Official Turbo LSJ thread!!!
Old 10-25-2011 | 05:31 AM
  #876
BlkWdoSS's Avatar
Originally Posted by jittjoey
As far as the install I can't find anyone around.... I live in Ohio 45 mins from Pittsburgh Youngstown , hour from Akron and 2 from Cleveland ... Surely there's gotta be someone
come to texas lol
l8r,
PD
Old 10-27-2011 | 02:01 AM
  #877
BumbleBee's Avatar
Getting there
Old 10-27-2011 | 04:48 AM
  #878
BlkWdoSS's Avatar
holy crap, thats a ton of intercooler piping
hope you complete it soon
l8r,
PD
Old 10-27-2011 | 10:57 AM
  #879
tlanzetta11's Avatar
Has anyone ran into this problem? For some odd reason my turbo will not spool for a period of time. It makes a very loud humming sound when it wont spool up. I get 1.6 psi. Its been happening every morning for the past 3 days. When i get going i put it in second gear and hit the throttle and let off about 5 times. on the last time i hear what sounds like a clunk or scraping sound and then the turbo spools like normal. Now, im not sure if its 100% the turbo making the clunk noise because I just heard it today. What could this be? No smoke no burning smell or other random noises afterword. ??
Old 10-27-2011 | 12:27 PM
  #880
SCcobaltSS's Avatar
How many miles on the turbo? Have you checked shaft play?
Originally Posted by BumbleBee
Getting there
Why did they take that route for the piping?
Old 10-27-2011 | 12:43 PM
  #881
1500 miles bullseye 252ET and yes i have, theres the same amount of play in and up and up and down. barely little as in id say 1/4 inch? maybe less but it doesnt seem abnormal.
Old 10-27-2011 | 03:15 PM
  #882
SCcobaltSS's Avatar
1/4" is a lot. You sure something isnt hitting? I dont know how a turbo just doesnt spool unless the WG is all the way open... Even then I would think it would still boost a little at least.
Old 10-27-2011 | 04:45 PM
  #883
Im pretty sure, considering that the amount of play was the same both ways. Ill double check it soon. There was no oil or anything on the fins. All what seems to be perfect. could it be the WG stuck? or maybe the BOV?
Old 10-27-2011 | 05:12 PM
  #884
SCcobaltSS's Avatar
Well I know with my 38mm WG all the way open and trying to hold 10 psi I get creep so I would think yours would still make boost.
I guess the BOV could be but I would think you would hear it...
Hopefully its something easy that the vetran turbo guys will point out.
Old 10-27-2011 | 06:33 PM
  #885
EXsoccer1921's Avatar
you say its been happening every morning, how early?? i know around here its been cold enough at times where the turbo won't spin for about 1 minute after start up cause its too cold. but im also running 2qts of sae50 oil and 4.5 of 5w30 synthetic so its a little thicker than 6.5 of 5w30 synthetic. once everything warms up and the oil is more viscous, works just like normal.
Old 10-27-2011 | 06:44 PM
  #886
nice fresh wash and wax
Old 10-27-2011 | 08:36 PM
  #887
mexi_loco's Avatar
That's what she said...
Old 10-27-2011 | 11:59 PM
  #888
Matt M's Avatar
We had a situation like this once that I can recall, and it ended up that there was actually a nut in the turbine housing. I'm sure there are other possibilities as well, but nothing comes to mind right off hand.
Old 10-28-2011 | 01:38 AM
  #889
as a fellow man, i'm ashamed that you couldn't account for your nuts.
Old 10-28-2011 | 06:08 AM
  #890
BlkWdoSS's Avatar
it is possibly needing to warm up, how long are you letting the car idle prior to driving? the turbo manufacturer will suggest a minimum amount of start and idle down time for their turbos.
Borg Warner says 30 seconds of start/idle time, I would extend that with it being cold. The more abuse you apply to that turbo on a cold start the shorter the life that it will see. You have low or no oil on the bearings, it will destroy the turbo very quickly. Also, check for all foreign material, remove the cold side housing take a look for any wear from the wheel coming in contact with the housing.
l8r,
PD
Old 10-28-2011 | 07:56 AM
  #891
05Slowline's Avatar
u mean i no floor pedal right after key turn?
Old 10-28-2011 | 10:15 AM
  #892
The first time this happened was right after i got off the highway ( I was driving for about 45 min). I go to accelerate with traffic and noticed the high pitch sound and the turbo not spooling. Lasted about 30 Min until it finally started to spool again. Now it only happens in the morning. I checked every possible piece that could cause this to happen. Im about to go take the intake (cold side) off and check that out becasue the car has been sitting over night, (hopefully the problem will occur). Its strange because like i said before after the problem stops everything is normal.
Old 10-28-2011 | 10:17 AM
  #893
Even driving normal will make the sound of it being stuck, thats how I know. After about 1 minute thats when i start to accelerate and decelerate to "break it loose".
Old 10-28-2011 | 10:38 AM
  #894
Old 10-28-2011 | 10:43 AM
  #895
SCcobaltSS's Avatar
Is it me or do those top blades look a little messed up? Or is it the picture? Kind of looks like it made contact.
Old 10-28-2011 | 10:44 AM
  #896
Matt M's Avatar
lol, luckily it wasn't one of mine.
Damn- it looks like that turbo is definitely bad. Tom- you should make an appointment with Tim to get in and get that swapped out.
Old 10-28-2011 | 11:05 AM
  #897
1LowLS's Avatar
The top 2 blades do look like they have been hitting the compressor housing.
Old 10-28-2011 | 11:13 AM
  #898
Matt, could i possibly come in today? Let me know asap, because the next time i can will be next friday.
Old 10-28-2011 | 11:20 AM
  #899
Matt M's Avatar
Shop is full right now, but if you can drop your car off, we can probably get at it on Monday. Can you drop it here Sunday night?
Old 10-28-2011 | 11:22 AM
  #900
I wish I could, but its my DD, Id have to make an appointment and come in early, wait until its fixed then return home. Would that work?
Update: Taking turbo off under warranty getting it swapped monday =D
Quick Reply: Official Turbo LSJ thread!!!
