Official Turbo LSJ thread!!!
#8626
Ye thats what i was thinking ima see if i can get a good one and try it again. But just changed my valve seals to see if it fixes the problem but still smoking. I was thinking the rings are bad. Or could bad turbo seals cause this
1 . Oil in my spark plugs
2. Oil leaking from the manifold flange where it meets the turbo
and leaking from the flange.. would need pics to help any. Could be feed line leaking
#8627
Has anyone compared frame sizes? Are the 6262, 6266 and 6466 all the same measurements as far as the compressor and turbine housing sizes go?
#8629
So quick question. I'm about to put a down payment on OTTP's turbo swap kit. I did without the cat, and added the serpentine belt. Since it does not come with the intake, or the intercooler/piping I am going to order ZZP's turbo swap intake, and ZZP's intercooler package. Everything comes out to $3,383 without shipping which is a very good price in my opinion. Am I missing anything guys?!
#8630
OTTP has the entire kit if you PM him.
they use different stuff so if you think it will all match up perfectly good luck.... my advise would be to buy it all from one vendor.
#8631
#8632
But how much does it all cost from OTTP? And I would assume it will all line up. I mean you can run a stock header, to an otto dp, to a zzp catback. I don't see why the intake and intercooler package would not work with OTTP's kit.
#8633
Sorry for the hijack since this isn't LSJ related!
#8634
an exhaust is different from custom piping for a turbo kit ... they both use different things in their kits do some research. I would not be telling you this if i did not know for a fact that it is not going to be plug and play when using components from both vendors.
#8635
Ontop of the piston and bottom of the spark plug. And its from the flange i can see it from the top and if i go under the car i can see oil leaking out
#8637
#8638
Josh uses a sheet metal IM, zzp uses the saab. ZZP's ic/charge pipes wont match up with the sheet metal IM. Look at both of them and you can see the huge difference in them.
#8639
#8640
hye guys,
I'm embarking on a LSJ-t build/swap with a k04 aiming for 260hp thats all i need for autoX (im currently running an l61) and i have the engine on a stand my plans for now are to rebuild it with new:
timing chain tensioner
Timing Chain
Main Bearings
Rod Bearings
Piston Rings
ARP Head Studs
head gasket
front and rear Main Seals
valve cover gasket (my valve cover lacked one)
Larger Injectors
Are there any inherantly week parts of the engine that i should be concerned with at sub 300 hp. the engine is currently stock
Timing Chain
Main Bearings
Rod Bearings
Piston Rings
ARP Head Studs
head gasket
Larger Injectors
#8642
haha thanks. i was aware of that. i have lots of parts that i didnt list to make the turbo strap onto the outside. just not sure if there are any weakspots inside the engine to be aware of. Is it worth it to spend the extra on a cometic Head gasket instead of just the OEM one?
#8644
It was apart already. like cranks out girdle is off. pistons and rods are out. head off. so i just want to get it back to stock basically. My buddy who i trust says he is pretty sure the engine was around 60, 000 Km (about 37000 miles).
#8646
Attention people with power: tire rack is closing out nos r888's
http://www.tirerack.com/tires/tires....omCompare1=yes
#8647
Got to play with my car on the dyno a little bit last night It was fun. Started conservative so I could see what changes made what gains. For example, on 21 psi at 10.6 AFR and 19.5* of timing up top it made 429whp. Didn't touch the boost controller, but leaned it out to 11.5 AFR and added a half degree and made 456whp. Then turned it to 22-22.3 lbs and it made 479whp, after 2 more flashes it made 496whp on the same boost.
#8649
After reading few posts i am feeling very skeptical now. Especially now that he is telling me that i need to take the car to dealership and rewrite the ecm because vin and os issue
#8650
