Official Turbo LSJ thread!!!
Old 04-30-2014 | 04:43 PM
  #7926
574's Avatar
574
Nothing wrong with that. ARM just put down 460hp on a stock lsj engine with 160k miles. Another guy jon put down the stock lsj record of 508
Old 04-30-2014 | 06:56 PM
  #7927
BlueDemon's Avatar
Well It can't hurt to set ignition and fuel map for higher boost. I don't always have to run it full boost ***** to the wall. I'll invest in a thorough tune and a good boost controller, then I can just turn up when I need it
Old 04-30-2014 | 06:59 PM
  #7928
Bass_Waves's Avatar
So I just hit a wall. The needs to go e85 requires 1200cc minimum injectors. What should j go with in terms of fuel pump?
Old 04-30-2014 | 08:48 PM
  #7929
BlueDemon's Avatar
Zzp has an Aem e85 pump kit that flows 320lph
Old 05-01-2014 | 07:05 AM
  #7930
bmxracerchamp12's Avatar
Originally Posted by BlueDemon
Will a gen.1 block hold 400 hp? I just have a fetish for over engineering
im running a sleeved first gen 2.2
Old 05-01-2014 | 07:25 AM
  #7931
armcclure's Avatar
Compression was about 200 across the board, leak down under 4%
Old 05-01-2014 | 07:53 AM
  #7932
BlueDemon's Avatar
My stock sleeves are in good shape. I really shouldn't be worried. I'll have way lower iats and just a little more pressure. Checked my mains and bores with a dial bore gauge, i had a bent rod for almost 3 years in cylinder 2. It only out me one and a half thousandths out of round. All mains are well in spec and my journals are good. I'll share a pic of that rod
Old 05-01-2014 | 09:01 AM
  #7933
BlueDemon's Avatar
Looks fine right
Old 05-01-2014 | 09:07 AM
  #7934
ItalianJoe1's Avatar
That's the special lower compression version, no problems there
Old 05-01-2014 | 09:11 AM
  #7935
BlueDemon's Avatar
Yes gm performance made a special run of rods to run 6.5:1 compression for turbo nitrous and methanol builds I own a set of these legendary beauties
Old 05-01-2014 | 08:14 PM
  #7936
BlkWdoSS's Avatar
I made 440whp on 93 with 3 bad cylinders on a stock LSJ, so I know a good running LSJ can handle far more
Old 05-01-2014 | 10:28 PM
  #7937
574's Avatar
574
Old 05-02-2014 | 05:52 AM
  #7938
BlueDemon's Avatar
Nice setup 574, is that zzps custom Saab manifold? My turbo kit is going to be frankensteined for sure. The 9-3 intake mani seems like the most cost effective solution to me. Probably going to be a combination of parts from treadstone, zzp and Hahn
Old 05-02-2014 | 07:00 AM
  #7939
574's Avatar
574
Not zzp just a Saab manifold from the junk yard modded by ARM and I. Manifold cost me $38...
Old 05-02-2014 | 07:51 AM
  #7940
BlueDemon's Avatar
I might do that. I have all the tools and time
Old 05-02-2014 | 08:38 AM
  #7941
$38 with tb? found a ttr mani and am going to pick it up this weekend
Old 05-02-2014 | 09:02 AM
  #7942
574's Avatar
574
It had a tb but I didn't buy it. .. it was a Saab. I pulled it off a car with front end damage and it was a bitch. Bought the tb from zzp for ****** $200
Old 05-02-2014 | 09:18 AM
  #7943
Rockford_Redline's Avatar
You can use you stock throttle body also.
Old 05-02-2014 | 11:32 AM
  #7944
574's Avatar
574
You can but you have to drill it out and have a spacer plate, I didn't have room fo that
Old 05-02-2014 | 12:26 PM
  #7945
just a minor trim job to make it work
Old 05-02-2014 | 12:41 PM
  #7946
armcclure's Avatar
You can't "trim off" the stepper motor
Old 05-02-2014 | 04:56 PM
  #7947
Area47's Avatar
Rent me! per hour
The stock long block record is higher than 508.
Old 05-02-2014 | 05:43 PM
  #7948
mrbelvedere's Avatar
that's what I was thinking
Old 05-02-2014 | 09:06 PM
  #7949
BlkWdoSS's Avatar
yep, doesnt Josh (blazin) make more than that?
Old 05-03-2014 | 01:03 AM
  #7950
574's Avatar
574
He doesn't know what he makes
Quick Reply: Official Turbo LSJ thread!!!
