Official TVS Thread!!!
Old 01-24-2013, 02:31 PM
  #4101
lsjion's Avatar
You used the head I did correct?
Old 01-24-2013, 02:36 PM
  #4102
ThexGovenor's Avatar
Cold starts suck on E85
Old 01-24-2013, 02:43 PM
  #4103
advise's Avatar
Its all in the tune started my car for the first time in a week 16° no problem
Old 01-24-2013, 02:48 PM
  #4104
South Central *********
JapEatr's Avatar
Josh gives the best head!
Old 01-24-2013, 05:09 PM
  #4105
armcclure's Avatar
Multiply the cranking fuel table 25% richer and get bkr6e's. problem solved.
Old 01-24-2013, 06:19 PM
  #4106
Powell Race Parts's Avatar
good advice from a valuable source.Arm, you get that motor sleeved yet? Lol. cheers.
Old 01-24-2013, 07:43 PM
  #4107
zrated89's Avatar
Originally Posted by mrbelvedere
if that was the case as soon as you get rid of the stock pulley then the blower is worthless because your starting to overspin it so by that all blowers are useless
you know what im talking about smart ass rpms
Old 01-24-2013, 08:13 PM
  #4108
InfraRedline's Avatar
Originally Posted by JapEatr
anyone have a TVS 2.6" pulley they would sell?
I believe Philzoot has one.
Old 01-24-2013, 08:28 PM
  #4109
100% METH's Avatar
I haz one too
Old 01-25-2013, 02:31 AM
  #4110
armcclure's Avatar
Lol one step at a time! I'll probably have it done with his next batch. Then start rounding up all the little pieces.
Old 01-25-2013, 10:19 AM
  #4111
he prolly sold it to me with his TVS. lol
Old 01-25-2013, 12:49 PM
  #4112
dwarrick's Avatar
How many of you are running a tvs with stock pulley and a factory bottom end?
Old 01-25-2013, 12:52 PM
  #4113
574
574's Avatar
I kinda was. I was on a 2.9
Old 01-25-2013, 01:44 PM
  #4114
I think rootbeer did for a while
Old 01-25-2013, 02:33 PM
  #4115
RooTBeeR's Avatar
Yup, 2 separate occasions.
60#'s
Only mods were bkr7e's
K&N cone filter.(full stock box)
Dual pass
Option b
Long tube header
3" resonator
Almost bare minimum-ish lol
Old 01-25-2013, 04:10 PM
  #4116
dwarrick's Avatar
I'm just worried about running factory bottom end. I have all the other mods to support and more, it is just my stock bottom end that worries me.
Would pistons be a wise choice? I feel the stock rods should hold up fine. I am not going for anything much over 300hp
Old 01-25-2013, 04:17 PM
  #4117
574
574's Avatar
I'll be running a 2.6 on a stock engine... pistons would be good if you want to do them but they are not needed
Old 01-25-2013, 04:34 PM
  #4118
mrbelvedere's Avatar
aparantly you haven't read enough through this thread
Old 01-25-2013, 04:45 PM
  #4119
TStone's Avatar
If you do go past 300hp, you have to upgrade all the bottom end like the cams, valves, and cam bearings.. and you have to modify the valve cover so you can run a coolant line into it so you can keep the internal parts cooled.
  #4120
You will be fine on the stock bottom end if you are only going for 300 on a TVS.
Old 01-25-2013, 05:53 PM
  #4121
Melon's Avatar
This is the first I'm hearing of adding a coolant line to valve cover. Please elaborate as this may b something I have to look into
Old 01-25-2013, 05:56 PM
  #4122
TStone's Avatar
The coolant keeps the pistons a lot colder so the engine runs colder so you make more horsepowers. best cooling mod out there
Old 01-25-2013, 05:58 PM
  #4123
Melon's Avatar
Alright. Where and how do u do it? I honestly have never heard of doin this before. Even with running meth?
Old 01-25-2013, 06:00 PM
  #4124
TStone's Avatar
You know the nipple on the back of the valve cover? Take some heater hose and attach it to the nipple and tap into the coolant pipe right below it. Yes, it is much better than meth. It keeps my IAT2 within 5* of IAT1 even after a pull
Old 01-25-2013, 06:04 PM
  #4125
Melon's Avatar
Don't u have to run a return line somewhere? Can't just pour coolant into cover without having a place for it to go?
Quick Reply: Official TVS Thread!!!
