Official TVS Thread!!!
#3291
South Central *********
ZZP Girdled Block
9.5:1 diamond pistons
pauter rods
ARP head studs
Billabong ported head
STOCK BALANCE SHAFTS
ZZP stage 2 cams
82# valvesprings
Harrop w/ 2.7" pulley
ATI OD Crank damper
phenolic spacer
dual pass opt B
Return style with fuel lab regulator
deatchwerks DW300 pump
80# injectors
pump rewire
E85
Clear Image Automotive Midlength header
catless DP
Hahn 3" exhaust
Injen intake
ported LSJ TB
NGK BKR7E gapped to .030"
HP tuned
pauter rods
ARP head studs
ZZP stage 2 cams
82# valvesprings
ATI OD Crank damper
phenolic spacer
dual pass opt B
80# injectors
pump rewire
E85
catless DP
Hahn 3" exhaust
Injen intake
ported LSJ TB
HP tuned
#3300
run 009:
Harrop w/ 3.1" pulley
80# injectors
pump rewire
93 Octane
catless DP
Hahn 3" exhaust
Injen intake
ported LSJ TB
Cobra HE
NGK BKR7E gapped to .032"
Run 012:
ZZP Girdled Block
pauter rods
ARP head studs
ZZP stage 2 cams
82# valvesprings
ATI OD Crank damper
phenolic spacer
dual pass opt B
80# injectors
pump rewire
E85
catless DP
Hahn 3" exhaust
Injen intake
ported LSJ TB
i also have another dyno that made 370/292... so more or less the same.
my single pump cannot keep up. i will have to go dual pump to reach higher than 7000 rpm upshifts at this point in time.
pulls like a motha!
80# injectors
pump rewire
93 Octane
catless DP
Hahn 3" exhaust
Injen intake
ported LSJ TB
Cobra HE
Run 012:
ZZP Girdled Block
pauter rods
ARP head studs
ZZP stage 2 cams
82# valvesprings
ATI OD Crank damper
phenolic spacer
dual pass opt B
80# injectors
pump rewire
E85
catless DP
Hahn 3" exhaust
Injen intake
ported LSJ TB
pulls like a motha!
