Official TVS Thread!!!
Old 01-08-2013, 10:24 AM
  #3751
zrated89's Avatar
Also remember Tim was a full blown stroker motor with the harmonics changed. So he would def need the ati balancer. But on a stock stroke car I don't see an issue
  #3752
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by zrated89
Still beating dead horses I see. And for reference I was running 7600rpms on the stock valve train and now run 8+ on my built motor and stock dampener. When I pulled my stock block down there were no signs of any damage from doing so. To each there own. Does the ati dampener work yes. Is it required when ur car only sees 8k rpms for a split second no.
Hey get out of this thread turbo boy
On a serious note, when I removed the stock valve springs, I could see how they handle blasts to 7k +.... They are tiny compared to my supertechs, but were fairly stiff.
Old 01-08-2013, 10:27 AM
  #3753
zrated89's Avatar
Yea I only had float a few times running the stockers and that was when I got greedy and tried running 8k after my 12.009 pass lol. Wanted that 11
Old 01-08-2013, 10:28 AM
  #3754
Administrator
Administrator
Staged07SS's Avatar
Wish u got it man!
Hey, I'll be finishing up with my Kent Moore Cam Gear bracket soon. I'll keep u posted.
Old 01-08-2013, 10:33 AM
  #3755
zrated89's Avatar
Def man. Had I run on my built motor and E she would have been mid 11s all day with 120+ traps
Old 01-08-2013, 10:42 AM
  #3756
mrbelvedere's Avatar
it was still a neutral balanced engine that has nothing to do with it
maybe but know one will ever know
Old 01-08-2013, 12:20 PM
  #3757
zrated89's Avatar
I know lol. And to me that's all that matters. I'm actually done posting results. I also know the car went 11.90 but since the slip wasn't legible I didn't claim it.
Old 01-08-2013, 12:27 PM
  #3758
574
574's Avatar
Since your going turbo dont you need turbo cams?
Old 01-08-2013, 12:34 PM
  #3759
how do you know you went 11.90 if it wasent legible lol
Old 01-08-2013, 12:36 PM
  #3760
zrated89's Avatar
Because I know how the run compared to the many 12.0 runs. I know the car therefor I know. So does others that were present at the track.
No. I sold the blower cams and will be back on the stockers for now.
Old 01-08-2013, 01:16 PM
  #3761
post it up
Old 01-08-2013, 02:23 PM
  #3762
InfraRedline's Avatar
Would have easily gone 120+ for sure. If I was trapping 119 on those tall slicks and stock CR and stock cams your 10:1 and cams would have made it a breeze.
Old 01-08-2013, 05:28 PM
  #3763
armcclure's Avatar
Originally Posted by 100% METH
One problem with those maps is they are calculated using inlet volume not rpm; which most ppl don't realize.
Inlet volume/sec is not directly related to rpm, meaning there's no good equation. Different temps, elevation, he'll even changing your air filter changes the relation between inlet vol/ rpm.
So stating a blowers efficiency is x rpm to y rpm is hardly any help at all when examining most compressor maps.
This one happens to have it, but most don't.
Just FYI for some of you.
Old 01-08-2013, 05:54 PM
  #3764
euthanasia's Avatar
Another thing to add is people don't know the tested sc is seeing no more then 10 psi and with no type of cooling when tested. The older M series superchargers were tested at 5 psi. And turbo's are typically tested at 15 psi. But you are 100% right most performance maps dont show sc rpm.
Old 01-08-2013, 05:56 PM
  #3765
574
574's Avatar
While your here, would you port a TVS if it was sent to you? I remember there was little gains when you did it
Old 01-08-2013, 06:16 PM
  #3766
no need to port a tvs
Old 01-08-2013, 06:19 PM
  #3767
TStone's Avatar
He made like 4 ftlbs.... I'm sorry but that's not even worth the $50 you'd have to pay to ship it...
Old 01-08-2013, 06:32 PM
  #3768
zrated89's Avatar
Originally Posted by mrbelvedere
post it up
i have a better idea ill post up my 10 second time slips and vids soon as my track opens up how about that? Taylor can and should post up some 11 sec times this year on the TVS and i hope he does
Old 01-08-2013, 08:25 PM
  #3769
10 sec pffffft to slow lol
Old 01-08-2013, 08:29 PM
  #3770
zrated89's Avatar
lolz for this forum thats the speed of sound
Old 01-08-2013, 08:35 PM
  #3771
that's plaid speed
Old 01-08-2013, 08:38 PM
  #3772
TStone's Avatar
mrb said he'll go 10's before you kenny............. :P
Old 01-08-2013, 08:54 PM
  #3773
zrated89's Avatar
haha hes gotta keep his stoughs together first
and no because hell never ditch the blower lol
Old 01-08-2013, 08:57 PM
  #3774
TStone's Avatar
Don't be so quick to assume.. he's got quite the head on his shoulders. He has a setup unlike anyone else. He's got some stuff up his sleeve. It's possible, that's all I can say.
Old 01-08-2013, 09:04 PM
  #3775
armcclure's Avatar
Not unless he makes a certain commitment...
Invest in a tanker John lol
Or just build a still...
Quick Reply: Official TVS Thread!!!
