Official Turbo LSJ thread!!!
Old 02-12-2014 | 10:53 PM
  #7626
SPDDMN36's Avatar
Very awesome. What tires do you run? And plans for radials to hold it down?
Old 02-12-2014 | 11:19 PM
  #7627
Powell Race Parts's Avatar
Good arm!
Old 02-13-2014 | 12:20 AM
  #7628
rico's Avatar
That thing moves
Old 02-13-2014 | 05:42 AM
  #7629
armcclure's Avatar
BFG SportComp2 255/40-17. Like any summer tire they're hard as a rock and don't grip worth crap when it's this cold.
When it's over 60* they actually do really well, especially with a small warmup.
I really don't WANT to run a dr unless I have to. And even then it would be only at the track.
I have most of powell's suspension parts. I love carving corners. And a drag radial would kiss that goodbye lol
Good arm!
Originally Posted by rico
That thing moves
Thanks
Old 02-13-2014 | 08:36 AM
  #7630
i944scania's Avatar
That's awesome! So your iats stay decent??
Old 02-13-2014 | 03:45 PM
  #7631
armcclure's Avatar
Yep.
Not on turbo setups. People rarely run larger than 2.5" charge piping so there's really not much of a point.
A little update on my non-ic setup: ambient 20* starting iat2 40* at the end of a 2-3-4 pull iat2 was only 75*
Things are looking good
Old 02-13-2014 | 04:21 PM
  #7632
Bluelightning's Avatar
Got Bewst?
Daym... Impressive lag
Old 02-13-2014 | 07:42 PM
  #7633
armcclure's Avatar
And just to clarify, that was NOT a nls. Just a normal quick granny shift. Just close your eyes and listen lol. Takes what 0.1 seconds to rebuild boost?
Old 02-13-2014 | 07:48 PM
  #7634
Got Bewst?
Let's revisit that when it's warm and you have more traction lol
Old 02-14-2014 | 05:43 AM
  #7635
armcclure's Avatar
We have a heat wave coming next week. Highs in the 50's. I'll be out tearin it up as long as all this snow doesn't flood everywhere.
Old 02-15-2014 | 10:34 AM
  #7636
startingline05's Avatar
Good to see the turbo LSJs still tearing it up on here
Old 02-16-2014 | 01:13 PM
  #7637
ucdatss's Avatar
iight guys I'm new to the turbo LSJ I'm currently piecing my kit together so far I have
Saab intake mani
2.4 throttle body
2.2 belt tensioner
By any chance does anyone have the routing diagram to the intercooler piping? Tryna determine which piping and turbo I will be going with
Old 02-16-2014 | 01:47 PM
  #7638
574's Avatar
574
Saab intake mani
2.4 throttle body
2.2 belt tensioner
Saab manifold has to use zzp pipe
Old 02-16-2014 | 05:47 PM
  #7639
armcclure's Avatar
False!
Old 02-16-2014 | 07:23 PM
  #7640
ucdatss's Avatar
Yeah u don't have to use Zzp piping
Old 02-16-2014 | 08:18 PM
  #7641
574's Avatar
574
False!
Can't tell if wise ass non intercooler comment or really another option
Old 02-16-2014 | 09:12 PM
  #7642
BlkWdoSS's Avatar
ive seen custom piping work with saab manifold, any fab shop can do it , its just usually cheaper to purchase intercooler piping that fits, ZZP can buy the piping bent and shaped in bulk and therefore cheaper than what you can do for just 1 set of piping
Saab intake mani
2.4 throttle body
2.2 belt tensioner
this is where you screwed up, if you are piecing together a kit you need to have a working understanding of turbo systems. If you have to ask the question you asked then it would be far better for you in the end to buy a complete kit.
There is no such thing as a routing diagram for a custom setup, it is all in how you address the way you would like to route it.
Old 02-16-2014 | 11:38 PM
  #7643
armcclure's Avatar
Was being a bit of a wise-ass lol
But really, when it comes to a custom setup, anything is possible. To use a Saab IM with an fmic you will have to have at least 1 180* and a mess of 90's.
I used to work for Roto-Fab and know how much that crap hurts flow. One of the things I hate most about pieces together pipes made from a pack of tight pre bends.
At least zzp has a cnc bender and can make the bend radius as large as possible for each turn.
Old 02-17-2014 | 02:38 AM
  #7644
sl0wlsj's Avatar
Opinions on lsj turbo. I ran a 5531 and made decent power. My question, should I run a 6262 or 6266. Mods will be as follows.
Gen 3 Block
K1 Rods
Diamond Pistons
ATI UD Damper
ZZP Neutral Shafts
Supertech intake and exhaust valves
ZZP 82# springs with titanium retainers
LSJ Turbo Stage 3 cams
80# injectors
Step 2 colder plugs
Looking to rev to 8k. Looking for 5s. Any guess on power for a 6262 or 6266?
Old 02-17-2014 | 07:55 AM
  #7645
574's Avatar
574
5862 or 6262. Both will do 5s. No need for a donkey dick turbo if you aren't gonna really use it, it'll just hurt your spool time. 6262 could put you 700+
Old 02-17-2014 | 08:49 AM
  #7646
armcclure's Avatar
Exactly. Sl0wlsj weren't you on a .48 also? Made very good numbers versus your boost level.
If you're only looking to break 5's is recommend the 5862. Comparable to a middle ground between an s256 and s262.
Old 02-17-2014 | 09:57 AM
  #7647
sl0wlsj's Avatar
Yeah I was on a .48. And I wanna break mid 5s atleast. Hoping for 6. Say ths 5862 would be the best for this?
Or guess I should ask, would the 6262 with my mods support over 600?
Old 02-17-2014 | 10:28 AM
  #7648
574's Avatar
574
You running corn?
Old 02-17-2014 | 10:42 AM
  #7649
sl0wlsj's Avatar
You running corn?
No bueno. None in my area
Old 02-17-2014 | 01:24 PM
  #7650
armcclure's Avatar
Iirc 340 at 19# on pump 93.
That's good. That's really good for a snail that size and pump. Makes me even more excited.
Yes the 6262 will get over 600 easy, but it may be more than you need, and have unnecessary lag. I think the 5862 would suit your goals perfectly.
Quick Reply: Official Turbo LSJ thread!!!
