Official Turbo LSJ thread!!!
Old 11-11-2011 | 07:45 PM
  #1001
jonathan923's Avatar
lol exactly i dont think i plan going over 25psi on this setup so it works for me.
Old 11-11-2011 | 07:47 PM
  #1002
07SSYellow's Avatar
Resident Post Whore/Troll
i have a turbo
L
N
F
Old 11-11-2011 | 09:03 PM
  #1003
tlanzetta11's Avatar
I just replaced my timing chain tensioner today because it was ticking and now im getting a p0341 code. any ideas? still hearing the tick also.
Old 11-11-2011 | 11:59 PM
  #1004
Matt M's Avatar
Stock cams? That is a cam position sensor performance code. It's not as common as the crank/cam position correlation code.
Old 11-12-2011 | 12:28 AM
  #1005
EXsoccer1921's Avatar
thats interesting. cause i just got one of those a few weeks ago. haven't had anything since though. i think it comes from sitting at that weird idle issue if i don't catch it soon enough. where my wideband drops to --- and throttle is lagged. it hasn't happened in quite a while, at random really. but i haven't had any codes in 3ish weeks
Old 11-12-2011 | 01:08 AM
  #1006
mexi_loco's Avatar
well, just took my car to my buddy who happens to be a gm tech. Based on intial driving, he thinks the "clunking" is a fucked tranny. fml...and i only had 32k miles.
Old 11-12-2011 | 02:58 AM
  #1007
i'm glad my trans loves me.
Old 11-13-2011 | 01:39 AM
  #1008
terry11's Avatar
Knock on woooooooood!
Old 11-13-2011 | 01:44 AM
  #1009
BLAZIN07SS's Avatar
I'm too JDM for you
i knock on my woodgrain nardi steering wheel before every pull
i seriously don't know how my car is still in one piece
Old 11-13-2011 | 03:23 PM
  #1010
jittjoey's Avatar
anyone know how a cutout sounds on the turbo lsj swap... i have a 3" down pipe cat-less and then ill be 3" all the way back ... wondering if it would benefit for the cutout for performance, sounds is a plus but who cares if the performance is there
Old 11-13-2011 | 11:50 PM
  #1011
terry11's Avatar
You'll be fine with your 3'' catless if performance is what your worried about.
Old 11-14-2011 | 02:13 AM
  #1012
BlkWdoSS's Avatar
Considering wiring in a vacuum pump for crank case ventilation. Was looking into wiring it to the old intercooler pump wiring, that way I can set it to come up at a certain ECT.
All of the BW guys, what size feed line are you using? Im thinking that my 4an may still be too large and need either a restrictor or a 3an line
l8r,
PD
Old 11-14-2011 | 02:31 AM
  #1013
andyjpoll's Avatar
Turbo Swap
I am interested in making my lsj a turbo with the zzp swap kit. zzp is about a 30min drive from my house . I havent decided on how much power yet but ill keep it between 350-400. So I went to look at pricing out everything that I would want for it, keep in mind my car is 100% stock except for aftermarket headlights and brake rotors so I need a lot yet. Just curious how much $ you all have invested to get to where your at. ZZPerformance - Wish List < my wishlist... comes out to about $7000 with: turbo kit, stage 4 clutch, axles, catback, front and rear trans mount, brfps, flywheel, and a revised shifter bracket, and thats with no install or tuning cost. Is there anything else that I should get with this setup? anything that isn't really necessary? I've read through this entire thread and still cant make up my mind, lol. But from what I can gather I should be ok making 350-400 on stock internals. Actually now that I think about it I will also need lsd since I am one of the unlucky ones that didnt get one stock.... more $$.
Old 11-14-2011 | 02:34 AM
  #1014
the thing with the vacuum pumps is that they're all belt driven. i've been trying to do some research on if a brake booster vacuum pump might work as they can be mounted remotely. trying to figure out if it can be run as a pcv pump and how much of a load it would put on the battery. something like this
Stainless Steel Brakes 28146 Stainless Steel Brakes Electric Vacuum Pump
Old 11-14-2011 | 07:06 AM
  #1015
05Slowline's Avatar
won't need some of the stuff on there like brfs, findanza flywheel, clutch, axels, right away....mines still on the stock clutch @ 65k and doesn't slip at all @ 15psi and i ride it alot lol...when time comes just get the gmpp clutch kit and ur stock flywheel resurfaced. id ditch some of that extra **** and add the tial q bov, switch to s252et, and get the dumped wastegate (save money on this).won't need lsd tranny per say mines not lsd im just gonna get some slicks or drag radials mounted to my old winter tires and put them on since i only drive it weekends really lol cheaper to replace when it breaks too.
Old 11-14-2011 | 03:25 PM
  #1016
BlkWdoSS's Avatar
not all of them, the one that Im looking at is a VW Secondary Air Injection Pump, its just electric, no belt needed
l8r,
PD
Old 11-14-2011 | 04:12 PM
  #1017
link?
Old 11-14-2011 | 05:22 PM
  #1018
BlkWdoSS's Avatar
http://www.amazon.com/07K-131-333-2-.../dp/B005B0IES4
this ones on amazon, pretty expensive from them, Ive found some on ebay that were far cheaper, but it gives you an idea of what it looks like and how it functions.
run lines from oil cap and valve cover to a catch can and from catch can to pump and then pump to intake of VTA
l8r,
PD
Old 11-14-2011 | 10:27 PM
  #1019
05Slowline's Avatar
3rd gear cruise pull lmao
S252et 15psi 3rd gear 40 roll - YouTube
from 40 to like 105 15psi
Old 11-15-2011 | 10:48 AM
  #1020
terry11's Avatar
You would be out on me like 5 cars from a 40 roll (3rd gear) lol
Thats a nice powerband
Old 11-15-2011 | 12:50 PM
  #1021
i finally get my tranny today. still waiting to get the rest of money for the other upgrades. i got a good deal on a 20k used lsj tranny and then on to the staged axels, brembos and 80s with new tune on 22psi then dyno. 380whp goal and am happy for a while haha
Old 11-15-2011 | 12:55 PM
  #1022
rico's Avatar
hola guys idk if yall even remmember me but looking to get another lsj to turbo and keep this time lol
Old 11-15-2011 | 12:57 PM
  #1023
BLAZIN07SS's Avatar
I'm too JDM for you
damn again? lol buy mine! $16,500
Old 11-15-2011 | 12:58 PM
  #1024
rico's Avatar
yes sir lol and haha i wish first gotta sell the beast zx10r and my mazda
Old 11-15-2011 | 03:10 PM
  #1025
I remember you had a yellow turbo lsj i believe?
Quick Reply: Official Turbo LSJ thread!!!
