Official Turbo LSJ thread!!!
Old 02-05-2014 | 01:46 AM
  #7601
EXsoccer1921's Avatar
Ahh makes sense. Thought they were talking about just in general.
Old 02-05-2014 | 10:38 AM
  #7602
i944scania's Avatar
Was in 2nd last night and lost traction for a second. But my speedo needle went to zero and back up, power steering notification came on for a seconds. Just like when I plug in my code reader. What the heck is that!
Old 02-05-2014 | 12:32 PM
  #7603
Bass_Waves's Avatar
Power steering motor taking a dump. You may need that or the pscm . Its part of the steering column. I had that issue on my redline. A new motor solved 90% of it.
Old 02-05-2014 | 01:10 PM
  #7604
rico's Avatar
I have had this problem happening
Old 02-05-2014 | 08:19 PM
  #7605
BlkWdoSS's Avatar
Its a recall , so just run by the dealership and have them swap it
Old 02-05-2014 | 08:20 PM
  #7606
rico's Avatar
Even with an 04 and no warranty ?
Old 02-05-2014 | 08:25 PM
  #7607
rivaladore's Avatar
I'm pretty sure recalls have nothing to do if you have or don't have a warranty.
Old 02-05-2014 | 08:57 PM
  #7608
Bass_Waves's Avatar
Yes. My 04 redline got 2 motors put in within a month. 1st failed quick. 2nd is good so far. The original was shorting out mad stuff
Rivaladore sent ya a text.
Old 02-05-2014 | 09:36 PM
  #7609
rico's Avatar
Yes. My 04 redline got 2 motors put in within a month. 1st failed quick. 2nd is good so far. The original was shorting out mad stuff Rivaladore sent ya a text.
Good to know I'll tell my friend (gm) tech to look into they for me
Old 02-06-2014 | 08:07 PM
  #7610
BlkWdoSS's Avatar
yep recall is something outside of warranty, you do not need warranty to get recalls completed
Old 02-06-2014 | 08:21 PM
  #7611
rico's Avatar
Gotcha called my friend he said next week he can change it also while I'm there putting on the upgraded timing chain tensioner
Old 02-06-2014 | 08:34 PM
  #7612
ZOLOMAN3000's Avatar
extremely noob question but on the turbo itself, the oil feed is the port with the round hole and the drain is the square port right?
FLAME SUIT ON lol
Old 02-06-2014 | 08:38 PM
  #7613
Bass_Waves's Avatar
FLAME SUIT ON lol
oil feed is on top of the turbo. drain is bottom.
Old 02-06-2014 | 08:50 PM
  #7614
i know that but if the housing is turned it could be facing the wrong way. on the fittings there is a round opening in the center, that i am assuming is the feed, and a square opening in the center on the other side, that i am assuming is the return.
or can the oil flow through either way
Old 02-06-2014 | 09:10 PM
  #7615
Bad-A-SS's Avatar
Please post a picture because you have confused me with the square opening lol
Old 02-06-2014 | 09:15 PM
  #7616
rivaladore's Avatar
Same here. I've only seen/handled turbos with the drain flange already installed. Possibly that hole is square where the flange butts up to it
Old 02-06-2014 | 09:17 PM
  #7617
i944scania's Avatar
Yes the square opening is oil return
Old 02-06-2014 | 09:28 PM
  #7618
ok thank you so much and i don't have a pic as the turbo is not here yet lol
i will try to find a pic of one similar on google
Old 02-08-2014 | 10:15 AM
  #7619
BlkWdoSS's Avatar
Biggest hole is drain, smallest hole is feed
The large hole is to drain more quickly since the feed comes in pressurized and the drain is not pressurized.
Old 02-12-2014 | 12:53 AM
  #7620
rico's Avatar
anyone running or has used a ls4 tb ? results on that if so?
Old 02-12-2014 | 10:19 AM
  #7621
armcclure's Avatar
Not on turbo setups. People rarely run larger than 2.5" charge piping so there's really not much of a point.
A little update on my non-ic setup: ambient 20* starting iat2 40* at the end of a 2-3-4 pull iat2 was only 75*
Things are looking good
Old 02-12-2014 | 05:48 PM
  #7622
BlkWdoSS's Avatar
great results, ready to see some summer temps though, Ill be getting with you shortly about injectors
Old 02-12-2014 | 09:27 PM
  #7623
rico's Avatar
Ok cool and very nice . I wish I could turbo with no intercooler too lol
Old 02-12-2014 | 10:07 PM
  #7624
i944scania's Avatar
Are you running lsj heat exchanger system or just no ic?
Old 02-12-2014 | 10:23 PM
  #7625
armcclure's Avatar
No ic at all. Less than 2' of 2.5" pipe straight from the compressor to a Saab manifold modified to use an lsj tb.
There's hardly any lag at all.
Check out this vid I did today. Still at only 13psi. I dropped to 2nd, and crept up to 40, then nailed it when the needle hit 40. So from about 10" of vac to ripping the tires loose before the speedo can even catch up lol
Quick Reply: Official Turbo LSJ thread!!!
