killa SS's Avatar
Still wont touch this :p
Old 01-03-2014 | 07:27 AM
  #7384
zzp 3" exhuast, aem e85 pump, boost reference fuel pressure kit, plus some other odds and ends i was missing
i know i wont pull you but i should hopefully keep up
but the reason i say stock looking and sounding is because i went with the quieter 3". the piping for the 20g routes under the car so you wont even know i have a turbo unless you are looking for it lol
Old 01-03-2014 | 10:22 AM
  #7385
InfraRedline's Avatar
My piping goes under the car as well. The ultimate troll status lol
Old 01-03-2014 | 11:08 AM
  #7386
i have an lsj fuel rail here. should i switch to the return style over the single line? i will run the boost reference kit but am looking for input
Old 01-03-2014 | 11:20 AM
  #7387
armcclure's Avatar
Makes for a clean and easy to adjust setup if you mount regulator to the end of the rail. Aside from that, doesn't make a huge difference.
Old 01-03-2014 | 12:35 PM
  #7388
it was mentioned that i wouldnt hold consistent enough of pressure across all the injectors if i kept my stock single line setup. i was originally just going to run the ottp return kit only but ended up buying the boost reference kit from zzp
Old 01-03-2014 | 08:18 PM
  #7389
BlkWdoSS's Avatar
Dallas, Texas, quite a drive
Turbo? what turbo?
Mine is on the end of the rail, extremely easy to adjust and and I feel its quite aesthetically pleasing there
Old 01-03-2014 | 08:23 PM
  #7390
noorj's Avatar
ewwwww worm clamp
Old 01-04-2014 | 01:33 AM
  #7391
i944scania's Avatar
Damn that looks so clean
Old 01-04-2014 | 02:00 AM
  #7392
Bluelightning's Avatar
Got Bewst?
Maybe if you popped the hood before you raced them lol
Old 01-04-2014 | 09:35 AM
  #7393
i944scania's Avatar
The beast intake manifold and fuel pressure regulator might give something away ha
Old 01-04-2014 | 03:25 PM
  #7394
BlkWdoSS's Avatar
Originally Posted by noorjariri
ewwwww worm clamp
Yea I know, needs some T-bolts, gotta clean up that area of the piping.
thanks
Old 01-04-2014 | 03:29 PM
  #7395
noorj's Avatar
lol yeah I'm just messin with ya, that manifold looks real nice tho
Old 01-04-2014 | 03:33 PM
  #7396
zrated89's Avatar
yea mine is sleeper as well, other than my shinny hahn intake manifold, and the precision turbo logo across it. That may give it away
Old 01-04-2014 | 03:59 PM
  #7397
BLAZIN07SS's Avatar
I'm too JDM for you
you can hide all the piping you want. my turbo whistles through the exhaust so unless someone is deaf, they are going to know i'm turbo'd
Old 01-04-2014 | 04:04 PM
  #7398
noorj's Avatar
what's your guys exhaust setup? right now I've got a 2.5" magnaflow catback with a catless downpipe. I wanna go to a full 3"
Old 01-04-2014 | 04:12 PM
  #7399
574's Avatar
574
Cut out in dp ftw
Old 01-04-2014 | 04:25 PM
  #7400
BLAZIN07SS's Avatar
I'm too JDM for you
full 3 inch catless turboback to a magnaflow straight through, no resonator
Quick Reply: Official Turbo LSJ thread!!!
