Official Turbo LSJ thread!!!
Old 03-12-2015 | 09:49 AM
  #8576
yellowsupercharged06's Avatar
hahaha its all good... after thinking it over a little more ive come to the conclusion that i will just put a 1/2" npt bung into the pan and thread a fitting on there once i decide what i want to go with.
this way if i ever need to get a bigger fitting i can just swap them out and im not stuck with just a 10an welded on there.
Old 03-12-2015 | 01:31 PM
  #8577
farmerz24's Avatar
Yep mine is a barbed fitting threaded into a welded bung.
Yeah I was about out of fuel on 30 then I turned the base pressure up even more. A little out of my comfort zone, but it gets the job done. The injectors are maxed out though, over 100% IDC lol. I got it to 32 lbs and then thought I should go a little higher in case I ever am in a little cooler air or I give the boost controller a little too much turn up lol, that way I know I'd be safe.
How is your injectors spraying over 100% IDC, or did you mean commanded duty cycle is exceeding 100%. It is impossible for an injector to run more than 100% duty cycle.
Shouldn't IDC's be kept to 80-85% max?
Old 03-12-2015 | 01:44 PM
  #8578
Tell that to staged
Old 03-12-2015 | 01:46 PM
  #8579
you can get our IDC's over 100% lol ... just cuz your shouldnt dont me you couldnt
Old 03-12-2015 | 01:55 PM
  #8580
farmerz24's Avatar
really... explain how and be sure to provide some math or a calculation to show it.
Here is a good page:
Injector Duty Cycle Explained
Old 03-12-2015 | 02:18 PM
  #8581
Straight from your link:
I have seen it more than once that people report they ran a duty higher than 100%... it is not possible. Your injector has completely maxed out and only ran 100%, you just ran it past its operating range and the calculation shows that. It is impossible to physically run an injector HIGHER than 100%.
Were just running them outside of operating range
Last edited by Slowbalt2000; 03-12-2015 at 02:18 PM. Reason: Automerged Doublepost
Old 03-12-2015 | 02:38 PM
  #8582
i have no math ... all i have is a HPT log that says its over 100% ... call HPT and ask them
Old 03-12-2015 | 02:49 PM
  #8583
Josh@ottp's Avatar
It's just a calculation. Once you reach 100% the injector is open the whole time it takes to complete one cycle.
Old 03-12-2015 | 03:01 PM
  #8584
InfraRedline's Avatar
Yes, my injectors are static, flowing 100%, and on the verge of losing fueling control. The calculated IDC is 120%. I included that to show the severity of how maxed they are. I think I am going to get some 160 lb'ers. I didn't expect this car to continue to pick up so much airflow per lb of boost above 30, but I'm not complaining
Old 03-13-2015 | 06:56 AM
  #8585
armcclure's Avatar
Dat ETT brah
Old 03-13-2015 | 10:55 AM
  #8586
jperilli's Avatar
Has anyone here gone the saab route and used the saab intake manifold, exhaust manifold, and turbo on the lsj?
Old 03-13-2015 | 10:59 AM
  #8587
i know a lot of guys use the saab intake manifold. I will be using one.
Old 03-13-2015 | 11:00 AM
  #8588
jperilli's Avatar
What exhaust manifold will you be going with?
Old 03-13-2015 | 11:01 AM
  #8589
im going to get the zzp kit so it will be theirs.
Old 03-13-2015 | 11:46 AM
  #8590
jperilli's Avatar
I see, I'm looking at piecing together a kit
Old 03-13-2015 | 11:51 AM
  #8591
i thought about that and then thought ... i dnt want it to take forever to find everything and be 1/2 assed.
id rather have all new stuff ya know.
Old 03-13-2015 | 12:00 PM
  #8592
jperilli's Avatar
I definitely understand your logic with that. I just feel like this would be an awesome learning experience for me and if I can throw this together cheaper than the kit I'll be pretty happy
Old 03-13-2015 | 12:09 PM
  #8593
With the saab turbo you wont make any more power than the m62 could.
Old 03-13-2015 | 05:54 PM
  #8594
armcclure's Avatar
Exactly
Old 03-19-2015 | 12:26 PM
  #8595
juan1101's Avatar
What are symptoms of bad turbo?
Old 03-20-2015 | 08:02 AM
  #8596
armcclure's Avatar
Rattles, burning oil, screeching, low boost, shaft play.
Old 03-20-2015 | 04:45 PM
  #8597
juan1101's Avatar
I just finish installing a used block on my car and when i turned it on it started smoking and all 4 plugs have oil
Im guessing rings are bad
Old 03-20-2015 | 06:06 PM
  #8598
armcclure's Avatar
Well that's not ideal
Old 03-20-2015 | 06:12 PM
  #8599
juan1101's Avatar
Ye did a compression test but dont think is accurate since theres oil in my cylinders
Old 03-20-2015 | 07:41 PM
  #8600
You mean you did a wet compression test? Thats still accurate.
Quick Reply: Official Turbo LSJ thread!!!
