Official Turbo LSJ thread!!!
#7828
Anyone having a hard time with lean/rich from rear o2 delete? Its set to no error reported in HP but I still get weird behavior sometimes. If I just plug the o2 back in and mount it under the body, would that help instead of just a connector lying there?
#7829
The secondary o2 is 100% for catalyst and primary o2 checks, it has nothing to do with fuel delivery.
#7830
My car literally starts commanding a weird 16afr or something all of a sudden. After half a min it starts commanding like 12. And this is at idle. The another min goes by and the car is fine up to 14.7 afr for 20 miles.
My evap purge goes to 0% and the front o2 displays weird voltages. I replaced both to see if issue would stop
#7831
That's because you have the codes set to no error reported.
The PCM thinks everything is supposed to be ok (no codes) but it can tell something is up. So it will run a rich/lean test when you come back down to idle.
Change one of the rear o2 codes to "no mil light" and disable ses. This will set the code but not give a check engine light. If any o2 codes are present, the rich/lean test cannot run.
#7832
Well I ran it through virtual dyno (which was within 10whp/tq on my sc setup) and it put out I think 405/350... Somewhere around there. And this was accidentally on low boost.
I have low set at 17, high at 24-25. The top end now feels every bit as strong on 17 as it did on 24 with stock cams.
I'm going back to the dyno on the 19th with a couple guys just for fun so hopefully we'll see mid 400's without trying too hard.
#7833
anyone run a stock lsj throttle body on an lsj turbo and mani? I need help with throttle body scaling numbers. Cannot get it quite right. car runs well, just a little laggy pre boost and throws CEL for tb and misfires that i dont feel.
Just max the numbers out? idk im lost
#7838
I'm getting new tires tomorrow guys, I've got a few options.
225 40, 225 45, 245 40, 245 45.
What is the best tire to keep my 2nd gear spin in control without rubbing besides a little on uturns?
Currently running 215 45 18s, stock sc rims.
I searched for info and everyone's got a different opinion.... would be great to hear from the Lsj t guys
#7839
#7843
The rear O2 delete, especially on the 07 cars will cause all kinds of ghost issues no matter how you command the CEL. I have ran into this, as well as bryan (area47) and really theres no need to delete it anyways leave it in keep the pcm happy
#7844
leaving the rear o2 in, you cant run a catless dp without getting a light. There really isnt a great option with HP Tuners to control that, we realistically need to be able to change the definition of catalyst failure inside the PCM.
#7847
Yea I just turn the 420 code off. I've never had an issue. I tried deleting the rear o2 and my car was super pissed off. I put it back in. U can also grab an anti fouler spacer and it won't trip the 420 code
