Official Turbo LSJ thread!!!
Old 05-17-2012 | 02:43 AM
  #2251
BlkWdoSS's Avatar
I agree with Rob, I shift at 7-72(ive seen my RPMs go to 79 with a NLS).
Does anyone happen to have a ZZP turbo kit base file for the s256? I am helping with an install and the guy bought the kit used. I will need to flash him with a file to get us over to the dyno. Pm Me if you have anything plz
Old 05-17-2012 | 07:32 AM
  #2252
USMCFieldMP's Avatar
Rattlesnake Race Shop
All I've got is the base file they made for my car. Don't know if or how well it'll work on their S256 kit.
Old 05-17-2012 | 09:08 AM
  #2253
MP Cobalt's Avatar
If you shifted like Ricky Bobby... you wouldn't lose boost at all in-between shifts.
Even when I was on the journal bearing PTE SC5031E, I didn't have slow spool problems after shifting.
More than likely, your problem is a combination of slow shifting and using a base tune. Probably a little bit of shifting too soon, as well. Shifting at 6500 is for fgts. Shifting before 7000 is also for fgts. 7000 to 7200 is optimal. I shifted at 7400 on a stock long block for over 60,000 miles. Also, the tune ZZP provides is a base tune. Too many people get into the thinking that this should be a top notch tune. It's not. It's a base tune. It's designed to be safe and to get the car running so that it can make its way to a dyno for proper tuning.
Well my buddy did tweaks on the tunes they gave me, everything was almost perfect what they sent me, the fueling levels at wot, and timing, he adjusted a few things. I just want to make sure nothing mechanically is wrong with the car and hopefully it's all tune based
  #2254
BLAZIN07SS's Avatar
I'm too JDM for you
rev that sumbitch to 7200rpm
Old 05-17-2012 | 09:10 AM
  #2255
MP Cobalt's Avatar
I have a base file they sent me for my 256et kit, its set up though for brfs because thats what he gave me since they didn't have any tunes without it for the stock fuel system, that could also be another reason my car is funny.
Old 05-17-2012 | 10:42 AM
  #2256
SCcobaltSS's Avatar
So your tune is for a BRFS and not stock? The injection tables are way different...
Old 05-17-2012 | 11:11 AM
  #2257
MP Cobalt's Avatar
yeah i know i was kinda upset zzp did that i payed for a tune to start out and thats what they gave me and i even said something about it and he said we dont got any tunes written for stock fuel system
Old 05-17-2012 | 11:35 AM
  #2258
SCcobaltSS's Avatar
That is dumb, how can they have tunes only for BRFS... Well once that injection is corrected its going to skew all the fueling.
Old 05-17-2012 | 09:12 PM
  #2259
Any base tune that they provided would be far from "Perfect". The MAF Scaling might be "perfect"... but the tune as a whole should have a lot of room to play with and gain power.
Old 05-18-2012 | 10:11 AM
  #2260
MP Cobalt's Avatar
So basically have him rewrite the whole tune and go from there
Old 05-18-2012 | 10:50 AM
  #2261
SCcobaltSS's Avatar
Just adjust the injector tables where they need to be and go from there. The tune itself is probably ok other than minor things you have changed.
Old 05-18-2012 | 10:51 AM
  #2262
SCcobaltSS's Avatar
I doubt the MAF is close once he changes the injector tables to what they should be.
Old 05-18-2012 | 01:39 PM
  #2263
MP Cobalt's Avatar
Lol well i sent Paul the stock file they sent me. He said he was going to adjust injectors tables and see what that does for me
Old 05-18-2012 | 01:56 PM
  #2264
SCcobaltSS's Avatar
Its going to run like crap. haha
Old 05-18-2012 | 09:22 PM
  #2265
MP Cobalt's Avatar
Whats going to run like crap now?
Old 05-18-2012 | 09:51 PM
  #2266
BLAZIN07SS's Avatar
I'm too JDM for you
Can you show us a video of the lag? Slight tuning differences are not going to make it spool super slow.
Old 05-18-2012 | 09:54 PM
  #2267
MP Cobalt's Avatar
I'll have to get a video next week when im off. i also was trying things, and in second gear not wot but pedal almost the whole way down about 90% and the car broke up at like 6k and stuff
Old 05-18-2012 | 10:07 PM
  #2268
05Slowline's Avatar
mine will do that occasionally also if im not wot but not half pedal lol. it's the bov opening when it shouldn't i think, on mine at least which sounds similar. don't happen all the time so idgaf though works fine
Old 05-19-2012 | 03:23 AM
  #2269
BlkWdoSS's Avatar
O ye of lil faith lol, you better be near your phone this weekend lol. Ill be texting you when i get a chance to sit down and start working on this. have you had a chance to take a look at the super long logs I sent you? I think my issue is about to manifest in the worst possible way but trying as hard as possible to be in a new car ASAP to get this one taken apart.
Old 05-19-2012 | 07:59 AM
  #2270
MP Cobalt's Avatar
lol well lets just get it good and close to right haha. I don't get off work till Friday.
Old 05-19-2012 | 07:03 PM
  #2271
DarkChild's Avatar
Do we have videos of the S252ET and the S262ET lurking around on the site? I'm torn between the two. I read full spool on the S252ET is 3,000 but I don't know when the S262ET gets its full spool. I want 400whp on 91 Pump gas with no methanol injected into it. I would like to do that around 20ish PSI. Is this possible? I'm going to keep researching some more. I'm tired of this SC crap. I want turbo.
Old 05-19-2012 | 07:07 PM
  #2272
05Slowline's Avatar
only one i uploaded is this one lol 15psi 40mph 3rd gear roll to the end of 3rd
S252et 15psi 3rd gear 40 roll - YouTube
s252et
when i do some more tuning ill have the go pro hooked up
400 on 91 @ 20psi probably won't happen on either, will prob be close but no reason not to turn it up a few more lbs.
Old 05-19-2012 | 07:19 PM
  #2273
EXsoccer1921's Avatar
billet wheel s262 will net you 400s on 20psi no problem. i hit 443 on pump gas, no meth injection, and i don't have a ported head. however spool on that turbo and the .70a/r housing is ridiculous. it is available in a .55 housing though but i don't know if that housing would carry you to the numbers youre wanting at the boost youre wanting
Old 05-19-2012 | 07:21 PM
  #2274
05Slowline's Avatar
yea didn't breakdown to ar cause he was looking at fast spool ^_^
Old 05-19-2012 | 09:20 PM
  #2275
brideout_8's Avatar
I am looking for 400whp on a 252et no meth and no head work. I am on 93 and was wanting to run 20lbs. Should I be expecting to run more boost to hit 400?
Quick Reply: Official Turbo LSJ thread!!!
