Official Turbo LSJ thread!!!
#2378
has anyone else have problems with wastegate flutter under partial throttle
if i boost to around 12-15psi at part throttle i get wastegate flutter and with the open dump on the wastegate it is really loud
now is there anything i can do to try and fix it
i thought it was because of the 10psi spring and a mbc so i went out and got some more springs and have it set to like 21psi spring pressure then a boost controller to bring it to 23ish
it is a tial 38mm
it is a tial 38mm
#2380
Do any of you guys know what all I need to swap out to run the ZZP stg 3 reverse split cams? Havent delved too far into looking at what will be needed. Im already planning on swapping out the valves, springs, retainers etc with supertech units. Anything else I will need?
#2387
I'm excited I get my car back tomorrow. Meth kit will finally be cleanly installed ( hasn't been workin forever due to prior **** job by another shop). No more vacuum hoses and T's everywhere. Gonna have a nice bar on the intake mani.
#2389
How's the iat2's this summer? I've been cruising in 5th at 60mph and see a constant 130 degrees. Won't do a pull so can't tell you what it's at during wot, lol. Hurry up summer and go away.
#2394
#2399
