Official Turbo LSJ thread!!!
Old 04-21-2014 | 06:12 PM
  #7876
InfraRedline's Avatar
Wanna know something weird? My car no longer torque steers at all. It just points straight and goes. One of 2 things is causing this. Either has something to do with the F40, or I have gotten so used to it over the years with the TVS and the broad power of the turbo makes it seem less dramatic lol.
Old 04-21-2014 | 06:18 PM
  #7877
armcclure's Avatar
Originally Posted by BlkWdoSS
what RPM did you run it to?
Only 7300. By spec the cams should peak between 8000-8500, and from the looks of the graph I'd say that's about right. I only hopped on the rollers for fun, I wasn't really shooting for any number, just wanted to see the tq curve.
That very well could be it. Even though these cans don't let it hit full boost till 4 on the street, it's still kinda violent lol. Once it's lit though she's pretty much point and shoot.
Old 04-22-2014 | 10:13 AM
  #7878
Repped for the turbo LSJ's last night and beat my friends 470+whp Evo from a 40 and a 60. I'll post vids today I was on 21 psi.
Old 04-22-2014 | 10:38 AM
  #7879
mrbelvedere's Avatar
we have the exact same cams and mine hit a lot sooner once you get the cl set 8500 will probably be a no go
Old 04-22-2014 | 04:30 PM
  #7880
armcclure's Avatar
Derek was saying the turbo will effect that a lot, will definitely be interesting
To find out for sure.
Old 04-22-2014 | 04:55 PM
  #7881
I bet it changes
Old 04-22-2014 | 04:57 PM
  #7882
New turbo video in the war stories
Old 04-22-2014 | 07:21 PM
  #7883
RedSSbalt246's Avatar
Nice Arm...**** is strong
Old 04-22-2014 | 10:32 PM
  #7884
armcclure's Avatar
Originally Posted by mrbelvedere
I bet it changes
Well of course it will change. How much is the question. Intake to exhaust pressure ratio will come into play also.
Thanks It's fun!
Old 04-23-2014 | 01:43 PM
  #7885
i944scania's Avatar
any advice on plugs? my cars finally good but im getting a stupid initial startup CEL from random misfire that i dont feel. Then the light goes away and comes on another time.
currently running step colder ngkr at .032. would normal plugs help? what gap
Old 04-23-2014 | 01:50 PM
  #7886
bmxracerchamp12's Avatar
you on pump or e85? my saturn gets the miss once and awhile but the light never pops. i randomly scan my car to make sure all is well
Old 04-23-2014 | 02:22 PM
  #7887
i944scania's Avatar
Just pump 93
Old 04-23-2014 | 03:17 PM
  #7888
armcclure's Avatar
Checked plugs I assume?
Old 04-23-2014 | 09:00 PM
  #7889
i944scania's Avatar
Yep yepp
Old 04-25-2014 | 05:03 AM
  #7890
armcclure's Avatar
What injectors, and are your cranking ve tables stock
Old 04-25-2014 | 01:10 PM
  #7891
i944scania's Avatar
Replaced plugs(ac delco copper .030), car is more responsive. And check engine light for 0300 didn't come for about a day. But I still get a ghost misfire.... I dont feel it and my code reader says its low rpm and throttle. Ya running 60s. Stupid check engine light. Not running any boost leaks or anything and it still threw intake perf code. We shut it off, maybe theyre connected.
Runs great, fast, 20in hg at idle. Idk whats up..
Old 04-25-2014 | 02:34 PM
  #7892
zrated89's Avatar
john is a mod?!?! WTF
Old 04-27-2014 | 07:13 PM
  #7893
BlueDemon's Avatar
Hey guys I'm doing an lsj turbo swap. The engine is torn down, ready for new internals because of a bent rod. So, my power goal is ~300 hp on an externally waste gated ko4 with bypass block off. My question is, forged rods/pistons or will new stockers hold up? I just don't want to waste money. Thanks
Old 04-28-2014 | 01:24 AM
  #7894
i944scania's Avatar
Friends I have a riddle for you:
Why would an lsj turbo run p1101 maf freq code and p0300 random misfire? No leaks, new plugs, cleaned tb, is it map sensor??? Only ghost misfire that I dont even feel at low rpm and idle.
Seems to wanna go lean, afrs bounce from 14.0-low 16s sometimes. Other times its perfect around 14.7
Although, setting that o2 code to no mil instead of no err seems to have worked for the lean/rich test
Old 04-28-2014 | 08:46 PM
  #7895
BlkWdoSS's Avatar
Start by getting a real turbo, a k04 is a waste on an LSJ and makes your life a complete headache. The LSJ flows air better than the LNF and will spool the k04 too quickly and makes the car fall on its face once it gets to a decent RPM
Old 04-28-2014 | 08:52 PM
  #7896
574's Avatar
574
I was gonna say the same, but many that have this already planned out don't care to listen.
Old 04-28-2014 | 09:12 PM
  #7897
armcclure's Avatar
They all live and learn. I have yet to see one single lsj-k04 built that wasn't abandoned or changed very quickly upon completion
Old 04-29-2014 | 01:10 AM
  #7898
Rockford_Redline's Avatar
Alan, Phillip Gruver has a k04 on his lsj and has had for over a year. He has had very good luck with it and loves it. Only one I know of though.
Old 04-29-2014 | 06:45 AM
  #7899
armcclure's Avatar
Good to hear. I'm not at all saying it's impossible, just takes careful tuning and proper boost control and smart driving.
Old 04-29-2014 | 08:57 AM
  #7900
Wasn't trying to downplay you at all. Just helping your point really. 1 guy has done it and liked it. I was actually working on a K04 swap and backed out before it was finished. I just picked up a precision 5431 today actually.
Quick Reply: Official Turbo LSJ thread!!!
