Official Turbo LSJ thread!!!
Old 02-20-2014 | 09:33 AM
  #7676
bmxracerchamp12's Avatar
i must have bad luck. i have had 3 quit on me. but even my aem gauge has been sent back once
Old 02-20-2014 | 10:04 AM
  #7677
i944scania's Avatar
When I had my boost issues, it would go past 17 normally.
Now, it just looks like my wastegate is opening at 15.
It caused me to over boost after I rebuilt my turbo last weekend, map and maf maxed if I did a pull.
So my tuner suggested I connect my stock gauge by its side. Comparing the two, they both follow each other thru boost/vac until about 15.
The glow shift is mechanical. Possible the hose is slightly kinked somewhere?
Old 02-20-2014 | 10:07 AM
  #7678
i944scania's Avatar
The vac t fitting it came with had a little brass fitting with a small hole in the top(to gauge). Is it better to run a normal t fitting
Old 02-20-2014 | 10:49 AM
  #7679
SPDDMN36's Avatar
Mine came with a plastic T-fitting.
Old 02-20-2014 | 11:47 AM
  #7680
i944scania's Avatar
mine did to, but the top of the plastic t fitting had a small brass piece in it that had a small hole.
Old 02-20-2014 | 11:55 AM
  #7681
SPDDMN36's Avatar
Oh, I don't remember if mine did or not
Old 02-20-2014 | 12:01 PM
  #7682
i944scania's Avatar
i managed to finally in the topic on it.
Supposedly this small piece helps reduce noise to the boost gauge.
My current system is:
-intake manifold vac, t off to wastegate, stright hose to another t for boost gauge, final hose stright to BOV.
Im going to try moving the boost refenence for the gauge before the wastegate
Old 02-20-2014 | 01:18 PM
  #7683
armcclure's Avatar
Yes. That little restrictor pull helps keep the gauge movements smooth. In 2nd gear my car builds boost faster than the gauge can move
Old 02-24-2014 | 10:27 PM
  #7684
i944scania's Avatar
So I do have a sudden slight leak somewhere up top of exhaust causing lean at idle. Happened after a day of tuning
But heres a quick video.
What do you guys think I'm making for power?
Old 02-24-2014 | 10:58 PM
  #7685
armcclure's Avatar
I would like to know as well
Old 02-24-2014 | 11:24 PM
  #7686
Bad-A-SS's Avatar
Ok guys and gals I had an exhaust mani gasket fail me awhile back been contemplating which one I should go with, any suggestions please it would help the decision making lol
Old 02-25-2014 | 05:59 AM
  #7687
armcclure's Avatar
Copper
Old 02-25-2014 | 08:51 AM
  #7688
i944scania's Avatar
Remflex gaskets are great.
I don't know if I should run more boost! I'm only at 18 in the video.
Don't wanna blow it upppp, still runs good compression. 120k miles tho.
I can't really gauge what a safe number is. Any suggestions?
Old 02-25-2014 | 09:02 AM
  #7689
Bass_Waves's Avatar
Video Link: http://m.youtube.com/watch?v=CHRTVO3S1EI
What turbo?
Old 02-25-2014 | 09:19 AM
  #7690
i944scania's Avatar
What turbo?
http://m.ebay.com/itm/261243200719?nav=SEARCH
Its a cheapo version that I rebuilt with Garrett internals
Old 02-25-2014 | 11:54 AM
  #7691
armcclure's Avatar
I wouldn't call that necessarily a cheapo if it's made with garret parts. At 18 I would ballpark you at 340.
Old 02-25-2014 | 11:58 AM
  #7692
i944scania's Avatar
Ya it was an ebay looking turbo I got in a used kit on here.
When i blew the oil seal I decided to use a garrett kit to rebuild.
I was thinking that range too! Do you know what you're running for power?
I have been thinking about running more boost but idk how safe it would be
  #7693
Bass_Waves's Avatar
Nailed it ^^^^
Old 02-25-2014 | 02:18 PM
  #7694
armcclure's Avatar
Realistically I would guess around 375. Give or take maybe 15 or so. Just a rough guess.
Another member on here made 339 on 19psi with pump gas and the smaller ar version of my turbo; don't know anything about the tune but would guess fairly conservitave. I'm running 20.5-21 and a pretty good amount of timing thanks to the corn. And this sob hits hard lol. Love it.
Old 02-25-2014 | 08:22 PM
  #7695
i944scania's Avatar
What are compressor and turbine #s of yours?
Glow shift works now! Pulled it out of pod, looked at it, put it back in. Now boosts fine past 15 ?
Old 02-25-2014 | 09:08 PM
  #7696
BlkWdoSS's Avatar
gonna finish stripping block tomorrow and then its off to Mr. B for sleeves, the Black Widow revival has begun
Old 02-25-2014 | 09:21 PM
  #7697
574's Avatar
574
How long has it been down? As long as I've been a member I don't remember seeing it on the street
Old 02-25-2014 | 09:31 PM
  #7698
BlkWdoSS's Avatar
It died in mid april 2012, so itll be right at 2 years once it is finally up and going again
Old 02-25-2014 | 10:41 PM
  #7699
armcclure's Avatar
55mm compressor, 57mm turbine, 0.63ar
They are awesome. I've helped install several sets.
Old 02-25-2014 | 11:13 PM
  #7700
julioareyna's Avatar
I need help im new here I just bought me a xobalt ss and has oil (runny peanut butter) in the water reservoir what to do
Quick Reply: Official Turbo LSJ thread!!!
