Official Turbo LSJ thread!!!
#8088
Around 4k I believe maybe a little lower. I decided to get a 3"made.
So I'll have a catless dp 2.5, the 3"catback will start right at the subframe. I'll have to figure out my space issue for the dp when I have someone make a 3" dp. There's just no room by the trans mount.
The added backpressure should help with a little torque and then the 3" catback will compensate for the heavier, cooler air coming thru, almost like an open system after the dp
#8089
Honestly I'm not completely sure. I'm always paying so much attention to everything else going on haha.
I'm about to make a 3" downpipe and decided I'm done with the corsa catback because it will hold me back being 2.5" or smaller. I am going to be catless, to some muffler or resonator then to a turn down. I've ran open dp before and I know I can't handle that noise for daily driving. So im wondering if you guys would recommend a resonator or a muffler and what brand?
#8090
#8092
time for the millionth question!
anyone even have any weird lag in first if you boost too much? Set at 20 psi, exaclt what im tuned at, the car doesnt like it if you mash it in 1st gear once the waste gate opens. it will even lag a little in 2nd when you shift.
another way to say it is if i wanted to, and i dont!, i could not sit there and burnout in 1st full boost. the car seems to hit a little bit if a wall?? but this doesnt appear in 2nd, 3rd, or any other gear.
any ideas on this? map sensor maxing out maybe?
#8094
#8095
