Official Turbo LSJ thread!!!
#8178
Live in Fort Wayne, work in Marion.
Oh booh. You know you like your snow machines too.
Besides, you and I together could literally run the north half of the state with import fabrication and tuning.
#8179
hey guys i need some advice again....
so i went to get retuned and turn the boost up from 20 to about 25.
heres what happend:
-The boost needle seemed to shake worse and worse, depending on how much boost i turned it up.
-The needle seems to shake +/- 1 psi at 20. it shakes arond 2 psi when i try to hit 25 psi. I assumed it was the maunal boost controller.
- we are assuming it is compressor surge. with the boost higher, around 2-4500 rpm it would sputter and we could observe the logs spiking out. and the boost read 50 lb/min at certain points.
- At lower boost, like 20-22, it doesnt do it as bad but the issue is still there. Its almost as if the car slugs a little down low rpm, then once it revs high enough it clears up. We do get knock when the logs start to go spikey.
Is this compressor surge? I have a zzp BOV with the stock spring. today i ordered a -11psi spring, for a car that idles 18-20in.
I wonder if my vacuum line setup is incorrect.
2 parts:
- intake mani -> boost gauge t -> BOV
-Compressor -> manual controller -> wastegate bottom port
Is this setup wrong? zzp reccomends using the top port for the MBC
Please shoot me your ideas guys!
thanks
heres what happend:
2 parts:
thanks
#8181
heres what happend:
2 parts:
thanks
heres what happend:
2 parts:
thanks
#8182
according to a lot of comanies, zzp, tial etc, they said run your vacuum: turbo nipple-> t to the controller-> other t to bottom wastegate -> other side of controller to top of wastegate.
Im going to try this. I got the biggest spring they make for that gate :/
As for the logs, we watched everything start to get jagged. the maf, map, injector duty went way high all of a sudden. That was only within those spikes. so the airflow is unstable. And as the engine revs, the issue starts to level out and injector duty cycle returns to a decent number.
Its just a strange airflow. I cant hear if the BOV is making a bunch of noise because open dump. so my first plan of attack is wastegate, but i ordered a new -11 psi spring compared to the stock zzp BOV -19
#8183
its in that lower rpm boost range. I think thats why my car is fast top end but kind of slows down at lower rpm. It definetly kills my 60-100.
Ill take a video later to show you. the boost needed just flickers very fast between a psi or two.
#8185
For a typical MBC setup, like what I run, its just vacuum source to the bottom of the MBC (in my case, a Hallman) then from the side port of the MBC you run that to the lower port on the WG, like you said. I know ZZP likes to T the line before the MBC to the top port on the WG, which I believe the idea is to eliminate that possible slight spike as boost hits, but I could be wrong.
#8187
i would lean towards bov. make sure it has a dedicated line that is as short as possible.
also, if you do re route your controller to use the top port, remember that the boost controller will then work backwards.
#8188
I installed with compressor-> t to MBC -> other t to bottom wg port -> bleed end of controller to top of WG(because the other end needs to see boost).
Didn't work! Left my controller adjusted 75% and it said 7 psi. So I put it back to normal, making 20
#8190
It's a 0-30 psi voodoo MBC. Bottom port is bleed, side port sees boost.
So I'm waiting on my -11psi bov spring, hopefully getting rid of my stock zzp -19 spring will help with this strange surge and I can run 25psi no problem
#8191
SO those that are using the Saab Intake Manifold,
what did you use for a throttle body gasket, I used thin paper.
I seem to have a vac leak at the mani some where, AFR goes wayyyyy lean idling.
Thanks
Thanks
#8192
i used the same rtv that i use as the oil pan seal and it works for me
#8195
Hey can you give me some advice on how to run my vacuum system for my wastegate?? I think I get flutter at higher boost.
I have a compressor port, voodoo mbc(boost port and bleed port), turbonetics deltagate adjustable with new 9-13psi spring.
What is the best way to control my boost with this given info?
I'd love to hear from everyone
#8197
If you are having true flutter problems it's wither a gate issue or a leak in the lines.
Sometimes it can be the mbc, but that's usually with home made or eBay ball/spring controllers.
You CAN use a small restrictor in the line between the controller and wg, but you have to be careful and start big and work down. Too much of a restriction will cause a massive boost spike.
#8198
Compressor cover -> controller in -> controller out -> wg bottom port
Should my wastegate be turned all the way up? Its adjustable 9-13psi, then turn up the controller?
Or turn the wg down and turn the controller up higher
#8200
I'm having some pretty bad spool issues. Earliest spool is about 4500 but it comes on like a light switch. I feel there is something wrong that's causing this. The boost doesn't build smoothly, it builds about 5lbs slow then snaps to 23psi. I have everything for a 3" exhaust on order but I just don't know if a restrictive exhaust could cause this much of an issue. I know a 5862 isn't going to spool at 3k but it should be sooner than 4500. Any ideas?
