Official Turbo LSJ thread!!!
Old 03-07-2015 | 02:52 PM
  #8551
blaknyellowSS's Avatar
I'm installing a hahn manifold and there's a hole in the middle that looks like something goes there but pretty much everything is bolted in...Anyone th I KS what it goes too or its just secondary hole?
Old 03-09-2015 | 10:23 AM
  #8552
InfraRedline's Avatar
Do you have a pic of it? It may be for the PCV system.
Old 03-10-2015 | 10:46 AM
  #8553
yellowsupercharged06's Avatar
alright guys soooo im getting a powell trap door oil pan and im going to need the oil return line fitting welded on.
I am putting the pan on before the turbo kit sooo i need the fitting on there with a cap of some sort .. whats my best option ?
-10an fitting welded on with a cap over it .... or ..... npt bung, plug it then use a npt to -10an fitting once the turbo is put on ?
whats the easier of the two, more logical ... better option ?
any info is appreciated.
Old 03-10-2015 | 12:08 PM
  #8554
Bluelightning's Avatar
Got Bewst?
I would use a -10 fitting welded on with a cap over it.
Old 03-11-2015 | 12:57 AM
  #8555
andrewcarr1993's Avatar
Spend a little more and Powell will have a 1/2 NPT (AKA 10AN) or whatever you want welded on.
Old 03-11-2015 | 09:25 AM
  #8556
John is putting it on for me
does anyone have a picture of their pan with the fitting on it ? im trying to determine the best location .
im going to have him weld a male 10an onto the pan like so:
and then the male fitting on the turbo side:
then run a female - female line to connect them both.
** i am thinking this through the correct way .. right ???
Old 03-11-2015 | 10:26 AM
  #8557
Got Bewst?
There really is no "best location". Zzp has a couple spots mentioned in their turbo kit instructions where to mount it. One is above the oil drain plug and the other is to the right of the drain plug.
Old 03-11-2015 | 10:39 AM
  #8558
thanks ... i actually just read that.
I didnt see it the first time i looked at the directions.
But the fittings above are the right idea right ?
Old 03-11-2015 | 10:44 AM
  #8559
Got Bewst?
Yes sir
Old 03-11-2015 | 11:04 AM
  #8560
Yay
now anyone want to recommend somewhere to buy the fitting and the line with Female connectors ?
Old 03-11-2015 | 11:12 AM
  #8561
Mine is just barbed fittings with an insulated hose, so I'm not sure on that one.
On another note, the car feels amazing in this warmer weather and 34 psi
Old 03-11-2015 | 11:18 AM
  #8562
im too hood for a barbed fitting lmao
im **** and want it as leak free as possible
Old 03-11-2015 | 11:38 AM
  #8563
Got Bewst?
Ya same here. If you just type in an fittings into Google I'm sure you'll find tons of places that sell what you need if that's the way you want to go.
Old 03-11-2015 | 11:44 AM
  #8564
they work for you guys fine then im assuming ?
do you guys have a bung on the oil pan or a barb fitting welded on ?
Old 03-11-2015 | 11:52 AM
  #8565
Got Bewst?
I have a fitting on my pan but my turbo is barbed. Either way will work fine. It's not like theres an over abundance of pressure to blow the line off or anything. It's just an oil return.
Old 03-11-2015 | 11:58 AM
  #8566
ah ok good to know. thanks guys.
Old 03-11-2015 | 12:27 PM
  #8567
574's Avatar
574
Ain't No body got fuel for that! !
But for real I thought you were damn near out at 30
Old 03-11-2015 | 01:14 PM
  #8568
Yep mine is a barbed fitting threaded into a welded bung.
Yeah I was about out of fuel on 30 then I turned the base pressure up even more. A little out of my comfort zone, but it gets the job done. The injectors are maxed out though, over 100% IDC lol. I got it to 32 lbs and then thought I should go a little higher in case I ever am in a little cooler air or I give the boost controller a little too much turn up lol, that way I know I'd be safe.
Old 03-11-2015 | 02:13 PM
  #8569
Do you have to have your tune dialed into each boost setting? Or if its calibrated well at one psi, you can change the manual controller and be fine?
Old 03-11-2015 | 03:26 PM
  #8570
I have it dialed in so I can turn the boost from 22 psi up to 34 now and be fine all on the same tune. I guess 26 and under may be a little rich since I haven't turned it down since raising the pressure, but with what I changed everywhere it should be close. Either way, I don't plan on running less than 27 lbs at TX2K lol
Old 03-11-2015 | 03:52 PM
  #8571
im going to have to have Paul tune my car the same way. im going to run the zzp mbc inside the cabin.
Old 03-11-2015 | 03:57 PM
  #8572
Since i dont have brfp or anything like that does this mean if i changed my mbc settings the car would run rich at lower boost and lean at higher boost or would it work out fine for me?
Old 03-11-2015 | 04:16 PM
  #8573
As long as you can keep full control of the MAF table (either mot maxing it out or using a mini AFC like me) you can tune it to work at all boost levels. That will also keep your timing table in check so you can scale that accordingly as well.
Old 03-11-2015 | 04:29 PM
  #8574
So i would just have to have slight adjustments made for each boost level. Cool
Old 03-12-2015 | 01:04 AM
  #8575
Any online shop, buy a 45 degree fitting some braided AN line and another fitting for the turbo.
Oops I'm a page behind
Quick Reply: Official Turbo LSJ thread!!!
