Official Turbo LSJ thread!!!
Old 03-14-2012 | 06:41 PM
  #1676
SCcobaltSS's Avatar
Does the meth kick in right when you knock? Could it be rich tip in knock from the meth? I have seen this before on meth kits. Just throwing it out there.
Do you have an indicator light that tells you if the meth is spraying?
Old 03-14-2012 | 09:45 PM
  #1677
jonnymerk's Avatar
It's very possible. I think I have it set to start round 5psi then of course full at full boost. Im goin tomorrow to check all my wires and lines so we'll see.
Old 03-15-2012 | 02:25 AM
  #1678
BlkWdoSS's Avatar
slawson, have James check your tune file. there are things you can adjust that will keep you Cruise from activating. I havent touched my HPT stuff lately so Im running blank on which **** you need to change.
You should try tuning with Ivest & Diamond Logic Builder, FML we have to use it at work. some is easier but there is sooooooo much **** that you can **** up quickly.
Jonny, it sounds like your car may be pulling timing for the meth and then not getting it. where was it spraying at when you were tuned?
I would choose the 256et because its a great mid range turbo. It only spools slightly slower than the 252 but can produce a higher volume of air and therefore more relilable HP. Or hell you could always get a 366XL like me
l8r,
PD
Old 03-15-2012 | 03:07 AM
  #1679
jonnymerk's Avatar
l8r,
PD
The settings I havent changed since my tune when I was no knock at all. It's very possible its a prob with the wiring. It has to be using some meth other wise Id know right away cus the car would buck like crasy if it wasnt getting any. I have the progressive controller from devils own. Im so unhappy with the job they did installing it I hate going back to them but dont have much choice atm.
Old 03-15-2012 | 01:04 PM
  #1680
BlkWdoSS's Avatar
u gotta find a better shop...
l8r,
PD
Old 03-15-2012 | 01:56 PM
  #1681
jonnymerk's Avatar
l8r,
PD
trust me know but it aint easy to find one near by and I cant be driving to another city if my car takes more then a day I have no way to get around or back.
I think I found someone so I'll see.
Old 03-15-2012 | 02:39 PM
  #1682
SCcobaltSS's Avatar
Its not hard to wire, how could they mess it up so bad? Check the nozzle, lines, etc. Hit the test button at idle and see what happens to the AFRs if they go rich and you stumble it is working.
Old 03-15-2012 | 08:04 PM
  #1683
jonnymerk's Avatar
cus they hired a n00b to do it. The guy was there for less then a week he qq'd and left cus he wanted more to do. It ended up being a short like before....cus the ******** that did it mounted the controller on my fuse box so wires are getting caught up in the engine bay area.
At least they fixed it so Ill will be good till I pay someone to redo it all the way I want.
Plus side found a guy more local gonna take my car to. He does lots of engine builds and fab work for high horsepower v8s so he should be capable of fixing my exhaust leak lol.
Old 03-17-2012 | 01:31 AM
  #1684
rivaladore's Avatar
Soon to be a fellow lsj turbo member. Order my kit today. Installing April 5th and 6th and getting BYT tuned on the 7th.
Old 03-17-2012 | 02:11 PM
  #1685
jonnymerk's Avatar
enjoy
on a side note its crazy how my IAT's drop now. once I hit 5psi and it activates it dips ti the 50-60s on a 90 degree day.
Old 03-17-2012 | 07:33 PM
  #1686
BlkWdoSS's Avatar
I need to watch sum of my logs to see what my IATs are on my car, I have a fairly large IC so that def helps me a lot.
Glad to see that we are adding sum more turbo guys
l8r,
PD
Old 03-18-2012 | 03:08 AM
  #1687
jonathan923's Avatar
turbo is off the balt now but soon another lsj will be turbo once he gets it, so am happy for them
Old 03-18-2012 | 08:28 AM
  #1688
05Slowline's Avatar
glad to see you got it sold bro sad to see you had to take it off
Old 03-18-2012 | 01:26 PM
  #1689
BlkWdoSS's Avatar
who ended up buying it? did you direct them to this thread?
l8r,
PD
Old 03-19-2012 | 12:17 AM
  #1690
I know bro but thanks man. she's back to m62 now lol no more racing or ripping second gear for me lol
Old 03-19-2012 | 12:19 AM
  #1691
l8r,
PD
yea another member on here is getting it. ill be directing him here once he gets everything so we can help him out
Old 03-19-2012 | 01:13 PM
  #1692
rivaladore's Avatar
Installing my turbo kit in a couple weeks and been trying to think about every aspect of the install so i don't run into any problems. I was wondering if I need to drop the subframe in order to install the s252et turbo?
Old 03-19-2012 | 02:29 PM
  #1693
no you dont. what i think takes the most time is just taking off your oil pan. make sure you clean up the previous gasket pieces on the bottom of the block before you install the new tapped oil pan. putting up the turbo is alittle pain in the ass but once you get it in its starts to get alittle bit easier.
Old 03-19-2012 | 06:21 PM
  #1694
terry11's Avatar
Old 03-19-2012 | 09:39 PM
  #1695
Originally Posted by terry11
that was quick
Old 03-19-2012 | 09:41 PM
  #1696
jonnymerk's Avatar
ya but that initial push is my favorite part lol
Old 03-19-2012 | 09:47 PM
  #1697
terry11's Avatar
that was quick
I must have missed a few pages man. Why did you go back to stock?
Old 03-19-2012 | 09:55 PM
  #1698
i didnt wanted to man, but unfortunately things got rough at home and had to get rid of it
now shes back on a m62 and i got this issue.
its a wistle that i cant seem to find where it comes from. the car on low rmps runs fin but after 4k rpms runs 10.0 afr and doesnt seem to pull anymore.
weird whistle - YouTube
guys have any input on this? sorry if it has nothing to do with a turbo lsj though but i figure us here have been through it all already haha
Old 03-19-2012 | 10:11 PM
  #1699
05Slowline's Avatar
yea i suggest 2 people for putting the turbo on lol bitch is heavy with one hand cramped on jack stands
Old 03-19-2012 | 10:12 PM
  #1700
btw any of you guys have an lsj stock ic pump laying around? thanks guys!
Quick Reply: Official Turbo LSJ thread!!!
