Official TVS Thread!!!
#3404
Roger.... His truck would beat you even once you get stuff swaped out. Honestly. Heed your own advice.
driver mod alone puts him in a stg2 far above most.
#3406
Holy **** calm down. I know what he said. I was simply stating a fact.
And I did say (in other words) that bryan in a stg2 (or any lsj) can and has put down way better times than most of us in a similar car. Myself Included. He's a damn good driver.
#3407
I just get sick of seeing people do this ****, a disagreement will start about one thing and then people snowball it into something else. We all know area has a bad ass truck this is already a giving, what we dont know is can area using an lsj stg 2 car beat bratboy's current setup. Either way we prolly never know, I didnt look but im assuming they dont live in the same state and I dont think area owns a cobalt anymore either, but this happens in other threads as well so before this turns into a slam fest about whats faster area's truck or bratboy's cobalt lets just stay on track with tvs info!
#3411
Wow awful you're quick to call someone a nut swinger...
Yet you're often the instigator and one of the biggest offenders.
Roger and I go back and forth all the time. It was no big deal till you had to dive in to play momma.
Take a dose of your own medicine and shut the hell up for a while.
#3412
#3416
I have been. Area and tstone both ran tvs's.
The 79's never seemed to flow what they claim; they fall behind 80's by alot more than 1lb.
Is your fuel system completely stock?
#3420
I'll be running cams in a few weeks.
LSJ's are identical mechanically through out all the years.
You would be fine. Plus ZZP's COMP Cams cam line are drop in ready cams.
#3421
The benefit (and reason for higher cost) of the
Zzp cams is tha they have done the leg work and have the cams ground directly for the lsj so no adjustments are needed.
#3422
Right. Cams from comp directly should work, and many have ran them, but to be 100% perfectly exact to the specs they need to be degreed manually with adjustable cam gears. Just like in the build book.
I'll have some Saab 9-3 LK9 B207R cams if you'd like them
![Very Happy](https://www.cobaltss.net/forums/images/smilies/icon_biggrin.gif)
#3424
I read that because the sensors on the cams and only 07 models have them. It be nice if I can put cams in mine. Fingers crossed.
