Official Turbo LSJ thread!!!
Old 06-23-2012 | 08:22 PM
  #2376
BlkWdoSS's Avatar
I have them on my other computer, If you havent gotten them before I get home then Ill post them for you
Old 06-23-2012 | 09:19 PM
  #2377
CCrunner84's Avatar
If you wouldn't mind checking I'd appreciate it!
Old 07-02-2012 | 10:13 PM
  #2378
Bl4des's Avatar
has anyone else have problems with wastegate flutter under partial throttle
if i boost to around 12-15psi at part throttle i get wastegate flutter and with the open dump on the wastegate it is really loud
now is there anything i can do to try and fix it
i thought it was because of the 10psi spring and a mbc so i went out and got some more springs and have it set to like 21psi spring pressure then a boost controller to bring it to 23ish
it is a tial 38mm
Old 07-03-2012 | 01:19 AM
  #2379
BlkWdoSS's Avatar
havent had wastegate flutter, but im running the turbosmart wastegate
Old 07-05-2012 | 01:44 AM
  #2380
BlkWdoSS's Avatar
Do any of you guys know what all I need to swap out to run the ZZP stg 3 reverse split cams? Havent delved too far into looking at what will be needed. Im already planning on swapping out the valves, springs, retainers etc with supertech units. Anything else I will need?
Old 07-12-2012 | 01:32 AM
  #2381
BlkWdoSS's Avatar
where you guys at? havent seen any one post in a while
Old 07-12-2012 | 03:06 AM
  #2382
EXsoccer1921's Avatar
she's baaaaaaaack
well, has been for a while.... totally forgot about this thread though.
Old 07-12-2012 | 08:50 AM
  #2383
jonathan923's Avatar
if it wasent for the radials, she would look like such a sleeper haha
Old 07-12-2012 | 01:07 PM
  #2384
but then i can't take advantage of it cause i can't hook up. hahah
Old 07-12-2012 | 03:10 PM
  #2385
zrated89's Avatar
you are all slow that is all blower powah FTW
Old 07-12-2012 | 03:23 PM
  #2386
wanna roll race and see what my new tail lights look like?
Old 07-12-2012 | 04:11 PM
  #2387
jonnymerk's Avatar
I'm excited I get my car back tomorrow. Meth kit will finally be cleanly installed ( hasn't been workin forever due to prior **** job by another shop). No more vacuum hoses and T's everywhere. Gonna have a nice bar on the intake mani.
Old 07-12-2012 | 04:57 PM
  #2388
nice ex car looks clean!! and Zrated has been asking for an lsjT for a while now someone should give him the courtesy plzz haha
Old 07-12-2012 | 10:10 PM
  #2389
startingline05's Avatar
How's the iat2's this summer? I've been cruising in 5th at 60mph and see a constant 130 degrees. Won't do a pull so can't tell you what it's at during wot, lol. Hurry up summer and go away.
Old 07-12-2012 | 10:14 PM
  #2390
100* outside temp. 109*, saw 107*s, iat2 while cruising at 70.
Old 07-12-2012 | 10:18 PM
  #2391
Must be nice. Today wasn't bad, the highest today cruising was 117. Damn Georgia heat.
Old 07-12-2012 | 10:20 PM
  #2392
BLAZIN07SS's Avatar
I'm too JDM for you
Iat2 shouldn't be that hot while cruising. I cruise like 15-20* above ambient
Old 07-12-2012 | 11:47 PM
  #2393
zrated89's Avatar
Sure but u cant use radials then after ee can meet at the strip
Old 07-12-2012 | 11:49 PM
  #2394
zrated89's Avatar
I'll be running danews 252et setup when mine is on the road. But honestly I'm not worried about a 252 on my new setup
Old 07-12-2012 | 11:56 PM
  #2395
lol just cause you want me on a street tire doesn't mean i won't pedal it. it'll still hook up
Old 07-13-2012 | 12:38 AM
  #2396
zrated89's Avatar
Oh ill be pedaling right beside u man oh yea well do a 20-120 roll :p
Old 07-13-2012 | 03:28 AM
  #2397
BlkWdoSS's Avatar
now the fun is back, I want in on this racing action.
check is coming in tomorrow to start building my motor, plan on going straight thru the 500whp mark without a hiccup lol
Old 07-13-2012 | 09:40 AM
  #2398
miltowncobalt's Avatar
what setup is all needed to be in the low low 400s? looking to turbo my lsj this winter. but gunna peice together a kit whats the betters parts and whats all needed
Old 07-13-2012 | 10:59 AM
  #2399
lol that is 15-20* above ambient here. the other weekend the heat index was like 116* thats when i was seeing 130* plus.
I havent seen all these temps sense the m62
Old 07-13-2012 | 11:42 AM
  #2400
Killa SS's Avatar
in about a week or so, I will be joining the ZZP built engine and turbo club
Quick Reply: Official Turbo LSJ thread!!!
