Official Turbo LSJ thread!!!
Old 03-30-2014 | 04:21 PM
  #7826
armcclure's Avatar
For those that haven't heard.....
Granted, it smoothed up a good deal once I actually dialed them in. This was the very first startup and it was about 30* outside.
Old 03-31-2014 | 08:09 AM
  #7827
noorj's Avatar
nice! so whats your whp goal alan?
Old 03-31-2014 | 09:32 AM
  #7828
i944scania's Avatar
Anyone having a hard time with lean/rich from rear o2 delete? Its set to no error reported in HP but I still get weird behavior sometimes. If I just plug the o2 back in and mount it under the body, would that help instead of just a connector lying there?
Old 03-31-2014 | 09:39 AM
  #7829
noorj's Avatar
I haven't had a problem before, you need to make sure all the secondary o2 codes are set to "3-No error reported"
The secondary o2 is 100% for catalyst and primary o2 checks, it has nothing to do with fuel delivery.
Old 03-31-2014 | 09:47 AM
  #7830
i944scania's Avatar
I know that the the rear o2 checks the cat but its the strangest thing. There's nothing else that can explain it, and on HP tuners there are other people who believe removing the rear o2 causes the computer to go crazy occasionally, since its a checking system that is now gone.
My car literally starts commanding a weird 16afr or something all of a sudden. After half a min it starts commanding like 12. And this is at idle. The another min goes by and the car is fine up to 14.7 afr for 20 miles.
My evap purge goes to 0% and the front o2 displays weird voltages. I replaced both to see if issue would stop
Old 03-31-2014 | 11:13 AM
  #7831
armcclure's Avatar
That's because you have the codes set to no error reported.
The PCM thinks everything is supposed to be ok (no codes) but it can tell something is up. So it will run a rich/lean test when you come back down to idle.
Change one of the rear o2 codes to "no mil light" and disable ses. This will set the code but not give a check engine light. If any o2 codes are present, the rich/lean test cannot run.
Old 03-31-2014 | 11:16 AM
  #7832
armcclure's Avatar
Well I ran it through virtual dyno (which was within 10whp/tq on my sc setup) and it put out I think 405/350... Somewhere around there. And this was accidentally on low boost.
I have low set at 17, high at 24-25. The top end now feels every bit as strong on 17 as it did on 24 with stock cams.
I'm going back to the dyno on the 19th with a couple guys just for fun so hopefully we'll see mid 400's without trying too hard.
Old 04-04-2014 | 02:54 PM
  #7833
i944scania's Avatar
anyone run a stock lsj throttle body on an lsj turbo and mani? I need help with throttle body scaling numbers. Cannot get it quite right. car runs well, just a little laggy pre boost and throws CEL for tb and misfires that i dont feel.
Just max the numbers out? idk im lost
Old 04-04-2014 | 03:28 PM
  #7834
armcclure's Avatar
Stock mani with adapter plate? You shouldn't "have" to change anything.
If anything, take scalar up a little.
Those tables don't do anything off idle though.
Old 04-04-2014 | 03:56 PM
  #7835
cobaltsssc760's Avatar
I could watch videos of people boosting from 40-100 all day long.
Cant wait to go turbo sometime late this year
Old 04-04-2014 | 04:07 PM
  #7836
InfraRedline's Avatar
Sorry its not from 40
Old 04-04-2014 | 04:45 PM
  #7837
close enough
Old 04-04-2014 | 11:33 PM
  #7838
i944scania's Avatar
I'm getting new tires tomorrow guys, I've got a few options.
225 40, 225 45, 245 40, 245 45.
What is the best tire to keep my 2nd gear spin in control without rubbing besides a little on uturns?
Currently running 215 45 18s, stock sc rims.
I searched for info and everyone's got a different opinion.... would be great to hear from the Lsj t guys
Old 04-04-2014 | 11:44 PM
  #7839
SPDDMN36's Avatar
I wouldnt go any wider than a 225 on stock rims. 45 sidewall will give you a hair more traction...maybe. Depending on how low you are you might rub on a 225's. My tires rub on hard turns on teins and my brothers car does on coils with the same tire setup. I think compound of tire will make more difference here than 10mm of tire width.
Old 04-04-2014 | 11:47 PM
  #7840
i944scania's Avatar
I am stock suspension, so sounds like might as well go for the 225 45? I'd hate to have a giant gap with the 40 too
Old 04-05-2014 | 10:29 AM
  #7841
The main thing like SPD said is the compound of the tire. Width will help, but putting a good quality tire on there will be the determining factor for traction.
Old 04-05-2014 | 11:21 AM
  #7842
BlkWdoSS's Avatar
im lowered on Pedders Springs with 235/40 tires without any rub issues
Old 04-05-2014 | 11:49 AM
  #7843
zrated89's Avatar
The rear O2 delete, especially on the 07 cars will cause all kinds of ghost issues no matter how you command the CEL. I have ran into this, as well as bryan (area47) and really theres no need to delete it anyways leave it in keep the pcm happy
Old 04-05-2014 | 07:13 PM
  #7844
BlkWdoSS's Avatar
leaving the rear o2 in, you cant run a catless dp without getting a light. There really isnt a great option with HP Tuners to control that, we realistically need to be able to change the definition of catalyst failure inside the PCM.
Old 04-05-2014 | 08:47 PM
  #7845
armcclure's Avatar
The PCM reacts off of codes, not lights. You can still set it to no mil.
Old 04-06-2014 | 04:05 PM
  #7846
BlkWdoSS's Avatar
I always just set them to No MIL, but the only way to do an actual delete is to change what the PCM is looking for when reading the rear o2
Old 04-07-2014 | 10:23 AM
  #7847
zrated89's Avatar
Yea I just turn the 420 code off. I've never had an issue. I tried deleting the rear o2 and my car was super pissed off. I put it back in. U can also grab an anti fouler spacer and it won't trip the 420 code
Old 04-08-2014 | 09:50 AM
  #7848
i944scania's Avatar
But I don't have a rear o2 bung, its being used by my wideband
And I'm cat less. So can I reconnect that o2 and just hang it under there so the pcm gets some communication?
Old 04-08-2014 | 09:53 AM
  #7849
bmxracerchamp12's Avatar
i will be in the same boat unless i sell my current turbo setup to go bigger
Old 04-08-2014 | 10:12 AM
  #7850
Bass_Waves's Avatar
Dang. Turned up the boost and lost traction. Guess I need better tires
Quick Reply: Official Turbo LSJ thread!!!
